Hello, I've just upgraded OC from version 9.0.4 to 9.1. After manually running the oc command to upgrade and turn off the maintenance mode, I logged into the web interface. When I did this I noticed a code integrity check alert. When I checked what files where in question I found that I had created a phpinfo.php file when troubleshooting an previous issue. So I deleted the file and rescanned. Now it still reporting an issue but when I check the list of invalid files I only see the following.
Technical information
them.
Results
- tasks
- EXCEPTION
- OC\IntegrityCheck\Exceptions\InvalidSignatureException
- Certificate has been revoked.
- EXCEPTION
Raw output
Array
[tasks] => Array
[EXCEPTION] => Array
[class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException
[message] => Certificate has been revoked.
I'm not sure what this is having an issue with. This is a pretty simple generic install using debian package management tools to install the deb file.
Any ideas how to figure out what is causing this alert in the code integrity checking process?
