- install owncloud in docker
- use a directory assigned by me for files.
Owncloud uses the directory I assigned in the docker compose:
volumes:
- files:/srv/dev-disk-by-uuid-200c66e5-83a6-43a5-95eb-8aaca475fe5e/canigiacloud
It automatically creates a directory in /mnt/data and uses the latter, even though in the configuration file at the line “datadirectory” there is assigned the directory of my choice
Operating system: Docker compose with portainer in Debian
Web server: nginx
Database: mariadb:10.11
PHP version: 7.4/8.1
ownCloud version: (see ownCloud admin page) latest version
Where did you install ownCloud from: docker compose
none
