Im trying to upgrade my server from 9.01 to 9.1 and I cannot finish it because the occ command does not seem to work
This is my first upgrade and I am following the infos from the online manual https://doc.owncloud.org/server/9.1/admin_manual/maintenance/package_upgrade.html
thank you
1. try to use sudo -u www-data php occ upgrade
upgrade
bash: -u: command not found
Operating system: debian 8.4
Web server: 9.1
Database: MySQL latest
PHP version: latest
Updated from an older ownCloud or fresh install: in the process of upgrading from 9.01 to 9.1
Here is a paste of my console output:
total 192
root@aas:/var/www/owncloud# ls -l
total 192
drwxr-xr-x 29 root root 4096 Oct 11 22:08 3rdparty
drwxr-xr-x 28 www-data www-data 4096 Oct 11 22:07 apps
drwxr-xr-x 2 www-data www-data 4096 Apr 7 2016 assets
-rw-r--r-- 1 root root 8301 Sep 19 18:04 AUTHORS
drwxrwxr-x 2 www-data www-data 4096 Oct 11 22:08 config
-rw-r--r-- 1 root root 3805 Sep 19 18:04 console.php
-rw-r--r-- 1 root root 34520 Sep 19 18:04 COPYING-AGPL
drwxr-xr-x 17 root root 4096 Oct 11 22:08 core
-rw-r--r-- 1 root root 5080 Sep 19 18:04 cron.php
drwxrwx--- 7 www-data www-data 4096 Oct 4 04:20 data
-rw-r--r-- 1 root root 35830 Sep 19 18:04 db_structure.xml
drwxr-xr-x 2 root root 4096 Apr 7 2016 etc
-rw-r--r-- 1 root root 179 Sep 19 18:04 index.html
-rw-r--r-- 1 root root 2282 Sep 19 18:04 index.php
drwxr-xr-x 3 root root 4096 Oct 11 22:08 l10n
drwxr-xr-x 6 root root 4096 Oct 11 22:08 lib
-rwxr-xr-x 1 root root 283 Sep 19 18:04 occ
drwxr-xr-x 2 root root 4096 Oct 11 22:08 ocs
drwxr-xr-x 2 root root 4096 Oct 11 22:08 ocs-provider
-rw-r--r-- 1 root root 3086 Sep 19 18:04 public.php
-rw-r--r-- 1 root root 5428 Sep 19 18:04 remote.php
drwxr-xr-x 4 root root 4096 Apr 15 12:56 resources
-rw-r--r-- 1 root root 26 Sep 19 18:04 robots.txt
drwxr-xr-x 12 root root 4096 Oct 11 22:08 settings
-rw-r--r-- 1 root root 1893 Sep 19 18:04 status.php
drwxr-xr-x 4 www-data www-data 4096 Oct 11 22:08 themes
drwxr-xr-x 7 root root 4096 Oct 11 22:08 updater
-rw-r--r-- 1 root root 233 Sep 19 18:05 version.php
root@snz:/var/www/owncloud# -u www-data php occ upgrade
