OCC Problem with Ldap
Hello i have a owncloud server Version 9.1.5 (stable), based on ubuntu.
It works fine and i authenticate the users via LDAP attached to a windows active directory and everything works fine.
I need to delete the files older than 7 days, i know there is not such a feature so i created the following script:
!/bin/bash
Erase files older than 7 day in my data directory and mantain folders:
/usr/bin/find /owncloud/owncloud/data/*/files/ -mtime +7 -exec rm {} \;
rescan filesystem:
/usr/bin/sudo -u www-data php /owncloud/owncloud/occ files:scan "--all"
1.Run the command : /usr/bin/sudo -u www-data php /owncloud/owncloud/occ files:scan "--all"
As from doumentation it is supposed to rescan all the file user and update the db removing the deleted files.
Actually when i run it :
[OC\ServerNotAvailableException]
Connection to LDAP server could not be established
files:scan [--output [OUTPUT]] [-p|--path PATH] [-q|--quiet] [-v|vv|vvv|--verbose] [--all] [--unscanned] [--] []...
Operating system:Ubuntu 14.04.5 LTS
Web server:Apache/2.4.7 (Ubuntu) PHP/5.5.9-1ubuntu4.21 OpenSSL/1.0.1f
Database:mysql
ownCloud version: (see ownCloud admin page)9.1.5
Updated from an older ownCloud or fresh install:fresh install
Nobody could help with this?
Domenico
Probably the connection to the LDAP server is lost during the file scan.
I'd recommend you to access through the webdav interface even though the process will likely be more expensive and time consuming, but it will be cleaner. Removing the files directly from the data folder isn't supported (do it at your own risk), and the files:scan is intended to be a fixer for some issues but it wasn't planned to be executed on purpose like that.
In any case, the files:scan support an user_id to be passed as parameter to scan only that user's folder. The simple fix is to get a list of user_ids you want to scan and go one by one instead of scanning all at once.
