I’m not aware of that feature. You can try to use the hidden attribute in the DfsPrivate folder if possible, but it might affect other system that might be connected to the system.
Thanks for your reply.
You mean set the Hidden attribute on the folder? Since this is production I don’t think I can make that change now, are you saying anything with a hidden attribute will not be scanned by SMB External Storage?
Yes. Files and folders with the hidden attribute set will be treated as non-readable, so they won’t be shown. It might get accidentally scanned if someone access to the folder directly, but this is unlikely because, as said, the folder won’t be shown neither in the web UI nor the clients.
Not that, as far as I know, changing the file attributes won’t change the mtime of the folder. You’ll likely need to force an additional change on the parent folder in order to change the mtime so ownCloud can scan the folder and update the permissions.
Thanks for that,
I need to investigate a bit more still.
The DfsrPrivate folder will only show if the view system files is on in windows explorer, it appears to show as a shortcut when I try to view it, but it is a junction to System Volume Information which is owned by SYSTEM. Doesn’t this mean it’s already hidden?
D:\StudentShare>dir /ah
Volume in drive D is Data
Volume Serial Number is B885-3DB6
Directory of D:\StudentShare
22/10/2018 10:10 AM 18,436 .DS_Store
01/10/2017 07:22 PM <DIR> .TemporaryItems
21/07/2013 05:21 PM <JUNCTION> DfsrPrivate [D:\System Volume Information\DFSR\Private\{63704702-175D-4424-A923-3F62A176C920}-{E82863D5-0258-4B31-88BA-B3385F0A59B5}]
08/03/2017 01:04 PM 100,864 Thumbs.db
I have been meaning to reply with a success story, but wasn’t the case still…
When I mount it under the owncloud test server I can’t actually see the contents but it does show hidden
smb: \> dir
. D 0 Tue May 14 10:38:38 2019
.. D 0 Tue May 14 10:38:38 2019
.DS_Store AH 18436 Mon Oct 22 11:10:39 2018
.TemporaryItems DH 0 Sun Oct 1 20:22:42 2017
1 to 1 Files D 0 Tue Apr 2 10:49:16 2019
Design Process Art.jpg A 38542 Tue Mar 21 13:24:57 2017
DfsrPrivate DHS 0 Sun Jul 21 17:27:03 2013
So the only way for this to work is to add RX to the DFSR\Private\GUID folder
The strange thing is yesterday I added RX for my staff account yet it was still inaccessible on the owncloud test server.
I spun up another VM mounted the share, all good, installed owncloud and for the first time I can see the contents and everything is working.
Today however, that new VM cannot see the share again. I check the permissions and they have magically disappeared… I added myself again and will check again tomorrow
