Has anyone also been able to determine the problem or have an idea for a solution?
- Set up mail notification for SMTP
- Send email test
E-mail sender should my address form the config.
A few weeks/months ago it worked correctly. Is it possibly a problem with 10.6?
SMTP Address (login data) from my mail account.
Raspbian GNU/Linux 10 (buster)
Apache/2.4.38 (Raspbian)
MySQL/MariaDB-Version: 15.1 Distrib 10.3.27-MariaDB
PHP-Version: 7.3.27-1~deb10u1
10.6
updated
“system”: {
“instanceid”: “ocoq89hwbqzx”,
“trusted_domains”: [
“nas”,
“datadirectory”: “/media/owncloud/data”,
“overwrite.cli.url”: “REMOVED SENSITIVE VALUE/owncloud”,
“htaccess.RewriteBase”: “/owncloud”,
“dbtype”: “mysql”,
“version”: “10.6.0.5”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “Europe/Berlin”,
“installed”: true,
“mail_smtpmode”: “smtp”,
“default_language”: “de”,
“trashbin_retention_obligation”: “auto, 30”,
“loglevel”: 3,
“mail_smtpport”: “465”,
“defaultapp”: “files”,
“overwriteprotocol”: “https”,
“updatechecker”: false,
“blacklisted_files”: [
“.htaccess”
“enable_avatars”: true,
“asset-pipeline.enabled”: true,
“activity_expire_days”: 365,
“quota_include_external_storage”: false,
“versions_retention_obligation”: “auto, 7”,
“allow_user_to_change_display_name”: false,
“knowledgebaseenabled”: false,
“session_lifetime”: 86400,
“check_for_working_htaccess”: true,
“maintenance”: false,
“log_rotate_size”: 1048576,
“session_keepalive”: true,
“mail_smtpdebug”: false,
“integrity.ignore.missing.app.signature”: [
“theme-mytheme”
“cache_chunk_gc_ttl”: 86400,
“skeletondirectory”: “/var/www/html/owncloud/apps/theme-mytheme/core/skeleton”,
“mail_smtpauth”: 1,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“mail_smtpauthtype”: “LOGIN”,
“mail_smtpsecure”: “ssl”,
“memcache.local”: “\OC\Memcache\APCu”,
“filelocking.enabled”: true,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379
“version.hide”: true,
“upgrade.disable-web”: true
Enabled:
- activity: 2.6.0
- audioplayer: 2.8.4
- brute_force_protection: 1.1.0
- calendar: 1.6.4
- comments: 0.3.0
- configreport: 0.2.0
- contacts: 1.5.5
- dav: 0.6.0
- drawio: 0.0.9
- extract: 1.2.4
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_clipboard: 1.0.3
- files_external: 0.7.1
- files_mediaviewer: 1.0.4
- files_pdfviewer: 0.11.2
- files_sharing: 0.14.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- market: 0.6.0
- metadata: 0.10.0
- notifications: 0.5.2
- password_policy: 2.1.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- theme-mytheme: 2.0.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- user_external
