Hello everyone,
I’m installing an OwnCloud 10.1.0 with MySQL and SSL required. The OwnCloud installation process fails directly when I enforce SSL for MySQL.
- Configure MySQL to force SSL connections (require_secure_transport = ON), generate certificates and all.
- Get the latest version of OwnCloud, as of now it’s 10.1.0
- Modify config.php to tell the driver the certificates’ location
<?php
$CONFIG = array (
'dbdriveroptions' => array(
PDO::MYSQL_ATTR_SSL_KEY =>'/etc/xxx',
PDO::MYSQL_ATTR_SSL_CERT =>'/etc/xxx',
PDO::MYSQL_ATTR_SSL_CA => '/etc/xxx',
PDO::MYSQL_ATTR_SSL_VERIFY_SERVER_CERT => false,
- Use occ to install
occ maintenance:install \
--database "mysql" --database-name "db_name" --database-host=127.0.0.1 \
--database-user "user" --database-pass "password" \
--admin-user "user" --admin-pass "password"
The installation fails because occ maintenance:install modifies the config.php turning this part:
to
1007 => '/etc/xxx',
1008 => '/etc/xxx',
1009 => '/etc/xxx',
1014 => false,
If I do the installation without enforcing SSL for MysQL, and that I define the dbdriveroptions after, everything works fine. So 'im quite certain that occ maintenance:install is the problem.
It shouldn’t modify the dbdriveroptions setting in config.php, instead it should rather use it to connect to MySQL in a secure way and do the installation.
Operating system: Devuan 2.0
Web server: NGinx 1.14.2
Database: Percona MySQL 5.7.25
PHP version: PHP7.2
ownCloud version: 10.1.0
Updated from an older ownCloud or fresh install: fresh install.
Downloaded the tar.gz and installed with occ maintenance.
It’s fine.
I’d like to keep enforcing SSL for MySQL, but for now I have to do the installation without it and enable it after.
Thanks.
