oC 9.1.4 adding SFTP external storage doesn't work
  1. Log in as yourself, Browse to “Personal” settings, scroll down to external storage
  2. Select Type “SFTP” and enter the credentials
  3. Click away from the text box and it will “test” the connection, showing a spinning circle icon
  4. The spinning circle icon spins forever and never becomes a green “success” circle.
  5. The SFTP server shows a successful login in, using both username/password and RSA shared key, but oC does not indicate this.
From the SFTP server log, showing successful login for both username/password and RSA shared key:
Feb 14 22:48:38 nostromo sshd[10679]: Accepted password for george from 10.3.3.214 port 42940 ssh2
Feb 14 22:48:38 nostromo sshd[10679]: pam_unix(sshd:session): session opened for user george by (uid=0)
Feb 14 22:55:55 nostromo sshd[13676]: Accepted publickey for george from 10.3.3.214 port 42948 ssh2: RSA e7:a0:d3:a6:0b:bb:f1:f9:21:f4:2b:65:f1:47:26:74
Feb 14 22:55:55 nostromo sshd[13676]: pam_unix(sshd:session): session opened for user george by (uid=0)
The spinning circle should become a green success circle after the login succeeds.
The spinning circle spins forever, and browsing to oC “Files” also shows a forever spinning circle. The only way to restore normal functionality is to delete the SFTP external storage.
Operating system: CentOS 7.3
Web server: Apache 2.4
Database: MariaDB 5.5.52
PHP version: 5.5.21
Updated from an older ownCloud or fresh install: updated from 9.1.3
There are no new lines written to owncloud.log during this activity.
Integrity status for oC9+
paste the results here.
Without matching logfiles its probably not possible to help here. You might want to create a bugreport to the developers about that at GitHub · Where software is built
