Opendir(/var/temp): failed to open dir: Not a directory
1.I’m seeing in my logs that i’m getting the error: “Error PHP opendir(/var/temp): failed to open dir: Not a directory at /var/www/owncloud/lib/private/tempmanager.php#187”
2.Don’t know where the error is coming from.
3.
NO error? :slight_smile:
Tell us what happens instead: Don’t know what the impact is, although my Music app is hanging, when i open it it freezes mostly after a few secs.
Operating system: Ubuntu server 16.04
Web server: apache2
Database: mysql
PHP version:7.0
ownCloud version (see ownCloud admin page):9.0.2
ownCloud log (data/owncloud.log, see How to find webserver or OC logfile / enable php logfile):https://cloud.ofnie.eu/index.php/s/WaXy7K3ujzq1xyz Password = “logfile”
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): no external storage, no external authentication, no reverse proxy.
Integrity status for oC9+
@memorex Hi, maybe this comment of this issue can help you:
or the solution provided in this other issue:
Cheers, davitol
its most likely that the following PHP directive:
is configured to a wrong (the /var/temp) directory which doesn’t exist or which is a file as the message:
is telling you.
Thank you for the reply!
I created a directory and chowned it to the user who is running PHP, also i checked the permissions so that it’s writable by the user and modified the directive “upload_tmp_dir” in my php.ini config file.
I uploaded a file to owncloud via http and don’t see the error.
Case closed? Or should i test it in another way?
Kind regards, Jonathan.
