I'm using OC for a couple of years, server setup on my Raspberry pi (raspbian jessie) for family use. It's worked almost without fault so when it failed today I had to re-read the OC 9 manual to remember the admin basics like occ commands.
I googled around and found some similar errors but no resolutions, anhow my initial issue is I cannot get to any debugging without access to occ commands, correct? I'm happy to try debug, provide more info and resolve but need help first in this case.
Thanks in advance.
- OC web reports 'internal server error'
- sudo -u www-data php occ status and all other commands fails with 'unhandled exception error
- tried reboots, check mysql access and apache all seem OK
first major failure of OC. no recent upgrades or changes made.
I though the occ command might allow a safemode access
all attempt to debug via web and occ fail with 'unhandles exception' error like this:
exception 'OCP\AppFramework\QueryException' with message 'Could not resolve OCA\Files_External\Lib\Backend\FTP! Class OCA\Files_External\Lib\Auth\Password\Password does not exist' in /var/www/html/owncloud/lib/private/appframework/utility/simplecontainer.php:89
Stack trace:
0 /var/www/html/owncloud/lib/private/appframework/utility/simplecontainer.php(104): OC\AppFramework\Utility\SimpleContainer->resolve('OCA\Files_Exter...')
1 /var/www/html/owncloud/apps/files_external/appinfo/application.php(74): OC\AppFramework\Utility\SimpleContainer->query('OCA\Files_Exter...')
2 /var/www/html/owncloud/apps/files_external/appinfo/application.php(45): OCA\Files_External\AppInfo\Application->loadBackends()
3 /var/www/html/owncloud/apps/files_external/appinfo/app.php(44): OCA\Files_External\AppInfo\Application->__construct()
4 /var/www/html/owncloud/lib/private/app.php(163): require_once('/var/www/html/o...')
5 /var/www/html/owncloud/lib/private/app.php(144): OC_App::requireAppFile('files_external')
6 /var/www/html/owncloud/lib/private/app.php(117): OC_App::loadApp('files_external')
7 /var/www/html/owncloud/lib/private/console/application.php(95): OC_App::loadApps()
8 /var/www/html/owncloud/console.php(87): OC\Console\Application->loadCommands(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
9 /var/www/html/owncloud/occ(11): require_once('/var/www/html/o...')
10 {main}
OC 9 with raspbian jessie on apache and mariaDB
apache
mariaDB 10
php 5.6
OC 9
updated several times over couple of years
forgot would have been download and install from website
I'm the admin and user
I cannot login.
withheld sensitive
I cannot login
cannot run occ, same error produced
yes, smb and nfs folders
no
not sure
SELECT * FROM oc_appconfig
WHERE appid
= 'user_ldap';
### Client configuration
**Browser:**
IE, Firefox, chrome all same error
**Operating system:**
Ubuntu 17.4, android - same error
### Logs
#### Web server error log
nsert your webserver log here
