Hello everyone.
Everything worked flawlessly until few weeks ago. Now I can only upload files from within the same subnet of the server.
I can smell it is a network issue, but I don’t understand where I should look…
Server cert is valid, DNS is up…
1.Upload a file remotely, with any client (out from private LAN)
Expected behavior
File uploaded as usual
Actual behavior
When I try to upload it from remote I get the error in the title. But this doesn’t happen if I upload the file from an address inside the same subnet of the server. This does happen with any client
Ubuntu Server 18.10
Apache 2.4.34
MariaDB
10.3.2
No update, no fresh. It just started happening
When I try to generate the config report from remote it gives me network error.
https://cloud.villamoscuzza.com/owncloud/index.php/s/3ZuAgLG5Bsw656c/download
smb
no
no
Any ONLY from outside server subnet
Any
[Fri Sep 18 00:00:01.022329 2020] [mpm_prefork:notice] [pid 13547] AH00163: Apache/2.4.34 (Ubuntu) SVN/1.10.0 OpenSSL/1.1.1 configured -- resuming normal operations
[Fri Sep 18 00:00:01.022349 2020] [core:notice] [pid 13547] AH00094: Command line: '/usr/sbin/apache2'
[Fri Sep 18 13:31:05.196106 2020] [mpm_prefork:notice] [pid 13547] AH00169: caught SIGTERM, shutting down
[Fri Sep 18 13:31:44.899579 2020] [so:warn] [pid 1193] AH01574: module dav_module is already loaded, skipping
[Fri Sep 18 13:31:45.172740 2020] [mpm_prefork:notice] [pid 1288] AH00163: Apache/2.4.34 (Ubuntu) SVN/1.10.0 OpenSSL/1.1.1 configured -- resuming normal operations
[Fri Sep 18 13:31:45.172773 2020] [core:notice] [pid 1288] AH00094: Command line: '/usr/sbin/apache2'
File contains normal operations and no log is generated when I upload a file successfully or unsuccessfully
