Odd language or character encoding for numbers display in client
client app settings show folder and files etc, E.G. "285 MB of 5.2 GB in use"
numbers are displayed in odd characters, I'm guessing Greek, Arabic, or something similar
E.G. "٤٨٥MB of ٥.٢GB in use"
  1. Windows 10 EN-GB lang default
  2. install client Version 2.3.4 (build 8624)
  3. Open settings window.. !
Web server: n/k
Database: n/k
PHP version: n/k
ownCloud version: n/k
Storage backend (external storage): n/k
Client version:Version 2.3.4 (build 8624)
Operating system:WIN 10 PRO 1703
OS language:EN-GB
Installation path of client:E:\Program Files (x86)\ownCloud
N/A
Shouldn't be something like this reported to a bugtracker?
Not to my logic - I figure if no-one else has the problem then the issue is with my rig; I was looking for some insight or maybe a suggestion from someone else that recognised the condition. Doesn't warrant a full on bug report until I can be sure it's a universal issue.
But everything else in the UI looks fine?
Do you have any special screen? (very high DPI, very low resolution, remote screen, ...)?
