- Normal installation of owncloud 9.1 on Debian. I created two conf files in the sites-available directory of apache: one for my subdomain and one for the main domain.
The user should access the cloud webpage through the subdomain.
The subdomain redirects to the main domain.
Operating system: debian 8.7
Web server: 2.4.10-10+de
Database: mariadb-server 10.1.21+mari
PHP version: php5 5.6.29+dfsg-
owncloud: 9.1.3-1.1
Special configuration (external storage, external authentication,
reverse proxy, server-side-encryption):
external storage, external authentifcation and server-side-encryption
enable
Comment
On my former server, owncloud was in a folder which name was sub.domain.ltd. It used to work. Now, I install on my new server and the subdomain redirects to the main domain.
My config:
<?php
$CONFIG = array (
'updatechecker' => false,
'instanceid' => 'octg8xzbc7wj',
'passwordsalt' => 'EBsyvBmoxXbsVhFW/7DJ+yVhGmq+Hd',
'secret' => 'ZFxLuWUkRGHopiLXQPMqAQHTFAYxinx0fu3rIwQcD1/0c5Cg',
'trusted_domains' =>
array (
0 => 'IP',
1 = > 'cloud.domain.ltd',
'datadirectory' => '/var/www/owncloud/data',
#'overwrite.cli.url' => 'http://IP/owncloud',
'overwrite.cli.url' => 'http://cloud.domain.ltd',
'dbtype' => 'mysql',
'version' => '9.1.3.1',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'dbuser' => 'oc_tchokapix1',
'dbpassword' => 'RFy5/vX0GUpctdx8RMZ5s2/zp75/QN',
'logtimezone' => 'UTC',
'installed' => true,
If I tell the config.php to overwrite the ip of the localhost, I can access my cloud throught the following address: http://IP/owncloud.
The two apaches configuration files show Documentroot (cloud.domain.ltd.conf points to the folder of my cloud and domain.ltd.conf points to the folder of my blog).
