oCIS high CPU usage
I am running oCIS in docker v7.0.1, default configuration. Even in idle state, with no users logged in, the CPU usage is significantly high.
Any thoughts on what might be going on here?
  1. Deploy a ocIS v7.0.1 docker image
  2. Check docker stats, CPU usage for ocis container significantly high (mine hovers 120 - 130%)
The CPU usage should be fraction of a percentage. Just for contrast, collabora running in a docker container on same host is 0.05 - 0.12% CPU usage
CPU % hovers between 120 - 130%
Operating system: Mac OS
ownCloud version: (see ownCloud admin page) Infinite Scale v7.0.1
Where did you install ownCloud from: hub.docker.com
That doesn’t sound right. Are there any logs that tell us what the server is doing? If not you could try to activate debugs logs. Maybe they tell us what the platform is trying to do.
thanks @kobergj - I must have done something wrong. When I revisited it today, the CPU usage was normal and not spiking. Appreciate the response.
