I would like to upload anything I want onto my own Owncloud server. I know it’s probably a security feature but I’ve been developing some things in Python but every time I try to upload one of my apps, Owncloud detects it as a virus and doesn’t upload it. But I made it myself, so I know it is not a virus, I just need to put it on my cloud, because that’s what I would like to keep my projects on. A few projects I made ARE viruses and I get the same error. I would just like to upload whatever I want without error
I get “Not acceptable” error in the logs when I look at why the file didn’t upload
- Upload “Example.py”
- Doesn’t work, get an error “Not acceptable”
Apache 2.2.32
PHP version: 5.6.29
ownCloud version: 10.0.2
Client version: 2.3.2
Operating system: Windows 10 Home
OS language:
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt
(On Windows usingcmd.exe, you might need to firstcdinto the ownCloud directory)
(See also ownCloud Documentation Overview ) -
Web server error log:
