I could use some help in getting OCIS working with Active Directory.
- Deployed a working basic Active Directory on Windows Server 2022 [tested integration with other systems and working]
- Installed OCIS version 4.0.5 (latest as of this writing) on Debian 12 following the Bare etal Installation with Systemd [tested and working with the embedded LDAP]
- Attempted to integrate OCIS with Active Directory following [LDAP - Active Directory | ownCloud]
Login would work using a user from Active Directory
Internal Server Error
OCIS Server
Operating system: Debian 12
ownCloud Infinite Scale: version 4.0.5 (fresh install from scratch)
Reverse Proxy Server
Web server: Apache (with Letsencrypt certbot)
OCIS configuration
Commented configuration lines show some slight variations in config I have tried.
OCIS_URL=https://cloud.example.com
PROXY_HTTP_ADDR=0.0.0.0:9200
PROXY_TLS=false
OCIS_INSECURE=false
OCIS_LOG_LEVEL=error
GRAPH_LOG_LEVEL=error
IDP_LOG_LEVEL=debug
PROXY_LOG_LEVEL=error
USERS_LOG_LEVEL=debug
OCIS_CONFIG_DIR=/etc/ocis
OCIS_BASE_DATA_PATH=/var/lib/ocis
# Active Directory integration
OCIS_LDAP_URI=ldap://ad.example.com:389
OCIS_LDAP_INSECURE="true"
OCIS_LDAP_BIND_DN="CN=Administrator,CN=Users,DC=ad,DC=example,DC=com"
OCIS_LDAP_BIND_PASSWORD=mypassword
#OCIS_LDAP_BIND_DN="CN=ownCloud Binder,OU=Service Accounts,DC=ad,DC=example,DC=com"
#OCIS_LDAP_BIND_PASSWORD=mypassword
OCIS_LDAP_DISABLE_USER_MECHANISM="none"
#OCIS_LDAP_GROUP_BASE_DN="CN=Groups,DC=ad,DC=example,DC=com"
OCIS_LDAP_GROUP_BASE_DN="CN=ownCloud Users,OU=Groups,DC=ad,DC=example,DC=com"
OCIS_LDAP_GROUP_OBJECTCLASS="group"
OCIS_LDAP_GROUP_SCHEMA_ID="objectGUID"
OCIS_LDAP_GROUP_SCHEMA_ID_IS_OCTETSTRING="true"
OCIS_LDAP_GROUP_SCHEMA_GROUPNAME="cn"
#OCIS_LDAP_USER_BASE_DN="CN=Users,DC=ad,DC=example,DC=com"
OCIS_LDAP_USER_BASE_DN="DC=ad,DC=example,DC=com"
OCIS_LDAP_USER_OBJECTCLASS="user"
OCIS_LDAP_USER_SCHEMA_ID="objectGUID"
OCIS_LDAP_USER_SCHEMA_ID_IS_OCTETSTRING="true"
OCIS_LDAP_USER_SCHEMA_USERNAME="sAMAccountName"
OCIS_LDAP_USER_ENABLED_ATTRIBUTE=Enabled # adding this got me further but with new errors somehow
OCIS_LDAP_LOGIN_ATTRIBUTES="sAMAccountName"
IDP_LDAP_LOGIN_ATTRIBUTE="sAMAccountName"
IDP_LDAP_UUID_ATTRIBUTE="objectGUID"
#IDP_LDAP_UUID_ATTRIBUTE_TYPE=binary
IDP_LDAP_UUID_ATTRIBUTE_TYPE=text
GRAPH_LDAP_SERVER_WRITE_ENABLED="false"
OCIS_EXCLUDE_RUN_SERVICES=idm
OCIS_ADMIN_USER_ID="<the-actual-objectGUID-of-my-own-user-in-active-directory>"
Browser: Tried with Firefox/Chrome
Operating system: Windows 11
I get losts of this one for all my attempted Active Directory integration configuration attempts.
Jan 29 08:23:14 hostname ocis[10050]: {"level":"debug","service":"idp","client_id":"<UUID>","known":true,"redirect_uri":"","trusted":false,"time":"2024-01-29T08:23:14.815638979+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/log/logrus_wrapper.go:50","message":"identifier client lookup"}
Jan 29 08:23:14 hostname ocis[10050]: {"level":"error","service":"idp","error":"ldap identifier backend get user error: user does not exist or too many entries returned","time":"2024-01-29T08:23:14.820901051+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/log/logrus_wrapper.go:50","message":"IdentifierIdentityManager: fetch failed to get user from userID"}
But those below I only started getting those when I added OCIS_LDAP_USER_ENABLED_ATTRIBUTE=Enabled
to configuration and seemingly got further.
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"UNLOCK","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.951943003+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"REPORT","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.951953091+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"OPTIONS","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.951963089+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"POST","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.951973084+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"MOVE","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.951994315+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"DELETE","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.952004861+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"MKCOL","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.952014979+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"TRACE","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.952024666+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"GET","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.952034378+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:47 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","method":"CONNECT","route":"/*","middlewares":9,"time":"2024-01-29T08:23:47.952051031+08:00","line":"github.com/owncloud/ocis/v2/services/idp/pkg/service/v0/service.go:269","message":"serving endpoint"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/.well-known/openid-configuration","duration":0.423404,"bytes":1816,"time":"2024-01-29T08:23:58.53980142+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":302,"path":"/signin/v1/identifier/_/authorize","duration":0.313307,"bytes":0,"time":"2024-01-29T08:23:58.565398287+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier","duration":0.602636,"bytes":913,"time":"2024-01-29T08:23:58.573098725+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/css/8.ac8bee22.chunk.css","duration":0.226284,"bytes":1883,"time":"2024-01-29T08:23:58.61388211+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/css/main.23a06b80.chunk.css","duration":0.160094,"bytes":1972,"time":"2024-01-29T08:23:58.615859891+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/runtime-main.e4d9e19d.js","duration":0.198932,"bytes":2822,"time":"2024-01-29T08:23:58.61689922+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/8.db623e05.chunk.js","duration":0.649794,"bytes":307030,"time":"2024-01-29T08:23:58.618001097+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/main.db02c823.chunk.js","duration":0.144742,"bytes":6036,"time":"2024-01-29T08:23:58.618235327+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/media/background.7296b9ab.jpg","duration":0.29353,"bytes":88069,"time":"2024-01-29T08:23:58.632547186+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/media/inter.aadb65ac.ttf","duration":1.168918,"bytes":803384,"time":"2024-01-29T08:23:58.6434092+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/9.59d761ae.chunk.js","duration":0.267958,"bytes":26958,"time":"2024-01-29T08:23:58.696520636+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/identifier-main.f8c32709.chunk.js","duration":0.132813,"bytes":1828,"time":"2024-01-29T08:23:58.696920131+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/media/inter.aadb65ac.ttf","duration":1.192341,"bytes":803384,"time":"2024-01-29T08:23:58.698423307+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/0.2b291eb9.chunk.js","duration":0.317855,"bytes":88467,"time":"2024-01-29T08:23:58.723052981+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/10.d3ab2020.chunk.js","duration":0.272571,"bytes":49290,"time":"2024-01-29T08:23:58.72433325+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/containers-login.8a89c515.chunk.js","duration":0.181582,"bytes":22012,"time":"2024-01-29T08:23:58.724394053+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/all-i18n-data.c64abe28.chunk.js","duration":0.173139,"bytes":7566,"time":"2024-01-29T08:23:58.72884043+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/favicon.ico","duration":0.207886,"bytes":15086,"time":"2024-01-29T08:23:58.73488067+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/logo.svg","duration":0.119551,"bytes":9896,"time":"2024-01-29T08:23:58.748517353+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"POST","status":200,"path":"/signin/v1/identifier/_/hello","duration":0.59166,"bytes":86,"time":"2024-01-29T08:23:58.749415041+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:23:58 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/signin/v1/identifier/static/js/main.db02c823.chunk.js.map","duration":0.179954,"bytes":16634,"time":"2024-01-29T08:23:58.798048944+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","id":"objectGUID=%93%5B%05U%96%E7%E9L%9A%8A%10%A6%AB%05m%AA","username":"aduser","time":"2024-01-29T08:24:04.396376626+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/log/logrus_wrapper.go:50","message":"ldap identifier backend logon"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","client_id":"web","known":true,"redirect_uri":"https://cloud.example.com/oidc-callback.html","trusted":true,"time":"2024-01-29T08:24:04.402755101+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/log/logrus_wrapper.go:50","message":"identifier client lookup"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"POST","status":200,"path":"/signin/v1/identifier/_/logon","duration":16.019282,"bytes":290,"time":"2024-01-29T08:24:04.403235023+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","client_id":"web","known":true,"redirect_uri":"https://cloud.example.com/oidc-callback.html","trusted":true,"time":"2024-01-29T08:24:04.438460066+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/log/logrus_wrapper.go:50","message":"identifier client lookup"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":302,"path":"/signin/v1/identifier/_/authorize","duration":6.147409,"bytes":0,"time":"2024-01-29T08:24:04.438835557+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/.well-known/openid-configuration","duration":0.153206,"bytes":1816,"time":"2024-01-29T08:24:04.930903067+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:04 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","client_id":"web","known":true,"redirect_uri":"https://cloud.example.com/oidc-callback.html","trusted":true,"time":"2024-01-29T08:24:04.943280177+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/log/logrus_wrapper.go:50","message":"identifier client lookup"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"POST","status":200,"path":"/konnect/v1/token","duration":68.612244,"bytes":2457,"time":"2024-01-29T08:24:05.011658489+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/konnect/v1/userinfo","duration":8.915597,"bytes":241,"time":"2024-01-29T08:24:05.035518782+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/.well-known/openid-configuration","duration":0.172219,"bytes":1816,"time":"2024-01-29T08:24:05.0882301+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/konnect/v1/jwks.json","duration":0.370006,"bytes":1609,"time":"2024-01-29T08:24:05.101551013+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"idp","request-id":"","proto":"HTTP/1.1","method":"GET","status":200,"path":"/konnect/v1/userinfo","duration":8.435891,"bytes":241,"time":"2024-01-29T08:24:05.126256057+08:00","line":"github.com/owncloud/ocis/v2/ocis-pkg/middleware/logger.go:27"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"e79e4bd58c282627639f94ccb8655076","method":"/cs3.identity.user.v1beta1.UserAPI/GetUserByClaim","time":"2024-01-29T08:24:05.169091382+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/internal/grpc/interceptors/auth/auth.go:122","message":"skipping auth"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"e79e4bd58c282627639f94ccb8655076","claim":"username","value":"aduser","time":"2024-01-29T08:24:05.16912977+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/user/manager/ldap/ldap.go:137","message":"GetUserByClaim"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"e79e4bd58c282627639f94ccb8655076","backend":"ldap","basedn":"DC=ad,DC=example,DC=com","filter":"(&(objectclass=user)(sAMAccountName=aduser))","scope":2,"time":"2024-01-29T08:24:05.169155572+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/utils/ldap/identity.go:217","message":"LDAP Search"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"e79e4bd58c282627639f94ccb8655076","entry":{"DN":"CN=AD User,CN=Users,DC=ad,DC=example,DC=com","Attributes":[{"Name":"displayName","Values":["AD User"],"ByteValues":["R2hpc2xhaW4gSGFjaGV5"]},{"Name":"objectGUID","Values":["\ufffd[\u0005U\ufffd\ufffd\ufffdL\ufffd\ufffd\u0010\ufffd\ufffd\u0005m\ufffd"],"ByteValues":["k1sFVZbn6UyaihCmqwVtqg=="]},{"Name":"sAMAccountName","Values":["aduser"],"ByteValues":["Z2hhY2hleQ=="]}]},"time":"2024-01-29T08:24:05.174381395+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/user/manager/ldap/ldap.go:144","message":"entries"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"e79e4bd58c282627639f94ccb8655076","backend":"ldap","basedn":"CN=ownCloud Users,OU=Groups,DC=ad,DC=example,DC=com","filter":"(&(objectclass=group)(member=CN=AD User,CN=Users,DC=ad,DC=example,DC=com))","scope":2,"time":"2024-01-29T08:24:05.174439636+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/utils/ldap/identity.go:349","message":"LDAP Search"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"e79e4bd58c282627639f94ccb8655076","user-agent":"grpc-go/1.57.0","from":"tcp://127.0.0.1:33840","uri":"/cs3.identity.user.v1beta1.UserAPI/GetUserByClaim","start":"29/Jan/2024:08:24:05 +0800","end":"29/Jan/2024:08:24:05 +0800","time_ns":6456835,"code":"OK","time":"2024-01-29T08:24:05.175576039+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/internal/grpc/interceptors/log/log.go:69","message":"unary"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"ocis","error":"error: not found: create container: error: not found: f1bdd61a-da7c-49fc-8203-0558109d1b4f!f1bdd61a-da7c-49fc-8203-0558109d1b4f/settings","time":"2024-01-29T08:24:05.18801412+08:00","message":"error initializing metadata client"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"ocis","error":"error: not found: create container: error: not found: f1bdd61a-da7c-49fc-8203-0558109d1b4f!f1bdd61a-da7c-49fc-8203-0558109d1b4f/settings","time":"2024-01-29T08:24:05.299342379+08:00","message":"error initializing metadata client"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"proxy","error":"{\"id\":\"go.micro.server\",\"code\":500,\"detail\":\"panic recovered: runtime error: invalid memory address or nil pointer dereference\",\"status\":\"Internal Server Error\"}","time":"2024-01-29T08:24:05.300212813+08:00","message":"Could not load roles"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"proxy","error":"{\"id\":\"go.micro.server\",\"code\":500,\"detail\":\"panic recovered: runtime error: invalid memory address or nil pointer dereference\",\"status\":\"Internal Server Error\"}","time":"2024-01-29T08:24:05.30044223+08:00","message":"Could not get user roles"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"0aa1a9f3a1372ec1213367eb20cc1384","method":"/cs3.identity.user.v1beta1.UserAPI/GetUserByClaim","time":"2024-01-29T08:24:05.313116436+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/internal/grpc/interceptors/auth/auth.go:122","message":"skipping auth"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"0aa1a9f3a1372ec1213367eb20cc1384","claim":"username","value":"aduser","time":"2024-01-29T08:24:05.313153508+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/user/manager/ldap/ldap.go:137","message":"GetUserByClaim"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"0aa1a9f3a1372ec1213367eb20cc1384","backend":"ldap","basedn":"DC=ad,DC=example,DC=com","filter":"(&(objectclass=user)(sAMAccountName=aduser))","scope":2,"time":"2024-01-29T08:24:05.313179689+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/utils/ldap/identity.go:217","message":"LDAP Search"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"0aa1a9f3a1372ec1213367eb20cc1384","entry":{"DN":"CN=AD User,CN=Users,DC=ad,DC=example,DC=com","Attributes":[{"Name":"displayName","Values":["AD User"],"ByteValues":["R2hpc2xhaW4gSGFjaGV5"]},{"Name":"objectGUID","Values":["\ufffd[\u0005U\ufffd\ufffd\ufffdL\ufffd\ufffd\u0010\ufffd\ufffd\u0005m\ufffd"],"ByteValues":["k1sFVZbn6UyaihCmqwVtqg=="]},{"Name":"sAMAccountName","Values":["aduser"],"ByteValues":["Z2hhY2hleQ=="]}]},"time":"2024-01-29T08:24:05.314607206+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/user/manager/ldap/ldap.go:144","message":"entries"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"0aa1a9f3a1372ec1213367eb20cc1384","backend":"ldap","basedn":"CN=ownCloud Users,OU=Groups,DC=ad,DC=example,DC=com","filter":"(&(objectclass=group)(member=CN=AD User,CN=Users,DC=ad,DC=example,DC=com))","scope":2,"time":"2024-01-29T08:24:05.314651885+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/pkg/utils/ldap/identity.go:349","message":"LDAP Search"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"debug","service":"users","pkg":"rgrpc","traceid":"0aa1a9f3a1372ec1213367eb20cc1384","user-agent":"grpc-go/1.57.0","from":"tcp://127.0.0.1:33840","uri":"/cs3.identity.user.v1beta1.UserAPI/GetUserByClaim","start":"29/Jan/2024:08:24:05 +0800","end":"29/Jan/2024:08:24:05 +0800","time_ns":2628008,"code":"OK","time":"2024-01-29T08:24:05.315760562+08:00","line":"github.com/cs3org/reva/v2@v2.16.4-0.20231220070538-82b93f6a66bc/internal/grpc/interceptors/log/log.go:69","message":"unary"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"ocis","error":"error: not found: create container: error: not found: f1bdd61a-da7c-49fc-8203-0558109d1b4f!f1bdd61a-da7c-49fc-8203-0558109d1b4f/settings","time":"2024-01-29T08:24:05.325834388+08:00","message":"error initializing metadata client"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"ocis","error":"error: not found: create container: error: not found: f1bdd61a-da7c-49fc-8203-0558109d1b4f!f1bdd61a-da7c-49fc-8203-0558109d1b4f/settings","time":"2024-01-29T08:24:05.436428115+08:00","message":"error initializing metadata client"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"proxy","error":"{\"id\":\"go.micro.server\",\"code\":500,\"detail\":\"panic recovered: runtime error: invalid memory address or nil pointer dereference\",\"status\":\"Internal Server Error\"}","time":"2024-01-29T08:24:05.438058497+08:00","message":"Could not load roles"}
Jan 29 08:24:05 ocis-hostname ocis[10079]: {"level":"error","service":"proxy","error":"{\"id\":\"go.micro.server\",\"code\":500,\"detail\":\"panic recovered: runtime error: invalid memory address or nil pointer dereference\",\"status\":\"Internal Server Error\"}","time":"2024-01-29T08:24:05.438083375+08:00","message":"Could not get user roles"}
[UserManager] getUser: user loaded
[UserManager] signinSilentCallback: success
[UserManager] signinSilent: success, signed in subject IPBwJ9dpRWSxD
POST https://cloud.example.com/api/v0/settings/values-list [HTTP/1.1 500 Internal Server Error 154ms]
