this is stupid question, but I changed this file:
lib/private/legacy/defaults.php
core/img/logo-icon.svg
for my owncloud (my logo and my text in home page)
Results:
core
INVALID_HASH
How do I remove this notice?
thanks
hi @oscaroxy please view ownCloud Documentation Overview
and ownCloud Documentation Overview
you will have to replace the defaults.php with the original from the tarball
and rerun occ integrity:check-core
thanks, I followed the steps:
create apps/appinfo/info.xml
create apps/theme-example
put into theme-example:
defaults.php (with my own text)
core/img/logo-icon.svg (with my own logo)
but nothig… I don’t see nothing of mine, only default owncloud. The only thing that I don’t find is “Enable the theme in the ownCloud Admin dashboard.” where is that?
I see General, Storage, Encryption, ecc…
thanks
do nobody reply me?
thanks
This should should show up in your admin backend as an own app where you can / should be able to enable it.
No, I don’t see any app with name “theme-example”… where have I mistake?
thanks
I found example-themes folder into owncloud/apps, I clone this folder and I changed icon and text into default.
I always see the “Integrity check”, how do I resolve this?
thanks
INVALID_HASH
- appinfo/info.xml
- core/css/styles.css
- core/img/favicon-touch.png
- core/img/favicon-touch.svg
- core/img/favicon.ico
- core/img/favicon.png
- core/img/favicon.svg
- core/img/logo-icon.png
- core/img/logo-icon.svg
- core/img/logo-mail.gif
- defaults.php
they are the files that I changed…
Simply I removed the file signature.json into folder appinfo into theme, after I rescan list file and voilà, all is ok.
bye
fliot
June 8, 2017, 3:20pm
9
I had to do more than just removing signature.json files,
I applied this generic solution:
Within Owncloud, use the code signing integrity features, without integrity check issues
Bye.
