Dear all,
I’d like to test owncloud-is version 8.1 in a virtual machine
almalinux 9.8 with 32GB of RAM, 4 cores, a 50GB root disk, and
a 1.3TB disk for owncloud-is data (/owncloud).
I need help creating a test instance that is integrated with LDAP and
uses Nginx as a proxy for web access.
I ran a first test using ocis --init and setting some variables in the ocis.env
OCIS_URL=https://a.b.c.d
# Logging
OCIS_LOG_LEVEL=info
# Configurazione
OCIS_CONFIG_DIR=/etc/ocis
# Metadata interni
OCIS_BASE_DATA_PATH=/owncloud/ocis/metadata
# Storage utenti
STORAGE_USERS_DRIVER=posix
STORAGE_USERS_POSIX_ROOT=/owncloud/ocis/data
#SECRET
OCIS_JWT_SECRET=
OCIS_TRANSFER_SECRET=
OCIS_SYSTEM_USER_API_KEY=
OCIS_MACHINEAUTH_API_KEY=
# Reverse proxy HTTPS
PROXY_TLS=false
PROXY_HTTP_ADDR=0.0.0.0:9200
#OCIS_EXCLUDE_RUN_SERVICES=idm
GRAPH_LDAP_URI=ldap://1.2.3.4:389
GRAPH_LDAP_STARTTLS=true
GRAPH_LDAP_BIND_DN=cn=XXXXXX,dc=pg,dc=infn,dc=it
GRAPH_LDAP_BIND_PASSWORD=
GRAPH_LDAP_USER_BASE_DN=ou=people,dc=infn,dc=it
GRAPH_LDAP_USER_FILTER=(isMemberOf=g:infn:pg:owncloud:users::*)
GRAPH_USERNAME_MATCH=none
GRAPH_LDAP_USER_SCHEMA_USERNAME=uid
GRAPH_LDAP_USER_SCHEMA_MAIL=mail
GRAPH_LDAP_USER_SCHEMA_DISPLAYNAME=cn
GRAPH_LDAP_USER_SCHEMA_ID=infnUUID
GRAPH_ASSIGN_DEFAULT_ROLE_TO_ALL_USERS=true
GRAPH_DEFAULT_ROLE=user
GRAPH_LDAP_ROLE_MAPPING=none
#REDIS
OCIS_CACHE_STORE=redis
OCIS_CACHE_STORE_NODES=127.0.0.1:6379
STORAGE_USERS_ID_CACHE_STORE=redis
STORAGE_USERS_ID_CACHE_STORE_NODES=127.0.0.1:6379
# IDP LDAP authentication
IDP_LDAP_URI=ldap://1.2.3.4:389
IDP_LDAP_STARTTLS=true
IDP_LDAP_BIND_DN=cn=XXXXXX,dc=pg,dc=infn,dc=it
IDP_LDAP_BIND_PASSWORD=
IDP_LDAP_BASE_DN=ou=people,dc=infn,dc=it
IDP_LDAP_LOGIN_ATTRIBUTE=uid
IDP_LDAP_UUID_ATTRIBUTE=infnUUID
IDP_LDAP_UUID_ATTRIBUTE_TYPE=string
IDP_LDAP_USER_SCHEMA_USERNAME=uid
GRAPH_LDAP_INSECURE=false
GRAPH_LDAP_CACERT=/etc/ocis/certs/ds1_ca.pem
IDP_LDAP_CACERT=/etc/ocis/certs/ds1_ca.pem
AUTH_BASIC_LDAP_CACERT=/etc/ocis/certs/ds1_ca.pem
GROUPS_LDAP_CACERT=/etc/ocis/certs/ds1_ca.pem
PROXY_USER_OIDC_CLAIM=preferred_username
PROXY_USER_CS3_CLAIM=username
These are other details of my installation:
user ocis, home directory /opt/ocis
env file /etc/ocis/ocis.env
yaml file /etc/ocis/ocis.yaml
ocis exec /usr/local/bin/ocis
This is nginx config:
server {
listen 443 ssl http2;
server_name A.B.C.D;
ssl_certificate /etc/pki/tls/certs/server.pem;
ssl_certificate_key /etc/pki/tls/private/server.key;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:10m;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers off;
client_max_body_size 50G;
proxy_read_timeout 3600;
proxy_send_timeout 3600;
proxy_connect_timeout 300;
location / {
proxy_pass http://127.0.0.1:9200;
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto https;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Port 443;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_buffering on;
proxy_buffers 16 16k;
proxy_buffer_size 32k;
proxy_max_temp_file_size 0;
server {
listen 80;
return 301 https://$host$request_uri;
The current setup isn’t working well. I’m getting errors when logging in:
Jul 15 12:15:34 owncloud-is ocis[25134]: {"level":"error","service":"proxy","remoteAddr":"1.1.1.1","request-id":"","proto":"HTTP/1.1","method":"GET","path":"/js/chunks/locale-DicwRaQd.mjs","query":"","fragment":"","error":"context canceled","time":"2026-07-15T12:15:34+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/proxy/proxy.go:53","message":"error happened in MultiHostReverseProxy"}
Jul 15 12:15:34 owncloud-is ocis[25134]: {"level":"info","service":"proxy","proto":"HTTP/1.1","request-id":"A.B.C.C/TgubzHOlT8-000061","traceid":"95004504848fdb7954f72edb886d73d2","remote-addr":"1.1.1.1","method":"GET","status":502,"path":"/js/chunks/locale-DicwRaQd.mjs","duration":0.226554,"bytes":0,"time":"2026-07-15T12:15:34+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/accesslog.go:34","message":"access-log"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"error","service":"proxy","error":"failed to verify access token: token has invalid claims: token is expired","authenticator":"oidc","path":"/ocs/v2.php/cloud/capabilities","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:140.0) Gecko/20100101 Firefox/140.0","client.address":"1.1.1.1","network.peer.address":"","network.peer.port":"","time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/oidc_auth.go:198","message":"failed to authenticate the request"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"info","service":"frontend","pkg":"rhttp","traceid":"bc329828447747963322049e2a589b3e","time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/reva/v2@v2.0.0-20260702095801-b6833225e5d0/internal/http/interceptors/auth/auth.go:247","message":"skipping auth check for: /ocs/v2.php/cloud/capabilities"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"info","service":"proxy","proto":"HTTP/1.1","request-id":"6c8578b6-97bc-4fbc-8f7e-4c64308afd66","traceid":"049a9b099ce7b1794ef1c24b32b8a4e1","remote-addr":"1.1.1.1","method":"GET","status":200,"path":"/ocs/v2.php/cloud/capabilities","duration":68.585949,"bytes":3428,"time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/accesslog.go:34","message":"access-log"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"error","service":"proxy","error":"failed to verify access token: token has invalid claims: token is expired","authenticator":"oidc","path":"/api/v0/settings/roles-list","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:140.0) Gecko/20100101 Firefox/140.0","client.address":"1.1.1.1","network.peer.address":"","network.peer.port":"","time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/oidc_auth.go:198","message":"failed to authenticate the request"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"info","service":"proxy","proto":"HTTP/1.1","request-id":"2645d7a3-a435-4ca2-9750-935af2f53ecf","traceid":"aad2720ead6fb64152eca97e62823d5a","remote-addr":"1.1.1.1","method":"POST","status":401,"path":"/api/v0/settings/roles-list","duration":0.611414,"bytes":0,"time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/accesslog.go:34","message":"access-log"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"error","service":"proxy","error":"failed to verify access token: token has invalid claims: token is expired","authenticator":"oidc","path":"/graph/v1.0/me","user_agent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:140.0) Gecko/20100101 Firefox/140.0","client.address":"1.1.1.1","network.peer.address":"","network.peer.port":"","time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/oidc_auth.go:198","message":"failed to authenticate the request"}
Jul 15 12:16:12 owncloud-is ocis[25134]: {"level":"info","service":"proxy","proto":"HTTP/1.1","request-id":"247a81ef-0ac4-422a-8e47-97833a39ee83","traceid":"47e8299f52b09fd4380ced3c1fe4496e","remote-addr":"1.1.1.1","method":"GET","status":401,"path":"/graph/v1.0/me","duration":0.690132,"bytes":0,"time":"2026-07-15T12:16:12+02:00","line":"github.com/owncloud/ocis/v2/services/proxy/pkg/middleware/accesslog.go:34","message":"access-log"}
I’d like to know if there’s a web-based procedure for compiling the
configuration files, or if I have to use a vi editor.
I’d like to know if it’s important to have the ocis.yaml file and if the one
I’m using is correct.
token_manager:
jwt_secret:
machine_auth_api_key: d
system_user_api_key: d
transfer_secret:
system_user_id: 827f4450-e319-4c44-922d-312ae9cfb7f8
admin_user_id: 2e0b3697-3017-4150-9c0b-71f7b6999f96
graph:
application:
events:
tls_insecure: false
spaces:
insecure: false
identity:
ldap:
bind_password:
service_account:
service_account_id: 1917543b-543b-41bb-906f-4c62fa29b0cd
service_account_secret:
idp:
ldap:
bind_password:
uri: ldap://1.2.3.4:389
uuid_attribute: infnUUID
uuid_attribute_type: string
login_attribute: uid
idm:
service_user_passwords:
admin_password:
idm_password:
reva_password:
idp_password:
collaboration:
wopi:
secret:
app:
insecure: false
proxy:
oidc:
insecure: false
insecure_backends: false
service_account:
frontend:
app_handler:
insecure: false
archiver:
insecure: false
service_account:
auth_basic:
auth_providers:
ldap:
bind_password:
auth_bearer:
auth_providers:
oidc:
insecure: false
users:
drivers:
ldap:
bind_password:
groups:
drivers:
ldap:
bind_password:
ocdav:
insecure: false
ocm:
service_account:
thumbnails:
thumbnail:
transfer_secret:
webdav_allow_insecure: false
cs3_allow_insecure: false
search:
events:
tls_insecure: false
service_account:
audit:
events:
tls_insecure: false
settings:
service_account_ids:
- 1917543b-543b-41bb-906f-4c62fa29b0cd
sharing:
events:
tls_insecure: false
storage_users:
events:
tls_insecure: false
mount_id: 563f1e8e-6179-44bf-a532-e6ca7dafd6c3
service_account:
notifications:
notifications:
events:
tls_insecure: false
service_account:
nats:
nats:
tls_skip_verify_client_cert: false
gateway:
storage_registry:
storage_users_mount_id: 563f1e8e-6179-44bf-a532-e6ca7dafd6c3
userlog:
service_account:
auth_service:
service_account:
clientlog:
service_account:
activitylog:
service_account:
Thank you in advance for your help.
Best Regards
Enrico
