- Install fresh copy of owncloud
- Login after setup
- Owncloud attempts to load up but after a few stops responding and dies
Owncloud should just load up fine and be accessible
Actual behavior
Owncloud displays a blank white box in front of the files app and the files app also loads a files app inside of itself. Entire page stops responding and Chrome alerts that the page is no longer responding with the option to kill the tab.
Red Hat Enterprise 7.4 (Maipo)
Nginx/1.10.2
Remote MySQL database
Server version: 5.7.19 MySQL Community Server (GPL)
10.0.3
Fresh install
No errors have been found
"system": {
"instanceid": "ocaq0h01coli",
"trusted_domains": [
"owncloud.mydomain.com"
"datadirectory": "\/media\/opt\/data\/",
"overwrite.cli.url": "http:\/\/owncloud.mydomain.com",
"dbtype": "mysql",
"version": "10.0.3.3",
"dbname": "owncloud",
"dbhost": "192.168.0.134",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"logtimezone": "UTC",
"installed": true
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.0
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.2
- notifications: 0.3.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.1
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- files_antivirus
- theme-example
- user_external
No
No
No
Google Chrome 61.0.3163.100 (Official Build) (64-bit)
Gentoo Linux
Error log is empty,
Access Log:
72.0.129.xx - - [10/Oct/2017:11:07:45 -0400] "GET / HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:45 -0400] "GET /apps/files/ HTTP/1.1" 200 30079 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:46 -0400] "GET /apps/files/cron.php HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:46 -0400] "GET /apps/files/undefined/img/notifications.svg HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:47 -0400] "GET /apps/files/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:47 -0400] "GET /apps/files/index.php/apps/firstrunwizard/wizard.php HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:47 -0400] "GET /apps/files/core/search/templates/part.results.html HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:47 -0400] "GET /apps/files/ HTTP/1.1" 200 30079 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:47 -0400] "GET /apps/files/ HTTP/1.1" 200 30077 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:48 -0400] "GET /apps/files/ HTTP/1.1" 200 30077 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
72.0.129.xx - - [10/Oct/2017:11:07:48 -0400] "GET /apps/files/ HTTP/1.1" 200 30079 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/61.0.3163.100 Safari/537.36" "-"
Empty
[browser.log](https://github.com/owncloud/core/files/1372446/browser.log)
Nginx Config
server {
listen 80;
listen [::]:80;
server_name owncloud.mydomain.com;
index index.html index.htm index.php;
# Path to the root of your installation
root /var/webapps/owncloud/;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# The following 2 rules are only needed for the user_webfinger app.
# Uncomment it if you're planning to use this app.
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
location = /.well-known/carddav {
return 301 $scheme://$host/remote.php/dav;
location = /.well-known/caldav {
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
# Enabling gzip would also make your server vulnerable to BREACH
# if no additional measures are done. See https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=773332
gzip off;
# Uncomment if your server is build with the ngx_pagespeed module
# This module is currently not supported.
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)/ {
return 404;
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) {
return 404;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
fastcgi_split_path_info ^(.+\.php)(/.*)$;
include fastcgi_params;
fastcgi_param SCRIPT_NAME $fastcgi_script_name; # necessary for owncloud to detect the contextroot https://github.com/owncloud/core/blob/v10.0.0/lib/private/AppFramework/Http/Request.php#L603
fastcgi_param PATH_INFO $fastcgi_path_info;
# fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; #Avoid sending the security headers twice
fastcgi_param front_controller_active true;
fastcgi_read_timeout 180; # increase default timeout e.g. for long running carddav/ caldav syncs with 1000+ entries
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
fastcgi_request_buffering off; #Available since NGINX 1.7.11
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
# Make sure it is BELOW the PHP block
location ~ \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "max-age=15778463";
# Add headers to serve security related headers (It is intended to have those duplicated to the ones above)
# Before enabling Strict-Transport-Security headers please read into this topic first.
#add_header Strict-Transport-Security "max-age=15552000; includeSubDomains";
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header X-Download-Options noopen;
add_header X-Permitted-Cross-Domain-Policies none;
# Optional: Don't log access to assets
access_log off;
location ~ \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg|map)$ {
add_header Cache-Control "public, max-age=7200";
# Optional: Don't log access to other assets
access_log off;
