OC 10.0.3.3 ./occ Call to undefined function
  1. sudo -u www-data ./occ
normal feedback from ./occ when no arguments are given
PHP Fatal error: Call to undefined function OC\App\simplexml_load_file() in /var/www/owncloud/lib/private/App/InfoParser.php on line 41
Linux XXXXX 4.4.0-79-generic #100-Ubuntu SMP Wed May 17 19:58:14 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
(which is ubunt 16.04)
Apache Server Status for XXXXX (via XXXXXX)
Server Version: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g
Server MPM: prefork
Server Built: 2017-09-18T15:09:02
Current Time: Sunday, 03-Dec-2017 12:23:45 CET
Restart Time: Sunday, 08-Oct-2017 21:01:49 CEST
Parent Server Config. Generation: 59
Parent Server MPM Generation: 58
Server uptime: 55 days 16 hours 21 minutes 56 seconds
Server load: 0.11 0.20 0.18
Total accesses: 2148012 - Total Traffic: 222.9 GB
CPU Usage: u3015.96 s849.26 cu0 cs0 - .0803% CPU load
.446 requests/sec - 48.6 kB/second - 108.8 kB/request
1 requests currently being processed, 9 idle workers
.W_...
Scoreboard Key:
“_” Waiting for Connection, “S” Starting up, “R” Reading Request,
“W” Sending Reply, “K” Keepalive (read), “D” DNS Lookup,
“C” Closing connection, “L” Logging, “G” Gracefully finishing,
“I” Idle cleanup of worker, “.” Open slot with no current process
sqlite3
php7.0
10.0.3.3
older (at least 8)
via ubuntu repository deb download.owncloud.com /
like ./occ, the admin login doesn’t work anymore. At some point I updated to owncloud which only allowed php7 (was that OC8 or OC9 already?). Since that is/was non-standard in Ubuntu 16, it took quite some effort to get php7 installed next to php5, which ubuntu did not want to un-install. In parallel, I now have the complication of having an original mysql-based setup of the server and (without me being aware) a new sqlite3 database in the data directory.
I am basically stuck, because any malfunctioning (admin login, ./occ, file locks) could be caused by the php5->php7 transition, the mysql->sqlite3 transition or any of the OC 8>9>10 transitions that were either ‘automatic’ or via the repository or via changing the repository name when going from ubuntu 15 to 16 (for instance).
The system starts to have more and more file locks and the current ‘keeping the system in the air’ way of ‘maintenance’ makes OC less and less usable for all users. Before I ruine everything, maybe fixing ./occ would help me to identify what is broken and what not.
Any help on how to get out of this deadlock would be appreciated. I acknowledge the messy status of the system at the moment.
It looks to my that you havn’t followed ownCloud Documentation Overview and you’re missing the php7.0-xml package.
Dear tom42,
I think I did:
sudo apt install php7.0-xml
Reading package lists… Done
Building dependency tree
Reading state information… Done
php7.0-xml is already the newest version (7.0.22-0ubuntu0.16.04.1).
at least it’s the current version of ubuntu16.04
It looks to me that something got wrong / is miss-configured in your PHP configuration and that module isn’t loaded correctly.
When I run php7.0 -i, it gives me several indications that “things are allright”:
Additional .ini files parsed => /etc/php/7.0/cli/conf.d/10-mysqlnd.ini,
/etc/php/7.0/cli/conf.d/10-opcache.ini,
/etc/php/7.0/cli/conf.d/10-pdo.ini,
/etc/php/7.0/cli/conf.d/15-xml.ini,
/etc/php/7.0/cli/conf.d/20-calendar.ini,
… and later:
dom
DOM/XML => enabled
DOM/XML API Version => 20031129
libxml Version => 2.9.3
HTML Support => enabled
… and later:
json
json support => enabled
json version => 1.4.0
libxml
libXML support => active
libXML Compiled Version => 2.9.3
libXML Loaded Version => 20904
libXML streams => enabled
… and later
wddx
WDDX Support => enabled
WDDX Session Serializer => enabled
xml
XML Support => active
XML Namespace Support => active
libxml2 Version => 2.9.3
xmlreader
XMLReader => enabled
I know little of php (7); is there a way to test the XML part, separate from OC?
My php -i output has the following:
Simplexml support => enabled
I think this is probably the one which is required for the “simplexml_load_file” in your initial posted output.
This is enabled too, but I get an extra ‘revision’ line:
SimpleXML
Revision => $Id: b8b5c37931a53e50a937c0aef2a26d351e173215 $
Schema support => enabled
Do you get such a ‘revision’ line below too?
Could this be the problem: apt installs php7.0-xml instead of php7.0-simplexml:
sudo apt install php7.0-simplexml
Note, selecting ‘php7.0-xml’ instead of ‘php7.0-simplexml’
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Anyone an idea?
The error relates to simple_xml in php7.0, but I do not know how to proceed debugging.
I have checked that:
sudo a2dismod php5: Module php5 already disabled
sudo a2enmod php7.0: Module php7.0 already enabled
sudo service apache2 restart
sudo -u www-data /var/www/owncloud/occ:
ls /etc/apache2/mods-enabled/ | grep php
php7.0.conf
php7.0.load
I’m stuck…
The occ command is a PHP file, not a batch script, so you need to run it with PHP. See: ownCloud Documentation Overview
Yes, this output gave another idea. This looks to me like a typical user error. Above you had used php7.0 to post the output and proved that simplexml is installed, but every PHP script is always using the “php” binary which probably defaults to PHP 5 on your system.
thanks both for the reply.
Indeed, the file /var/www/owncloud/occ has:
#!/usr/bin/env php
on the first line and this will find php5, because /usr/bin/php links to /etc/alternative/php (in Ubuntu at least), which, in turn points at /usr/bin/php5.6 (on my computer).
server:/etc/alternatives> ll php
lrwxrwxrwx 1 root root 15 Jun 12 22:29 php → /usr/bin/php5.6*
so, I changed it to point at php7.0:
server:/etc/alternatives> sudo ln -fs /usr/bin/php7.0 php
that SOLVES the problem and I can now run ./occ in /var/www/owncloud since the ‘php’ inside now will find php7.0
(still needs to be run as user www-data, though).
Thanks!
