- install 10.2.1
- Uploaded default license
- installed collabora development edition(CODE)
- got a notification to run domain join script “Not all installed apps have been registered”
- tried to update license with new ucs.license file received by email.
- restarted the server.
- still not able to execute join scripts.
collabora CODE should be installed
join script failing with following log
DOMAIN JOIN
Search
1
Domain join
SHOW JOIN STATUS
Join log
Configure 01univention-ldap-server-init.inst Fri Sep 6 08:52:27 IST 2019
2019-09-06 08:52:27.025807944+05:30 (in joinscript_init)
Not updating windows/domain
Not updating kerberos/realm
File: /var/lib/univention-ldap/translog/DB_CONFIG
2019-09-06 08:52:30.406460065+05:30 (in joinscript_save_current_version)
Configure 02univention-directory-notifier.inst Fri Sep 6 08:52:30 IST 2019
2019-09-06 08:52:30.473684458+05:30 (in joinscript_init)
Starting univention-directory-notifier (via systemctl): univention-directory-notifier.serviceJob for univention-directory-notifier.service failed because the control process exited with error code.
See “systemctl status univention-directory-notifier.service” and “journalctl -xe” for details.
failed!
2019-09-06 08:52:30.758024509+05:30 (in joinscript_save_current_version)
Configure 03univention-directory-listener.inst Fri Sep 6 08:52:30 IST 2019
2019-09-06 08:52:30.842171278+05:30 (in joinscript_init)
2019-09-06 08:52:32.186115880+05:30 (in joinscript_save_current_version)
univention-join-hooks: looking for hook type “join/pre-joinscripts” on ucs-6098.pb.intranet
Found hooks:
RUNNING 50collabora.inst
2019-09-06 10:22:23.423055697+05:30 (in joinscript_init)
Object exists: cn=services,cn=univention,dc=pb,dc=intranet
Object exists: cn=collabora,cn=services,cn=univention,dc=pb,dc=intranet
WARNING: cannot append collabora to service, value exists
No modification: cn=ucs-6098,cn=dc,cn=computers,dc=pb,dc=intranet
Considering dependency proxy for proxy_wstunnel:
Module proxy already enabled
Module proxy_wstunnel already enabled
4fb838c701a16929507f09aeb22ed57ec90d378a40f7dc2e428db9d4ab65d84e
richdocuments not found
EXITCODE=1
7f1d1ef6-831d-438f-9fe9-b8130740f0e4
univention-join-hooks: looking for hook type “join/post-joinscripts” on ucs-6098.pb.intranet
Found hooks:
Fri Sep 6 10:22:41 IST 2019
univention-run-join-scripts finished
cp: cannot stat ‘’: No such file or directory
univention-run-join-scripts started
Fri Sep 6 10:24:39 IST 2019
Found hooks:
2019-09-06 10:24:44.981707771+05:30 (in joinscript_init)
EXITCODE=1
f25748b8-d0be-4c44-850f-f0f8f65ecdd4
Found hooks:
Fri Sep 6 10:25:02 IST 2019
Fri Sep 6 10:27:24 IST 2019
Found hooks:
2019-09-06 10:27:29.263521668+05:30 (in joinscript_init)
EXITCODE=1
6c8cdddc-25e7-4219-8142-9e2236db8caa
Found hooks:
Fri Sep 6 10:27:46 IST 2019
Fri Sep 6 23:07:26 IST 2019
Found hooks:
2019-09-06 23:07:32.093955026+05:30 (in joinscript_init)
EXITCODE=1
0f630be2-2b72-418f-ab4f-8ac04ce970a2
Found hooks:
Fri Sep 6 23:07:49 IST 2019
Fri Sep 6 23:12:37 IST 2019
Found hooks:
2019-09-06 23:12:41.854772460+05:30 (in joinscript_init)
EXITCODE=1
88f056af-2806-420c-be04-01e1983c06c9
Found hooks:
Fri Sep 6 23:12:58 IST 2019
Administrator
@ucs-6098
License
2
Server
2
User settings
1
Certificates
2
Switch language
2
Help
7
Back to start site
Logout
Operating system: HOST system Windows
10.2.1
