Hi all,
I am running OC (2.7.6 - 3261) client on Windows (v20H2- 19042.985) and the connected OC server is running 10.7.0 (on Linux).
I have configured a directory to sync and it really runs fine so far.
Now I have the following:
I create a new file (ie an image *.png) and edit it (with mspaint). OC client can not sync because the file is locked. That’s fine so far. Now I am done with editig, the new file is safed and no lock should be there.
I expect OC client trying to sync the file on the next invocation so it gets synced to the server. Instead OC client does never touch the file again and it will stay unsinchronized. Additionall,y I can find the file in the “Activity” tab as “not synchronized”.
Same happens for all files which are locked during an attempt to sync them.
So any new files doe not get synchronized and any edited ones either not.
I expect this is not how it should work.
Her’s the part of the logfile where the file occured the first time:
05-20 11:03:57:877 [ info sync.discovery ]: Not a move, no item in db with inode 69651
05-20 11:03:57:877 [ info sync.discovery ]: Discovered "Arbeitszeugnis Peggy.odt" CSyncEnums::CSYNC_INSTRUCTION_NEW OCC::SyncFileItem::Up CSyncEnums::ItemTypeFile
05-20 11:03:57:877 [ info sync.engine ]: Item is on blacklist: "Arbeitszeugnis Peggy.odt" retries: 8 for another 2283 s
05-20 11:03:58:762 [ info gui.socketapi ]: Sending SocketAPI message --> "STATUS:ERROR:C:\\Users\\chvoelker\\Documents\\Arbeitszeugnis Peggy.odt" to QLocalSocket(0x260c0b6c990)
05-20 11:04:00:763 [ info sync.propagator ]: Starting CSyncEnums::CSYNC_INSTRUCTION_IGNORE propagation of "Arbeitszeugnis Peggy.odt" by OCC::PropagateIgnoreJob(0x260c47e87b0)
05-20 11:04:00:763 [ warning sync.propagator ]: Could not complete propagation of "Arbeitszeugnis Peggy.odt" by OCC::PropagateIgnoreJob(0x260c47e87b0) with status OCC::SyncFileItem::BlacklistedError and error: "Server hat \"403 Forbidden\" auf \"PUT https://owncloud.knebb.de/remote.php/dav/files/cvoelker/Doks/Arbeitszeugnis Peggy.odt\" geantwortet (Sabre\\DAV\\Exception\\Forbidden) (Übersprungen aufgrund des früheren Fehlers, erneuter Versuch in 38 Minuten)"
Well, it writes “retry in 38Minutes”. But it does not. It might retry but will fail because on “blacklist”- which blacklist? I do not have excluded the file!
Is this a bug? Can someone confirm?
Thanks!
/KNEBB
Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
