OCC won't work at all
  1. Running Owncloud 10.0.2.1 on Ubuntu Server 16.04 64bits. Everything is fine except the OCC command.
  2. The command: “sudo -u www-data php /var/www/html/owncloud/occ status” always gives the same result:
    root@nsxxxyyy:~# sudo -u www-data php /var/www/html/owncloud/occ status
    Error: Call to undefined function OC\DB\ctype_digit() in /var/www/html/owncloud/lib/private/DB/ConnectionFactory.php:184
    Stack trace:
    #0 /var/www/html/owncloud/lib/private/Server.php(463): OC\DB\ConnectionFactory->createConnectionParams()
    #1 /var/www/html/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
    #2 /var/www/html/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘DatabaseConnect…’)
    #3 /var/www/html/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘DatabaseConnect…’)
    #4 /var/www/html/owncloud/lib/private/Server.php(1111): OC\ServerContainer->query(‘DatabaseConnect…’)
    #5 /var/www/html/owncloud/lib/private/Server.php(342): OC\Server->getDatabaseConnection()
    #6 /var/www/html/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
    #7 /var/www/html/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘AppConfig’)
    #8 /var/www/html/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘AppConfig’)
    #9 /var/www/html/owncloud/lib/private/Server.php(1040): OC\ServerContainer->query(‘AppConfig’)
    10 /var/www/html/owncloud/lib/private/legacy/app.php(1044): OC\Server->getAppConfig()
    #11 /var/www/html/owncloud/lib/private/Server.php(372): OC_App::getAppVersions()
    #12 /var/www/html/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(113): OC\Server->OC{closure}(Object(OC\Server))
    #13 /var/www/html/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(111): Pimple\Container->offsetGet(‘MemCacheFactory’)
    #14 /var/www/html/owncloud/lib/private/ServerContainer.php(87): OC\AppFramework\Utility\SimpleContainer->query(‘MemCacheFactory’)
    #15 /var/www/html/owncloud/lib/private/Server.php(1092): OC\ServerContainer->query(‘MemCacheFactory’)
    #16 /var/www/html/owncloud/lib/base.php(821): OC\Server->getMemCacheFactory()
    #17 /var/www/html/owncloud/lib/base.php(560): OC::registerAutoloaderCache()
    #18 /var/www/html/owncloud/lib/base.php(1003): OC::init()
    #19 /var/www/html/owncloud/console.php(57): require_once(‘/var/www/html/o…’)
    #20 /var/www/html/owncloud/occ(11): require_once(‘/var/www/html/o…’)
    #21 {main}root@nsxxxyyy:~#
Ubuntu Server 64bits 16.04
Apache 2.4.18
MariaDB 10.0.29
php 7.0.18
10.0.2.1
restored from my backups after a server crash. I wrote a dirty script in order to rebuild and restore the initial configuration with settings and datas
I downloaded owncloud-10.0.2.zip from owncloud.org site.
<?php $CONFIG = array ( 'instanceid' => 'ocukfdee23wsvu', 'passwordsalt' => 'ModifiedEb3asqUjFDZSkkq5yjjqhZ', 'secret' => 'Modified2ZSi0MIAGgbF4DhosdfAFgkGYGzVgghGfkgVYsI455yG5D', 'trusted_domains' => array ( 0 => 'www.xxxx.ggggggg.cc', ), 'datadirectory' => '/datas/owncloud-datas', 'overwrite.cli.url' => 'https://www.xxxx.ggggggg.cc/owncloud', 'dbtype' => 'mysql', 'version' => '10.0.2.1', 'dbname' => 'ownclouddatabase', 'dbhost' => 'localhost:3306', 'dbtableprefix' => 'oc_', 'dbuser' => 'owdbadmin', 'dbpassword' => 'xxxxxxxxxxxxxxxxxxxxyyyy', 'logtimezone' => 'Europe/Paris', 'installed' => true, 'filelocking.enabled' => true, 'memcache.local' => '\\OC\\Memcache\\Redis', 'memcache.locking' => '\\OC\\Memcache\\Redis', 'redis' => array ( 'host' => 'localhost', 'port' => 6379, 'timeout' => 0.0, 'password' => 'VeryLongPassword', ), 'mail_smtpmode' => 'smtp', 'mail_smtpsecure' => 'tls', 'mail_from_address' => 'FirstName.LastName@free.fr', 'mail_domain' => 'free.fr', 'mail_smtpauthtype' => 'LOGIN', 'mail_smtpauth' => 1, 'mail_smtphost' => 'smtp.free.fr', 'mail_smtpport' => '587', 'mail_smtpname' => 'FirstName.LastName', 'mail_smtppassword' => 'LongPassword', 'default_language' => 'fr', 'defaultapp' => 'files', 'enable_avatars' => true, 'allow_user_to_change_display_name' => false, 'remember_login_cookie_lifetime' => 1296000, 'session_lifetime' => 86400, 'updatechecker' => true, 'has_internet_connection' => true, 'check_for_working_webdav' => true, 'check_for_working_htaccess' => true, 'log_type' => 'owncloud', 'logfile' => '/var/log/owncloud.log', 'loglevel' => 2, 'log_rotate_size' => 52428800, 'enable_previews' => true, 'preview_max_x' => 2048, 'preview_max_y' => 2048, 'preview_max_scale_factor' => 10, 'maintenance' => false, ); ``` **Are you using external storage, No **Are you using encryption:** yes **Are you using an external user-backend, No
did you try to googe for this error message?
you are missing a php extention - see PHP: Installation - Manual
maybe you need to install an additional package?
Thank you for your answer.
Yes, I googled the error messages, but did not find out anything useful.
Indeed, it looks like a PHP package could be missing, but I did not find anything useful either.
Below, the list of the PHP installed packages:
ii libapache2-mod-php7.0 7.0.18-0ubuntu0.16.04.1 amd64 server-side, HTML-embedded scripting language (Apache 2 module)
ii php-common 1:35ubuntu6 all Common files for PHP packages
ii php-igbinary 1.2.1-10-ge0e66b9+1.2.1-2 amd64 igbinary PHP serializer
ii php-imagick 3.4.0~rc6-1ubuntu3 amd64 Provides a wrapper to the ImageMagick library
ii php-redis 2.2.7-389-g2887ad1+2.2.7-1 amd64 PHP extension for interfacing with Redis
ii php7.0-bz2 7.0.18-0ubuntu0.16.04.1 amd64 bzip2 module for PHP
ii php7.0-cli 7.0.18-0ubuntu0.16.04.1 amd64 command-line interpreter for the PHP scripting language
ii php7.0-common 7.0.18-0ubuntu0.16.04.1 amd64 documentation, examples and common module for PHP
ii php7.0-curl 7.0.18-0ubuntu0.16.04.1 amd64 CURL module for PHP
ii php7.0-gd 7.0.18-0ubuntu0.16.04.1 amd64 GD module for PHP
ii php7.0-intl 7.0.18-0ubuntu0.16.04.1 amd64 Internationalisation module for PHP
ii php7.0-json 7.0.18-0ubuntu0.16.04.1 amd64 JSON module for PHP
ii php7.0-mbstring 7.0.18-0ubuntu0.16.04.1 amd64 MBSTRING module for PHP
ii php7.0-mcrypt 7.0.18-0ubuntu0.16.04.1 amd64 libmcrypt module for PHP
ii php7.0-mysql 7.0.18-0ubuntu0.16.04.1 amd64 MySQL module for PHP
ii php7.0-opcache 7.0.18-0ubuntu0.16.04.1 amd64 Zend OpCache module for PHP
ii php7.0-readline 7.0.18-0ubuntu0.16.04.1 amd64 readline module for PHP
ii php7.0-xml 7.0.18-0ubuntu0.16.04.1 amd64 DOM, SimpleXML, WDDX, XML, and XSL module for PHP
ii php7.0-zip
The command:
apt-cache search ctype
lists only one PHP package:
php7.0-common.
please run php -m and php --info and paste the output
php -m
[PHP Modules]
bz2
calendar
Core
ctype
curl
date
dom
exif
fileinfo
filter
ftp
gd
gettext
hash
iconv
igbinary
imagick
intl
json
libxml
mbstring
mcrypt
mysqli
mysqlnd
openssl
pcntl
pcre
PDO
pdo_mysql
Phar
posix
readline
redis
Reflection
session
shmop
SimpleXML
sockets
SPL
standard
sysvmsg
sysvsem
sysvshm
tokenizer
wddx
xml
xmlreader
xmlwriter
xsl
Zend OPcache
zip
zlib
[Zend Modules]
Zend OPcache
php --info
phpinfo()
PHP Version => 7.0.18-0ubuntu0.16.04.1
System => Linux nsabcdef.ip-x-yy-zz.eu 4.4.0-87-generic #110-Ubuntu SMP Tue Jul 18 12:55:35 UTC 2017 x86_64
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /etc/php/7.0/cli
Loaded Configuration File => /etc/php/7.0/cli/php.ini
Scan this dir for additional .ini files => /etc/php/7.0/cli/conf.d
Additional .ini files parsed => /etc/php/7.0/cli/conf.d/10-mysqlnd.ini,
/etc/php/7.0/cli/conf.d/10-opcache.ini,
/etc/php/7.0/cli/conf.d/10-pdo.ini,
/etc/php/7.0/cli/conf.d/15-xml.ini,
/etc/php/7.0/cli/conf.d/20-bz2.ini,
/etc/php/7.0/cli/conf.d/20-calendar.ini,
/etc/php/7.0/cli/conf.d/20-ctype.ini,
/etc/php/7.0/cli/conf.d/20-curl.ini,
/etc/php/7.0/cli/conf.d/20-dom.ini,
/etc/php/7.0/cli/conf.d/20-exif.ini,
/etc/php/7.0/cli/conf.d/20-fileinfo.ini,
/etc/php/7.0/cli/conf.d/20-ftp.ini,
/etc/php/7.0/cli/conf.d/20-gd.ini,
/etc/php/7.0/cli/conf.d/20-gettext.ini,
/etc/php/7.0/cli/conf.d/20-iconv.ini,
/etc/php/7.0/cli/conf.d/20-igbinary.ini,
/etc/php/7.0/cli/conf.d/20-imagick.ini,
/etc/php/7.0/cli/conf.d/20-intl.ini,
/etc/php/7.0/cli/conf.d/20-json.ini,
/etc/php/7.0/cli/conf.d/20-mbstring.ini,
/etc/php/7.0/cli/conf.d/20-mcrypt.ini,
/etc/php/7.0/cli/conf.d/20-memcached.ini,
/etc/php/7.0/cli/conf.d/20-mysqli.ini,
/etc/php/7.0/cli/conf.d/20-pdo_mysql.ini,
/etc/php/7.0/cli/conf.d/20-phar.ini,
/etc/php/7.0/cli/conf.d/20-posix.ini,
/etc/php/7.0/cli/conf.d/20-readline.ini,
/etc/php/7.0/cli/conf.d/20-redis.ini,
/etc/php/7.0/cli/conf.d/20-shmop.ini,
/etc/php/7.0/cli/conf.d/20-simplexml.ini,
/etc/php/7.0/cli/conf.d/20-sockets.ini,
/etc/php/7.0/cli/conf.d/20-sysvmsg.ini,
/etc/php/7.0/cli/conf.d/20-sysvsem.ini,
/etc/php/7.0/cli/conf.d/20-sysvshm.ini,
/etc/php/7.0/cli/conf.d/20-tokenizer.ini,
/etc/php/7.0/cli/conf.d/20-wddx.ini,
/etc/php/7.0/cli/conf.d/20-xmlreader.ini,
/etc/php/7.0/cli/conf.d/20-xmlwriter.ini,
/etc/php/7.0/cli/conf.d/20-xsl.ini,
/etc/php/7.0/cli/conf.d/20-zip.ini
PHP API => 20151012
PHP Extension => 20151012
Zend Extension => 320151012
Zend Extension Build => API320151012,NTS
PHP Extension Build => API20151012,NTS
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => disabled
Zend Memory Manager => enabled
Zend Multibyte Support => provided by mbstring
IPv6 Support => enabled
DTrace Support => available, disabled
Registered PHP Streams => https, ftps, compress.zlib, php, file, glob, data, http, ftp, compress.bzip2, phar, zip
Registered Stream Socket Transports => tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2
Registered Stream Filters => zlib., string.rot13, string.toupper, string.tolower, string.strip_tags, convert., consumed, dechunk, bzip2., convert.iconv., mcrypt., mdecrypt.
This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.0.18-0ubuntu0.16.04.1, Copyright (c) 1999-2017, by Zend Technologies
Configuration
bz2
BZip2 Support => Enabled
Stream Wrapper support => compress.bzip2://
Stream Filter support => bzip2.decompress, bzip2.compress
BZip2 Version => 1.0.6, 6-Sept-2010
calendar
Calendar support => enabled
Core
Directive => Local Value => Master Value
allow_url_fopen => On => On
allow_url_include => Off => Off
arg_separator.input => & => &
arg_separator.output => & => &
auto_append_file => no value => no value
auto_globals_jit => On => On
auto_prepend_file => no value => no value
browscap => no value => no value
default_charset => UTF-8 => UTF-8
default_mimetype => text/html => text/html
disable_classes => no value => no value
disable_functions => no value => no value
display_errors => Off => Off
display_startup_errors => Off => Off
doc_root => no value => no value
docref_ext => no value => no value
docref_root => no value => no value
enable_dl => Off => Off
enable_post_data_reading => On => On
error_append_string => no value => no value
error_log => no value => no value
error_prepend_string => no value => no value
error_reporting => 22527 => 22527
exit_on_timeout => Off => Off
expose_php => On => On
extension_dir => /usr/lib/php/20151012 => /usr/lib/php/20151012
file_uploads => On => On
highlight.comment => #FF8000 => #FF8000
highlight.default => #0000BB => #0000BB
highlight.html => #000000 => #000000
highlight.keyword => #007700 => #007700
highlight.string => #DD0000 => #DD0000
html_errors => Off => Off
ignore_repeated_errors => Off => Off
ignore_repeated_source => Off => Off
ignore_user_abort => Off => Off
implicit_flush => On => On
include_path => .:/usr/share/php => .:/usr/share/php
input_encoding => no value => no value
internal_encoding => no value => no value
log_errors => On => On
log_errors_max_len => 1024 => 1024
mail.add_x_header => On => On
mail.force_extra_parameters => no value => no value
mail.log => no value => no value
max_execution_time => 0 => 0
max_file_uploads => 20 => 20
max_input_nesting_level => 64 => 64
max_input_time => -1 => -1
max_input_vars => 1000 => 1000
memory_limit => -1 => -1
open_basedir => no value => no value
output_buffering => 0 => 0
output_encoding => no value => no value
output_handler => no value => no value
post_max_size => 8M => 8M
precision => 14 => 14
realpath_cache_size => 4096K => 4096K
realpath_cache_ttl => 120 => 120
register_argc_argv => On => On
report_memleaks => On => On
report_zend_debug => Off => Off
request_order => GP => GP
sendmail_from => no value => no value
sendmail_path => /usr/sbin/sendmail -t -i => /usr/sbin/sendmail -t -i
serialize_precision => 17 => 17
short_open_tag => Off => Off
SMTP => localhost => localhost
smtp_port => 25 => 25
sql.safe_mode => Off => Off
sys_temp_dir => no value => no value
track_errors => Off => Off
unserialize_callback_func => no value => no value
upload_max_filesize => 2M => 2M
upload_tmp_dir => no value => no value
user_dir => no value => no value
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
variables_order => GPCS => GPCS
xmlrpc_error_number => 0 => 0
xmlrpc_errors => Off => Off
zend.assertions => -1 => -1
zend.detect_unicode => On => On
zend.enable_gc => On => On
zend.multibyte => Off => Off
zend.script_encoding => no value => no value
ctype
ctype functions => enabled
curl
cURL support => enabled
cURL Information => 7.47.0
Age => 3
Features
AsynchDNS => Yes
CharConv => No
Debug => No
GSS-Negotiate => No
IDN => Yes
IPv6 => Yes
krb4 => No
Largefile => Yes
libz => Yes
NTLM => Yes
NTLMWB => Yes
SPNEGO => Yes
SSL => Yes
SSPI => No
TLS-SRP => Yes
HTTP2 => No
GSSAPI => Yes
KERBEROS5 => Yes
UNIX_SOCKETS => Yes
PSL => No
Protocols => dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtmp, rtsp, smb, smbs, smtp, smtps, telnet, tftp
Host => x86_64-pc-linux-gnu
SSL Version => OpenSSL/1.0.2g
ZLib Version => 1.2.8
date
date/time support => enabled
“Olson” Timezone Database Version => 0.system
Timezone Database => internal
Default timezone => Europe/Berlin
date.default_latitude => 31.7667 => 31.7667
date.default_longitude => 35.2333 => 35.2333
date.sunrise_zenith => 90.583333 => 90.583333
date.sunset_zenith => 90.583333 => 90.583333
date.timezone => no value => no value
dom
DOM/XML => enabled
DOM/XML API Version => 20031129
libxml Version => 2.9.3
HTML Support => enabled
XPath Support => enabled
XPointer Support => enabled
Schema Support => enabled
RelaxNG Support => enabled
exif
EXIF Support => enabled
EXIF Version => 1.4 $Id: 8bdc0c8f27c2c9dd1f7551f1f9fe3ab57a06a4b1 $
Supported EXIF Version => 0220
Supported filetypes => JPEG,TIFF
exif.decode_jis_intel => JIS => JIS
exif.decode_jis_motorola => JIS => JIS
exif.decode_unicode_intel => UCS-2LE => UCS-2LE
exif.decode_unicode_motorola => UCS-2BE => UCS-2BE
exif.encode_jis => no value => no value
exif.encode_unicode => ISO-8859-15 => ISO-8859-15
fileinfo
fileinfo support => enabled
version => 1.0.5
libmagic => 522
filter
Input Validation and Filtering => enabled
Revision => $Id: 28fcca4bfda9c9907588a64d245b49cb398249d8 $
filter.default => unsafe_raw => unsafe_raw
filter.default_flags => no value => no value
ftp
FTP support => enabled
FTPS support => enabled
gd
GD Support => enabled
GD headers Version => 2.1.1
GD library Version => 2.1.1
FreeType Support => enabled
FreeType Linkage => with freetype
FreeType Version => 2.6.1
GIF Read Support => enabled
GIF Create Support => enabled
JPEG Support => enabled
libJPEG Version => 8
PNG Support => enabled
libPNG Version => 1.2.54
WBMP Support => enabled
XPM Support => enabled
libXpm Version => 30411
XBM Support => enabled
WebP Support => enabled
gd.jpeg_ignore_warning => 0 => 0
gettext
GetText Support => enabled
hash
hash support => enabled
Hashing Engines => md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support => Enabled
MHASH API Version => Emulated Support
iconv
iconv support => enabled
iconv implementation => glibc
iconv library version => 2.23
iconv.input_encoding => no value => no value
iconv.internal_encoding => no value => no value
iconv.output_encoding => no value => no value
igbinary
igbinary support => enabled
igbinary version => 1.2.2-dev
igbinary APC serializer ABI => no
igbinary session support => no
igbinary.compact_strings => On => On
imagick
imagick module => enabled
imagick module version => 3.4.0RC6
imagick classes => Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, ImagickKernel
Imagick compiled with ImageMagick version => ImageMagick 6.8.9-9 Q16 x86_64 2016-03-14 http://www.imagemagick.org
Imagick using ImageMagick library version => ImageMagick 6.8.9-9 Q16 x86_64 2017-07-21 http://www.imagemagick.org
ImageMagick copyright => Copyright (C) 1999-2014 ImageMagick Studio LLC
ImageMagick release date => 2017-07-21
ImageMagick number of supported formats: => 205
ImageMagick supported formats => 3FR, AAI, AI, ART, ARW, AVI, AVS, BGR, BGRA, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CRW, CUR, CUT, DCM, DCR, DCX, DDS, DFONT, DNG, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, FAX, FITS, FRACTAL, FTS, G3, GIF, GIF87, GRADIENT, GRAY, GROUP4, HALD, HDR, HISTOGRAM, HRZ, HTM, HTML, ICB, ICO, ICON, INFO, INLINE, IPL, ISOBRL, JBG, JBIG, JNG, JNX, JPEG, JPG, JSON, K25, KDC, LABEL, M2V, M4V, MAC, MAP, MASK, MAT, MATTE, MEF, MIFF, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WMV, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV
imagick.locale_fix => 0 => 0
imagick.progress_monitor => 0 => 0
imagick.skip_version_check => 0 => 0
intl
Internationalization support => enabled
version => 1.1.0
ICU version => 55.1
ICU Data version => 55.1
intl.default_locale => no value => no value
intl.error_level => 0 => 0
intl.use_exceptions => 0 => 0
json
json support => enabled
json version => 1.4.0
libxml
libXML support => active
libXML Compiled Version => 2.9.3
libXML Loaded Version => 20903
libXML streams => enabled
mbstring
Multibyte Support => enabled
Multibyte string engine => libmbfl
HTTP input encoding translation => disabled
libmbfl version => 1.3.2
oniguruma version => 5.9.6
mbstring extension makes use of “streamable kanji code filter and converter”, which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support => enabled
Multibyte regex (oniguruma) backtrack check => On
Multibyte regex (oniguruma) version => 5.9.6
mbstring.detect_order => no value => no value
mbstring.encoding_translation => Off => Off
mbstring.func_overload => 0 => 0
mbstring.http_input => no value => no value
mbstring.http_output => no value => no value
mbstring.http_output_conv_mimetypes => ^(text/|application/xhtml+xml) => ^(text/|application/xhtml+xml)
mbstring.internal_encoding => no value => no value
mbstring.language => neutral => neutral
mbstring.strict_detection => Off => Off
mbstring.substitute_character => no value => no value
mcrypt
mcrypt support => enabled
mcrypt_filter support => enabled
Version => 2.5.8
Api No => 20021217
Supported ciphers => cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes => cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dir => no value => no value
mcrypt.modes_dir => no value => no value
mysqli
MysqlI Support => enabled
Client API library version => mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $
Active Persistent Links => 0
Inactive Persistent Links => 0
Active Links => 0
mysqli.allow_local_infile => On => On
mysqli.allow_persistent => On => On
mysqli.default_host => no value => no value
mysqli.default_port => 3306 => 3306
mysqli.default_pw => no value => no value
mysqli.default_socket => no value => no value
mysqli.default_user => no value => no value
mysqli.max_links => Unlimited => Unlimited
mysqli.max_persistent => Unlimited => Unlimited
mysqli.reconnect => Off => Off
mysqli.rollback_on_cached_plink => Off => Off
mysqlnd
mysqlnd => enabled
Version => mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $
Compression => supported
core SSL => supported
extended SSL => supported
Command buffer size => 4096
Read buffer size => 32768
Read timeout => 31536000
Collecting statistics => Yes
Collecting memory statistics => No
Tracing => n/a
Loaded plugins => mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_sha256_password
API Extensions => mysqli,pdo_mysql
mysqlnd statistics =>
bytes_sent => 0
bytes_received => 0
packets_sent => 0
packets_received => 0
protocol_overhead_in => 0
protocol_overhead_out => 0
bytes_received_ok_packet => 0
bytes_received_eof_packet => 0
bytes_received_rset_header_packet => 0
bytes_received_rset_field_meta_packet => 0
bytes_received_rset_row_packet => 0
bytes_received_prepare_response_packet => 0
bytes_received_change_user_packet => 0
packets_sent_command => 0
packets_received_ok => 0
packets_received_eof => 0
packets_received_rset_header => 0
packets_received_rset_field_meta => 0
packets_received_rset_row => 0
packets_received_prepare_response => 0
packets_received_change_user => 0
result_set_queries => 0
non_result_set_queries => 0
no_index_used => 0
bad_index_used => 0
slow_queries => 0
buffered_sets => 0
unbuffered_sets => 0
ps_buffered_sets => 0
ps_unbuffered_sets => 0
flushed_normal_sets => 0
flushed_ps_sets => 0
ps_prepared_never_executed => 0
ps_prepared_once_executed => 0
rows_fetched_from_server_normal => 0
rows_fetched_from_server_ps => 0
rows_buffered_from_client_normal => 0
rows_buffered_from_client_ps => 0
rows_fetched_from_client_normal_buffered => 0
rows_fetched_from_client_normal_unbuffered => 0
rows_fetched_from_client_ps_buffered => 0
rows_fetched_from_client_ps_unbuffered => 0
rows_fetched_from_client_ps_cursor => 0
rows_affected_normal => 0
rows_affected_ps => 0
rows_skipped_normal => 0
rows_skipped_ps => 0
copy_on_write_saved => 0
copy_on_write_performed => 0
command_buffer_too_small => 0
connect_success => 0
connect_failure => 0
connection_reused => 0
reconnect => 0
pconnect_success => 0
active_connections => 0
active_persistent_connections => 0
explicit_close => 0
implicit_close => 0
disconnect_close => 0
in_middle_of_command_close => 0
explicit_free_result => 0
implicit_free_result => 0
explicit_stmt_close => 0
implicit_stmt_close => 0
mem_emalloc_count => 0
mem_emalloc_amount => 0
mem_ecalloc_count => 0
mem_ecalloc_amount => 0
mem_erealloc_count => 0
mem_erealloc_amount => 0
mem_efree_count => 0
mem_efree_amount => 0
mem_malloc_count => 0
mem_malloc_amount => 0
mem_calloc_count => 0
mem_calloc_amount => 0
mem_realloc_count => 0
mem_realloc_amount => 0
mem_free_count => 0
mem_free_amount => 0
mem_estrndup_count => 0
mem_strndup_count => 0
mem_estndup_count => 0
mem_strdup_count => 0
proto_text_fetched_null => 0
proto_text_fetched_bit => 0
proto_text_fetched_tinyint => 0
proto_text_fetched_short => 0
proto_text_fetched_int24 => 0
proto_text_fetched_int => 0
proto_text_fetched_bigint => 0
proto_text_fetched_decimal => 0
proto_text_fetched_float => 0
proto_text_fetched_double => 0
proto_text_fetched_date => 0
proto_text_fetched_year => 0
proto_text_fetched_time => 0
proto_text_fetched_datetime => 0
proto_text_fetched_timestamp => 0
proto_text_fetched_string => 0
proto_text_fetched_blob => 0
proto_text_fetched_enum => 0
proto_text_fetched_set => 0
proto_text_fetched_geometry => 0
proto_text_fetched_other => 0
proto_binary_fetched_null => 0
proto_binary_fetched_bit => 0
proto_binary_fetched_tinyint => 0
proto_binary_fetched_short => 0
proto_binary_fetched_int24 => 0
proto_binary_fetched_int => 0
proto_binary_fetched_bigint => 0
proto_binary_fetched_decimal => 0
proto_binary_fetched_float => 0
proto_binary_fetched_double => 0
proto_binary_fetched_date => 0
proto_binary_fetched_year => 0
proto_binary_fetched_time => 0
proto_binary_fetched_datetime => 0
proto_binary_fetched_timestamp => 0
proto_binary_fetched_string => 0
proto_binary_fetched_json => 0
proto_binary_fetched_blob => 0
proto_binary_fetched_enum => 0
proto_binary_fetched_set => 0
proto_binary_fetched_geometry => 0
proto_binary_fetched_other => 0
init_command_executed_count => 0
init_command_failed_count => 0
com_quit => 0
com_init_db => 0
com_query => 0
com_field_list => 0
com_create_db => 0
com_drop_db => 0
com_refresh => 0
com_shutdown => 0
com_statistics => 0
com_process_info => 0
com_connect => 0
com_process_kill => 0
com_debug => 0
com_ping => 0
com_time => 0
com_delayed_insert => 0
com_change_user => 0
com_binlog_dump => 0
com_table_dump => 0
com_connect_out => 0
com_register_slave => 0
com_stmt_prepare => 0
com_stmt_execute => 0
com_stmt_send_long_data => 0
com_stmt_close => 0
com_stmt_reset => 0
com_stmt_set_option => 0
com_stmt_fetch => 0
com_deamon => 0
bytes_received_real_data_normal => 0
bytes_received_real_data_ps => 0
openssl
OpenSSL support => enabled
OpenSSL Library Version => OpenSSL 1.0.2g 1 Mar 2016
OpenSSL Header Version => OpenSSL 1.0.2g 1 Mar 2016
Openssl default config => /usr/lib/ssl/openssl.cnf
openssl.cafile => no value => no value
openssl.capath => no value => no value
pcntl
pcntl support => enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support => enabled
PCRE Library Version => 8.38 2015-11-23
PCRE JIT Support => enabled
pcre.backtrack_limit => 1000000 => 1000000
pcre.jit => 1 => 1
pcre.recursion_limit => 100000 => 100000
PDO
PDO support => enabled
PDO drivers => mysql
pdo_mysql
PDO Driver for MySQL => enabled
Client API version => mysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $
pdo_mysql.default_socket => /var/run/mysqld/mysqld.sock => /var/run/mysqld/mysqld.sock
Phar
Phar: PHP Archive support => enabled
Phar EXT version => 2.0.2
Phar API version => 1.1.1
SVN revision => $Id: 9d91fd26ae99260111b934cc25174387d4bd7059 $
Phar-based phar archives => enabled
Tar-based phar archives => enabled
ZIP-based phar archives => enabled
gzip compression => enabled
bzip2 compression => enabled
Native OpenSSL support => enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list => no value => no value
phar.readonly => On => On
phar.require_hash => On => On
posix
Revision => $Id: b691ca925e7a085e6929579c4eba8fed0732e0ef $
readline
Readline Support => enabled
Readline library => EditLine wrapper
cli.pager => no value => no value
cli.prompt => \b > => \b >
redis
Redis Support => enabled
Redis Version => 2.2.8-devphp7
Reflection
Reflection => enabled
Version => $Id: 7d703262f14bc65e05ff76fb3714c945f9bf961a $
session
Session Support => enabled
Registered save handlers => files user redis rediscluster redis rediscluster
Registered serializer handlers => php_serialize php php_binary wddx
session.auto_start => Off => Off
session.cache_expire => 180 => 180
session.cache_limiter => nocache => nocache
session.cookie_domain => no value => no value
session.cookie_httponly => Off => Off
session.cookie_lifetime => 0 => 0
session.cookie_path => / => /
session.cookie_secure => Off => Off
session.entropy_file => /dev/urandom => /dev/urandom
session.entropy_length => 32 => 32
session.gc_divisor => 1000 => 1000
session.gc_maxlifetime => 1440 => 1440
session.gc_probability => 0 => 0
session.hash_bits_per_character => 5 => 5
session.hash_function => 0 => 0
session.lazy_write => On => On
session.name => PHPSESSID => PHPSESSID
session.referer_check => no value => no value
session.save_handler => files => files
session.save_path => /var/lib/php/sessions => /var/lib/php/sessions
session.serialize_handler => php => php
session.upload_progress.cleanup => On => On
session.upload_progress.enabled => On => On
session.upload_progress.freq => 1% => 1%
session.upload_progress.min_freq => 1 => 1
session.upload_progress.name => PHP_SESSION_UPLOAD_PROGRESS => PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix => upload_progress_ => upload_progress_
session.use_cookies => On => On
session.use_only_cookies => On => On
session.use_strict_mode => Off => Off
session.use_trans_sid => 0 => 0
shmop
shmop support => enabled
SimpleXML
Simplexml support => enabled
Revision => $Id: b8b5c37931a53e50a937c0aef2a26d351e173215 $
Schema support => enabled
sockets
Sockets Support => enabled
SPL
SPL support => enabled
Interfaces => Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes => AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support => enabled
Path to sendmail => /usr/sbin/sendmail -t -i
assert.active => 1 => 1
assert.bail => 0 => 0
assert.callback => no value => no value
assert.exception => 0 => 0
assert.quiet_eval => 0 => 0
assert.warning => 1 => 1
auto_detect_line_endings => 0 => 0
default_socket_timeout => 60 => 60
url_rewriter.tags => a=href,area=href,frame=src,input=src,form=fakeentry => a=href,area=href,frame=src,input=src,form=fakeentry
user_agent => no value => no value
sysvmsg
sysvmsg support => enabled
Revision => $Id: dfb999763f95bfe9609fae60b4e07a492888ec7c $
sysvsem
sysvshm
tokenizer
Tokenizer Support => enabled
wddx
WDDX Support => enabled
WDDX Session Serializer => enabled
xml
XML Support => active
XML Namespace Support => active
libxml2 Version => 2.9.3
xmlreader
XMLReader => enabled
xmlwriter
XMLWriter => enabled
xsl
XSL => enabled
libxslt Version => 1.1.28
libxslt compiled against libxml Version => 2.9.3
EXSLT => enabled
libexslt Version => 1.1.28
Zend OPcache
Opcode Caching => Disabled
Optimization => Disabled
SHM Cache => Enabled
File Cache => Disabled
Startup Failed => Opcode Caching is disabled for CLI
opcache.blacklist_filename => no value => no value
opcache.consistency_checks => 0 => 0
opcache.dups_fix => Off => Off
opcache.enable => On => On
opcache.enable_cli => Off => Off
opcache.enable_file_override => Off => Off
opcache.error_log => no value => no value
opcache.fast_shutdown => 0 => 0
opcache.file_cache => no value => no value
opcache.file_cache_consistency_checks => 1 => 1
opcache.file_cache_only => 0 => 0
opcache.file_update_protection => 2 => 2
opcache.force_restart_timeout => 180 => 180
opcache.huge_code_pages => Off => Off
opcache.inherited_hack => On => On
opcache.interned_strings_buffer => 4 => 4
opcache.lockfile_path => /tmp => /tmp
opcache.log_verbosity_level => 1 => 1
opcache.max_accelerated_files => 2000 => 2000
opcache.max_file_size => 0 => 0
opcache.max_wasted_percentage => 5 => 5
opcache.memory_consumption => 64 => 64
opcache.optimization_level => 0x7FFFBFFF => 0x7FFFBFFF
opcache.preferred_memory_model => no value => no value
opcache.protect_memory => 0 => 0
opcache.restrict_api => no value => no value
opcache.revalidate_freq => 2 => 2
opcache.revalidate_path => Off => Off
opcache.save_comments => 1 => 1
opcache.use_cwd => On => On
opcache.validate_permission => Off => Off
opcache.validate_root => Off => Off
opcache.validate_timestamps => On => On
zip
Zip => enabled
Zip version => 1.13.5
Libzip version => 1.0.1
zlib
ZLib Support => enabled
Stream Wrapper => compress.zlib://
Stream Filter => zlib.inflate, zlib.deflate
Compiled Version => 1.2.8
Linked Version => 1.2.8
zlib.output_compression => Off => Off
zlib.output_compression_level => -1 => -1
zlib.output_handler => no value => no value
Additional Modules
Module Name
Environment
Variable => Value
TERM => xterm-256color
SHELL => /bin/bash
SSH_CLIENT => AA.BB.CC.DD 32653 22
SSH_TTY => /dev/pts/0
USER => root
LS_COLORS => rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:.tar=01;31:.tgz=01;31:.arc=01;31:.arj=01;31:.taz=01;31:.lha=01;31:.lz4=01;31:.lzh=01;31:.lzma=01;31:.tlz=01;31:.txz=01;31:.tzo=01;31:.t7z=01;31:.zip=01;31:.z=01;31:.Z=01;31:.dz=01;31:.gz=01;31:.lrz=01;31:.lz=01;31:.lzo=01;31:.xz=01;31:.bz2=01;31:.bz=01;31:.tbz=01;31:.tbz2=01;31:.tz=01;31:.deb=01;31:.rpm=01;31:.jar=01;31:.war=01;31:.ear=01;31:.sar=01;31:.rar=01;31:.alz=01;31:.ace=01;31:.zoo=01;31:.cpio=01;31:.7z=01;31:.rz=01;31:.cab=01;31:.jpg=01;35:.jpeg=01;35:.gif=01;35:.bmp=01;35:.pbm=01;35:.pgm=01;35:.ppm=01;35:.tga=01;35:.xbm=01;35:.xpm=01;35:.tif=01;35:.tiff=01;35:.png=01;35:.svg=01;35:.svgz=01;35:.mng=01;35:.pcx=01;35:.mov=01;35:.mpg=01;35:.mpeg=01;35:.m2v=01;35:.mkv=01;35:.webm=01;35:.ogm=01;35:.mp4=01;35:.m4v=01;35:.mp4v=01;35:.vob=01;35:.qt=01;35:.nuv=01;35:.wmv=01;35:.asf=01;35:.rm=01;35:.rmvb=01;35:.flc=01;35:.avi=01;35:.fli=01;35:.flv=01;35:.gl=01;35:.dl=01;35:.xcf=01;35:.xwd=01;35:.yuv=01;35:.cgm=01;35:.emf=01;35:.ogv=01;35:.ogx=01;35:.aac=00;36:.au=00;36:.flac=00;36:.m4a=00;36:.mid=00;36:.midi=00;36:.mka=00;36:.mp3=00;36:.mpc=00;36:.ogg=00;36:.ra=00;36:.wav=00;36:.oga=00;36:.opus=00;36:.spx=00;36:.xspf=00;36:
MAIL => /var/mail/root
PATH => /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
PWD => /root
LANG => fr_FR.UTF-8
SHLVL => 1
HOME => /root
LOGNAME => root
SSH_CONNECTION => AA.BB.CC.DD 32653 XX.YY.ZZ.AA 22
LESSOPEN => | /usr/bin/lesspipe %s
LESSCLOSE => /usr/bin/lesspipe %s %s
_ => /usr/bin/php
PHP Variables
Variable => Value
$_SERVER[‘TERM’] => xterm-256color
$_SERVER[‘SHELL’] => /bin/bash
$_SERVER[‘SSH_CLIENT’] => AA.BB.CC.DD 32653 22
$_SERVER[‘SSH_TTY’] => /dev/pts/0
$_SERVER[‘USER’] => root
$_SERVER[‘LS_COLORS’] => rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:.tar=01;31:.tgz=01;31:.arc=01;31:.arj=01;31:.taz=01;31:.lha=01;31:.lz4=01;31:.lzh=01;31:.lzma=01;31:.tlz=01;31:.txz=01;31:.tzo=01;31:.t7z=01;31:.zip=01;31:.z=01;31:.Z=01;31:.dz=01;31:.gz=01;31:.lrz=01;31:.lz=01;31:.lzo=01;31:.xz=01;31:.bz2=01;31:.bz=01;31:.tbz=01;31:.tbz2=01;31:.tz=01;31:.deb=01;31:.rpm=01;31:.jar=01;31:.war=01;31:.ear=01;31:.sar=01;31:.rar=01;31:.alz=01;31:.ace=01;31:.zoo=01;31:.cpio=01;31:.7z=01;31:.rz=01;31:.cab=01;31:.jpg=01;35:.jpeg=01;35:.gif=01;35:.bmp=01;35:.pbm=01;35:.pgm=01;35:.ppm=01;35:.tga=01;35:.xbm=01;35:.xpm=01;35:.tif=01;35:.tiff=01;35:.png=01;35:.svg=01;35:.svgz=01;35:.mng=01;35:.pcx=01;35:.mov=01;35:.mpg=01;35:.mpeg=01;35:.m2v=01;35:.mkv=01;35:.webm=01;35:.ogm=01;35:.mp4=01;35:.m4v=01;35:.mp4v=01;35:.vob=01;35:.qt=01;35:.nuv=01;35:.wmv=01;35:.asf=01;35:.rm=01;35:.rmvb=01;35:.flc=01;35:.avi=01;35:.fli=01;35:.flv=01;35:.gl=01;35:.dl=01;35:.xcf=01;35:.xwd=01;35:.yuv=01;35:.cgm=01;35:.emf=01;35:.ogv=01;35:.ogx=01;35:.aac=00;36:.au=00;36:.flac=00;36:.m4a=00;36:.mid=00;36:.midi=00;36:.mka=00;36:.mp3=00;36:.mpc=00;36:.ogg=00;36:.ra=00;36:.wav=00;36:.oga=00;36:.opus=00;36:.spx=00;36:.xspf=00;36:
$_SERVER[‘MAIL’] => /var/mail/root
$_SERVER[‘PATH’] => /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
$_SERVER[‘PWD’] => /root
$_SERVER[‘LANG’] => fr_FR.UTF-8
$_SERVER[‘SHLVL’] => 1
$_SERVER[‘HOME’] => /root
$_SERVER[‘LOGNAME’] => root
$_SERVER[‘SSH_CONNECTION’] => AA.BB.CC.DD 32653 XX.YY.ZZ.AA 22
$_SERVER[‘LESSOPEN’] => | /usr/bin/lesspipe %s
$_SERVER[‘LESSCLOSE’] => /usr/bin/lesspipe %s %s
$SERVER[''] => /usr/bin/php
$_SERVER[‘PHP_SELF’] =>
$_SERVER[‘SCRIPT_NAME’] =>
$_SERVER[‘SCRIPT_FILENAME’] =>
$_SERVER[‘PATH_TRANSLATED’] =>
$_SERVER[‘DOCUMENT_ROOT’] =>
$_SERVER[‘REQUEST_TIME_FLOAT’] => 1501175582.7936
$_SERVER[‘REQUEST_TIME’] => 1501175582
$_SERVER[‘argv’] => Array
$_SERVER[‘argc’] => 0
PHP License
hmmm - seems enabled - strange[quote=“IvanClement, post:1, topic:8738”]
[/quote]
please retry this command - but first cd into the folder … just in case
I’ve already tried to cd to the owncloud directory. It doesn’t change anything…
root@nsaabbcc:/var/www/html/owncloud# sudo -u www-data php /var/www/html/owncloud/occ status
Stack trace:
#21 {main}root@nsaabbcc:/var/www/html/owncloud# sudo -u www-data php ./occ status
Stack trace:
#21 {main}root@nsaabbcc:/var/www/html/owncloud# sudo -u www-data php occ status
Stack trace:
Should I give up with this configuration ??
I’m wondering if I should be trying YunoHost…
Does anyone have an idea of why OCC won’t work properly any more ??
I gave up, and I’m reinstalling the server…
According the information we can extract given the commands above ctype is available - no idea why it is missing when executing the code … sorry … I’m out of ideas
Thank you again. But, I gave up, and reinstalled Yunohost, and nextcloud on my server.
