Client should silently sync
Client sync's but asks for known password every 1-2 minutes, the dialog for the specified account is shown and the password is already typed in, so I need to press "ok" every 1-2 minutes.
- Use self-signed SSL certificate for the https connection
- Connect the client via https, not http
ownCloud version:
version 10.0.7.2
edition Community
Client version:
Version 2.4.0 (build 8836)
Mac OS X Sierra
OS language: German
Installation path of client:
logs.
- Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
"SSL-Errors happened for url \"https://myowncloudurl/status.php\" \tError in QSslCertificate(...), QMap(), QDateTime(2018-03-03 10:12:10.000 UTC Qt::TimeSpec(UTC)), QDateTime(2019-03-03 10:12:10.000 UTC Qt::TimeSpec(UTC))) : \"Das Zertifikat ist selbstsigniert und daher nicht vertrauenswürdig\" ( \"Das Zertifikat ist selbstsigniert und daher nicht vertrauenswürdig\" ) \n " Certs are known and trusted! This is not an actual error.
Web server error log:
