Preparando la actualización
Establecer el nivel de registro a depuración
Modo mantenimiento activado
Advertencia de reparación:You have incompatible or missing apps enabled that could not be found or updated via the marketplace.
Advertencia de reparación:Please install or update the following apps manually or disable them with: occ app:disable activity occ app:disable files_pdfviewer occ app:disable files_texteditor occ app:disable gallery occ app:disable templateeditor
Advertencia de reparación:For manually updating, see https://doc.owncloud.org/server/10.0/go.php?to=admin-marketplace-apps
have you tried what is suggested in the error message?
