Hello Frank,
I tried deleting the DB file, however it unfortunately did not help. It does create the DB file again. Also, when sending the e-mail nothing happens.
The log file:
7-4-2018 09:33:24 INFO: Initializing Adding… Start
7-4-2018 09:33:30 ERROR: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
bij System.Data.SQLite.SQLite3.Open(String strFilename, String vfsName, SQLiteConnectionFlags connectionFlags, SQLiteOpenFlagsEnum openFlags, Int32 maxPoolSize, Boolean usePool)
bij System.Data.SQLite.SQLiteConnection.Open()
bij Update.DbUpsert.CreateShareLogTableIfNotExist()
bij Update.DbUpsert.DB_Path(). Problem while creating BLURRED\AppData\Roaming\ownCloud.Logshare.db
7-4-2018 09:34:23 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
bij Outlook_EpikShare.DBconnection.DBquerys.GetNextPendingShareId(). No connection to DB.
7-4-2018 09:34:23 WARN: System.NullReferenceException: De objectverwijzing is niet op een exemplaar van een object ingesteld.
bij Outlook_EpikShare.ShareSettingForm.checkForm(Object sender, EventArgs e)
bij System.Windows.Forms.Control.OnTextChanged(EventArgs e)
bij System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e)
bij System.Windows.Forms.Control.set_Text(String value)
bij System.Windows.Forms.TextBoxBase.set_Text(String value)
bij System.Windows.Forms.TextBox.set_Text(String value)
bij Outlook_EpikShare.ShareSettingForm…ctor(Boolean allowE2ee). Can`t open Window ShareSettings. ShareSettings Line 19
7-4-2018 09:34:34 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
bij Outlook_EpikShare.DBconnection.DBquerys.GetPendingSharesFromSql(). No connection to DB.
bij Outlook_EpikShare.DBconnection.DBquerys.CreatePendingShare(PendingShares pendingshares). No connection to DB.
7-4-2018 09:34:37 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
bij Outlook_EpikShare.DBconnection.DBquerys.GetPendingShareFilesFromSql(PendingShares ps). No connection to DB.
bij Outlook_EpikShare.DBconnection.DBquerys.UpdatePendingShareMailtext(PendingShares ps). No connection to DB.
bij Outlook_EpikShare.DBconnection.DBquerys.UpdatePendingShareSubject(PendingShares ps). No connection to DB.
bij Outlook_EpikShare.DBconnection.DBquerys.CreatePendingSharesGuests(String recipient). CreatePendingSharesGuests
bij Outlook_EpikShare.DBconnection.DBquerys.UpdatePendingSharesRecipients(String updaterecipients, Int64 psId, PendingSharesState state). No connection to DB.
7-4-2018 09:34:38 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
7-4-2018 09:34:39 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
bij Outlook_EpikShare.DBconnection.DBquerys.SetSharelog_ServerShares(ServerShare servershares). Error
7-4-2018 09:34:53 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
7-4-2018 09:34:57 WARN: System.Data.SQLite.SQLiteException (0x80004005): unable to open database file
bij Outlook_EpikShare.Views.MyOutlookShares.GetAktiveShareFromSql(). No connection to DB.
bij Outlook_EpikShare.Views.MyOutlookShares.GetDeaktivateShareFromSql(). No connection to DB.
