Ocis 7.x.x. keycloak authentication suddenly failed
I hvae installed ocis with keycloak 7.x.x. as per https: //owncloud.dev/ocis/deployment/ocis_keycloak/ using the default docker compose.yml giving on github. all had been working fine for a long time, this month the login suddenly broke. after entering the login credentials into the keycloak prompt ocis just displays: Not logged in
This could be because of a routine safety log out, or because your account is either inactive or not yet authorized for use. Please try logging in after a while or seek help from your Administrator.
Nothing had been changed. Trafik acme certificates are up to date. URL is hosted at cloudflare. Any help how to debug would be appreciated.
Check if the internal IDM certificate has expired. It is in the idm directory. If this is true you can simple delete the certificate to regenerate it.
Problem solved, topic can be closed. Issue were corrupt ldap.crt ldap.key files in the idm folder
