OC 10 missing apps and Ownnote
Hello - I am newer to OC so please excuse me if I miss some finer points. Everything was working so well for me and it seems progress has made this whole suite entirely unusable for me
Have installed numerous instances of OC 9 with various apps via cPanel with my hosting provider. I have used various apps depending on the application.
I have never been able to successfully install OC manually however have had great success since finding the setup-owncloud.php installer. Only down side is that by default it installs the latest version of OC.
Recently, using this installer I noticed I that I lost any reference to apps management. I discovered after much frustration that OC 10 doesn’t seem to support apps - or at least the one I depend on most for my catalogs - Ownnote.
I can’t imagine why developers would remove this functionality. Something I wish I understood.
Here you can see the applications menu compared in my installs of OC 9 and 10.
Is anyone able to recommend a method to install ownnote on to OC 10 or a way to modify my php installer to reference and load version 9? This is way over my head and I’m at a loss.
https://postimg.org/gallery/19etdbk0k/
https://s29.postimg.org/4dry577br/001_OC-9.jpg
https://s29.postimg.org/ep4axuz13/002_OC-10.jpg
https://s29.postimg.org/rhsexsamv/003_1.png
https://s29.postimg.org/eg6q7xm8n/004_2.png
https://s29.postimg.org/8tadagjpz/005_3.png
https://s29.postimg.org/slcj9qv9z/006_4.png
You are missing the Market app. Please check your logs, or errors ( integrity check )
Although, I checked, and ownNote is not in the market app. You could install it manually from the store - Marketplace
The developer of this app, has not yet released it for owncloud 10. Maybe you will have to wait or install a older version of owncloud.
Here is a link to our documentary, with a 9.1 repo.
https://doc.owncloud.com/server/10.0/admin_manual/installation/linux_installation.html#repositories
