- Install v 10.5 via Docker
- Log in to docker image as www-data
- Try to run php occ
It should not error
www-data@aeba32fff501: ~/owncloud # php occ
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'owncloud.appconfig' doesn't exist in /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:78
Stack trace:
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php(78): PDO->query()
#1 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(911): Doctrine\DBAL\Driver\PDOConnection->query()
#2 /var/www/owncloud/lib/private/DB/Connection.php(187): Doctrine\DBAL\Connection->executeQuery()
#3 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery()
#4 /var/www/owncloud/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/owncloud/lib/private/AppConfig.php(301): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/owncloud/lib/private/AppConfig.php(80): OC\AppConfig->loadConfigValues()
#7 /var/www/owncloud/lib/private/AppConfig.php(278): OC\AppConfig->getApps()
#8 /var/www/owncloud/lib/private/legacy/app.php(957): OC\AppConfig->getValues()
#9 /var/www/owncloud/lib/private/Server.php(444): OC_App::getAppVersions()
#10 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#11 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet()
#12 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query()
#13 /var/www/owncloud/lib/private/Server.php(1223): OC\ServerContainer->query()
#14 /var/www/owncloud/lib/private/Server.php(603): OC\Server->getMemCacheFactory()
#15 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#16 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet()
#17 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query()
#18 /var/www/owncloud/lib/private/Server.php(1439): OC\ServerContainer->query()
#19 /var/www/owncloud/lib/private/legacy/app.php(343): OC\Server->getAppManager()
#20 /var/www/owncloud/lib/private/legacy/app.php(107): OC_App::getEnabledApps()
#21 /var/www/owncloud/lib/base.php(585): OC_App::loadApps()
#22 /var/www/owncloud/lib/base.php(1059): OC::init()
#23 /var/www/owncloud/console.php(74): require_once('/var/www/ownclo...')
#24 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
#25 {main}
Next Doctrine\DBAL\Driver\PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'owncloud.appconfig' doesn't exist in /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:83
Stack trace:
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(911): Doctrine\DBAL\Driver\PDOConnection->query()
#1 /var/www/owncloud/lib/private/DB/Connection.php(187): Doctrine\DBAL\Connection->executeQuery()
#2 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery()
#3 /var/www/owncloud/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()
#4 /var/www/owncloud/lib/private/AppConfig.php(301): OC\DB\QueryBuilder\QueryBuilder->execute()
#5 /var/www/owncloud/lib/private/AppConfig.php(80): OC\AppConfig->loadConfigValues()
#6 /var/www/owncloud/lib/private/AppConfig.php(278): OC\AppConfig->getApps()
#7 /var/www/owncloud/lib/private/legacy/app.php(957): OC\AppConfig->getValues()
#8 /var/www/owncloud/lib/private/Server.php(444): OC_App::getAppVersions()
#9 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#10 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet()
#11 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query()
#12 /var/www/owncloud/lib/private/Server.php(1223): OC\ServerContainer->query()
#13 /var/www/owncloud/lib/private/Server.php(603): OC\Server->getMemCacheFactory()
#14 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#15 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet()
#16 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query()
#17 /var/www/owncloud/lib/private/Server.php(1439): OC\ServerContainer->query()
#18 /var/www/owncloud/lib/private/legacy/app.php(343): OC\Server->getAppManager()
#19 /var/www/owncloud/lib/private/legacy/app.php(107): OC_App::getEnabledApps()
#20 /var/www/owncloud/lib/base.php(585): OC_App::loadApps()
#21 /var/www/owncloud/lib/base.php(1059): OC::init()
#22 /var/www/owncloud/console.php(74): require_once('/var/www/ownclo...')
#23 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
#24 {main}
**Next Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing 'SELECT * FROM `appconfig`':**
SQLSTATE[42S02]: Base table or view not found: 1146 Table 'owncloud.appconfig' doesn't exist in /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractMySQLDriver.php:42
Stack trace:
#0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(169): Doctrine\DBAL\Driver\AbstractMySQLDriver->convertException()
#1 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php(149): Doctrine\DBAL\DBALException::wrapException()
#2 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(914): Doctrine\DBAL\DBALException::driverExceptionDuringQuery()
#3 /var/www/owncloud/lib/private/DB/Connection.php(187): Doctrine\DBAL\Connection->executeQuery()
#4 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php(206): OC\DB\Connection->executeQuery()
#5 /var/www/owncloud/lib/private/DB/QueryBuilder/QueryBuilder.php(141): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/owncloud/lib/private/AppConfig.php(301): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/owncloud/lib/private/AppConfig.php(80): OC\AppConfig->loadConfigValues()
#8 /var/www/owncloud/lib/private/AppConfig.php(278): OC\AppConfig->getApps()
#9 /var/www/owncloud/lib/private/legacy/app.php(957): OC\AppConfig->getValues()
#10 /var/www/owncloud/lib/private/Server.php(444): OC_App::getAppVersions()
#11 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#12 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet()
#13 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query()
#14 /var/www/owncloud/lib/private/Server.php(1223): OC\ServerContainer->query()
#15 /var/www/owncloud/lib/private/Server.php(603): OC\Server->getMemCacheFactory()
#16 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}()
#17 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet()
#18 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query()
#19 /var/www/owncloud/lib/private/Server.php(1439): OC\ServerContainer->query()
#20 /var/www/owncloud/lib/private/legacy/app.php(343): OC\Server->getAppManager()
#21 /var/www/owncloud/lib/private/legacy/app.php(107): OC_App::getEnabledApps()
#22 /var/www/owncloud/lib/base.php(585): OC_App::loadApps()
#23 /var/www/owncloud/lib/base.php(1059): OC::init()
#24 /var/www/owncloud/console.php(74): require_once('/var/www/ownclo...')
#25 /var/www/owncloud/occ(11): require_once('/var/www/ownclo...')
#26 {main}
Operating system: Ubuntu 20.04
Database: MySQL 5.7 - tried MariaDB:latest as well
PHP version: Docker
ownCloud version: 10.5.0 (stable)
Where did you install ownCloud from: docker
results of integrity/failed
List of activated apps: none
Are you using encryption: no
