- Ubuntu do-release-upgrade from 14.04 LTS to 16.04 LTS
It should just work!
When I go to my owncloud server page, I get a bunch of text instead of the frontpage.
Web server: Apache 2.4.18
Database: MySql
PHP version: 7.0.8
Updated from an older ownCloud or fresh install: 9.1.0 was working with Ubuntu 14.04
Integrity status for oC9+
This is what shows up on the web page. Or, you can see for yourself at https://cloud.phipac.com
* @author Lukas Reschke
* @author Morris Jobke
* @author Robin Appelman
* @author Thomas Müller
* @author Vincent Petry
* @copyright Copyright (c) 2016, ownCloud, Inc.
* @license AGPL-3.0
* This code is free software: you can redistribute it and/or modify
* it under the terms of the GNU Affero General Public License, version 3,
* as published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Affero General Public License for more details.
* You should have received a copy of the GNU Affero General Public License, version 3,
* along with this program. If not, see
// Show warning if a PHP version below 5.4.0 is used, this has to happen here
// because base.php will already use 5.4 syntax.
if (version_compare(PHP_VERSION, '5.4.0') === -1) {
echo 'This version of ownCloud requires at least PHP 5.4.0
echo 'You are currently running ' . PHP_VERSION . '. Please update your PHP version.';
return;
try {
require_once 'lib/base.php';
OC::handleRequest();
} catch(\OC\ServiceUnavailableException $ex) {
\OC::$server->getLogger()->logException($ex, ['app' => 'index']);
//show the user a detailed error page
OC_Response::setStatus(OC_Response::STATUS_SERVICE_UNAVAILABLE);
OC_Template::printExceptionErrorPage($ex);
} catch (\OC\HintException $ex) {
OC_Template::printErrorPage($ex->getMessage(), $ex->getHint());
} catch (Exception $ex) {
OC_Response::setStatus(OC_Response::STATUS_INTERNAL_SERVER_ERROR);
} catch (Error $ex) {
