- Installed ownCloud 10.7 on Raspberry Pi 4 with Raspbian
- Tried first connection to dashboard, logged smoothly
- Followed instructions to move datadir to a different path, specifically on an external USB drive
- Checked that USB drive path was set properly for www-data user from terminal before and after applying the datadir change guide
Logging in and seeing datadir changed to external drive
After restarting Apache and occ the dashboard web page returns an Internal server error message
Operating system: Raspbian 10
Web server: Apache
PHP version: cat /etc/os-release
ownCloud version: (see ownCloud admin page) ownCloud 10.7
Where did you install ownCloud from: tar
Signing status (ownCloud 9.0 and above): not enabled
"system": {
"trusted_domains": [
"localhost",
"192.168.1.113"
"datadirectory": "\/media\/wde\/data\/",
"overwrite.cli.url": "http:\/\/localhost",
"dbtype": "mysql",
"version": "10.7.0.4",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"logtimezone": "UTC",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/apps-external",
"writable": true
"installed": true,
"instanceid": "occg2z94ljfn",
"redis": {
"host": "127.0.0.1",
"port": "6379"
"maintenance": false
Enabled:
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.0
- dav:
- Version: 0.6.0
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.5.2
- files_external:
- Version: 0.7.1
- files_mediaviewer:
- Version: 1.0.4
- files_sharing:
- Version: 0.14.0
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.2.0
- market:
- Version: 0.6.0
- notifications:
- Version: 0.5.2
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- updatenotification:
- Version: 0.2.1
Disabled:
- encryption:
- external:
- user_external:
Are you using external storage, if yes which one: /media/wde
Are you using encryption: no
Browser: stock Raspbian browser
{"reqId":"l4pyHdS7KY4g4VIucPXI","level":3,"time":"2021-04-02T20:36:41+00:00","remoteAddr":"192.168.1.113","user":"magione","app":"index","method":"GET","url":"-index.php-apps-gfiles-/?dir=-/&fileid=3","message":"Exception: {-"Exception-":-"OCP -Files -NotFoundException-",-"Message-":-"-",-"Code-":0,-"Trace-":-"#0 /var /www /owncloud /apps /files /lib /Controller /ViewController.php(134): OC_Helper::getStorageInfo(' /', false)--n#1 /var /www /owncloud /apps /files /lib /Controller /ViewController.php(208): OCA -Files -Controller -ViewController->getStorageInfo()--n#2 /var /www /owncloud /lib /private /AppFramework /Http /Dispatcher.php(153): OCA -Files -Controller -ViewController->index(' /', '', '3', NULL)--n#3 /var /www /owncloud /lib /private /AppFramework /Http /Dispatcher.php(85): OC -AppFramework -Http -Dispatcher->executeController(Object(OCA -Files -Controller -ViewController), 'index')--n#4 /var /www /owncloud /lib /private /AppFramework /App.php(100): OC -AppFramework -Http -Dispatcher->dispatch(Object(OCA -Files -Controller -ViewController), 'index')--n#5 /var /www /owncloud /lib /private /AppFramework /Routing /RouteActionHandler.php(47): OC -AppFramework -App::main('ViewController', 'index', Object(OC -AppFramework -DependencyInjection -DIContainer), Array)--n#6 /var /www /owncloud /lib /private /Route /Router.php(341): OC -AppFramework -Routing -RouteActionHandler->__invoke(Array)--n#7 /var /www /owncloud /lib /base.php(915): OC -Route -Router->match(' /apps /files /')--n#8 /var /www /owncloud /index.php(54): OC::handleRequest()--n#9 {main}-",-"File-":-" /var /www /owncloud /lib /private /legacy /helper.php-",-"Line-":585}"}
{"reqId":"tfRZ9XIYtLQXYfpHpmhh","level":3,"time":"2021-04-02T20:36:41+00:00","remoteAddr":"192.168.1.113","user":"magione","app":"index","method":"GET","url":"-index.php-apps-gfiles-/?dir=-/&fileid=3","message":"Exception: {-"Exception-":-"OCP -Files -NotFoundException-",-"Message-":-"-",-"Code-":0,-"Trace-":-"#0 /var /www /owncloud /apps /files /lib /Controller /ViewController.php(134): OC_Helper::getStorageInfo(' /', false)--n#1 /var /www /owncloud /apps /files /lib /Controller /ViewController.php(208): OCA -Files -Controller -ViewController->getStorageInfo()--n#2 /var /www /owncloud /lib /private /AppFramework /Http /Dispatcher.php(153): OCA -Files -Controller -ViewController->index(' /', '', '3', NULL)--n#3 /var /www /owncloud /lib /private /AppFramework /Http /Dispatcher.php(85): OC -AppFramework -Http -Dispatcher->executeController(Object(OCA -Files -Controller -ViewController), 'index')--n#4 /var /www /owncloud /lib /private /AppFramework /App.php(100): OC -AppFramework -Http -Dispatcher->dispatch(Object(OCA -Files -Controller -ViewController), 'index')--n#5 /var /www /owncloud /lib /private /AppFramework /Routing /RouteActionHandler.php(47): OC -AppFramework -App::main('ViewController', 'index', Object(OC -AppFramework -DependencyInjection -DIContainer), Array)--n#6 /var /www /owncloud /lib /private /Route /Router.php(341): OC -AppFramework -Routing -RouteActionHandler->__invoke(Array)--n#7 /var /www /owncloud /lib /base.php(915): OC -Route -Router->match(' /apps /files /')--n#8 /var /www /owncloud /index.php(54): OC::handleRequest()--n#9 {main}-",-"File-":-" /var /www /owncloud /lib /private /legacy /helper.php-",-"Line-":585}"}
{"reqId":"a35F8M8naNN9vfAK56Yr","level":3,"time":"2021-04-02T20:36:43+00:00","remoteAddr":"192.168.1.113","user":"magione","app":"index","method":"GET","url":"-index.php-apps-gfiles-/","message":"Exception: {-"Exception-":-"OCP -Files -NotFoundException-",-"Message-":-"-",-"Code-":0,-"Trace-":-"#0 /var /www /owncloud /apps /files /lib /Controller /ViewController.php(134): OC_Helper::getStorageInfo(' /', false)--n#1 /var /www /owncloud /apps /files /lib /Controller /ViewController.php(208): OCA -Files -Controller -ViewController->getStorageInfo()--n#2 /var /www /owncloud /lib /private /AppFramework /Http /Dispatcher.php(153): OCA -Files -Controller -ViewController->index('', '', NULL, NULL)--n#3 /var /www /owncloud /lib /private /AppFramework /Http /Dispatcher.php(85): OC -AppFramework -Http -Dispatcher->executeController(Object(OCA -Files -Controller -ViewController), 'index')--n#4 /var /www /owncloud /lib /private /AppFramework /App.php(100): OC -AppFramework -Http -Dispatcher->dispatch(Object(OCA -Files -Controller -ViewController), 'index')--n#5 /var /www /owncloud /lib /private /AppFramework /Routing /RouteActionHandler.php(47): OC -AppFramework -App::main('ViewController', 'index', Object(OC -AppFramework -DependencyInjection -DIContainer), Array)--n#6 /var /www /owncloud /lib /private /Route /Router.php(341): OC -AppFramework -Routing -RouteActionHandler->__invoke(Array)--n#7 /var /www /owncloud /lib /base.php(915): OC -Route -Router->match(' /apps /files /')--n#8 /var /www /owncloud /index.php(54): OC::handleRequest()--n#9 {main}-",-"File-":-" /var /www /owncloud /lib /private /legacy /helper.php-",-"Line-":585}"}
{"reqId":"wXrulWD9jHU4e0SEiTD1","level":3,"time":"2021-04-02T20:41:43+00:00","remoteAddr":"192.168.1.113","user":"magione","app":"no app in context","method":"GET","url":"-ocs-v2.php-gapps-/notifications-/api-/v1-/notifications?format=json","message":"User backend OC--User--Database is returning home: -/media-/wde-/data-/-/magione for user: magione which differs from existing value: -/media-/wde-/data-/magione-/files"}
ownCloud
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times and include the technical details below in your report.
Technical details
Remote Address: 192.168.1.113
Request ID: a35F8M8naNN9vfAK56Yr
Believe it or not, the mount command needs
