Owncloud 10.0.4.4 DavFS issue
  1. Upgrade to owncloud 10.0.4
  2. Try to mount a davfs share
The Share should be mounted
/sbin/mount.davfs: mounting failed; the server does not support WebDAV
Web server: Apache 2.4
Database: mysql 5.7
PHP version: 5.6
ownCloud version: (see ownCloud admin page) 10.0.4.4
Updated from an older ownCloud or fresh install: Updated from 10.0.3.3
Where did you install ownCloud from: from repo download.owncloud.com
    "system": {
        "forcessl": true,
        "installed": true,
        "dbtype": "mysql",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "overwritehost": "",
        "overwriteprotocol": "",
        "theme": "",
        "3rdpartyroot": "",
        "3rdpartyurl": "",
        "defaultapp": "files",
        "knowledgebaseenabled": true,
        "knowledgebaseurl": "http:\/\/api.apps.owncloud.com\/v1",
        "appstoreenabled": true,
        "mail_smtpmode": "sendmail",
        "mail_smtphost": "127.0.0.1",
        "mail_smtpport": 25,
        "mail_smtpauth": false,
        "appcodechecker": "",
        "updatechecker": false,
        "logtimezone": "Europe\/Zurich",
        "logfile": "\/var\/log\/owncloud.log",
        "loglevel": 0,
        "log_authfailip": true,
        "log_type": "owncloud",
        "log_query": false,
        "debug": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": true
        "instanceid": "513e28974df26",
        "version": "10.0.4.4",
        "maintenance": false,
        "trusted_domains": [
            "gland.netoxygen.ch",
            "ge.netoxygen.ch",
            "cloud.netoxygen.ch"
        "trashbin_retention_obligation": "auto",
        "appstore.experimental.enabled": true
Enabled:
  - calendar: 1.5.4
  - comments: 0.3.0
  - configreport: 0.1.1
  - contacts: 1.5.3
  - dav: 0.3.2
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_external: 0.7.1
  - files_sharing: 0.10.1
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - market: 0.2.3
  - notifications: 0.3.2
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - templateeditor: 0.1
  - updatenotification: 0.2.1
Disabled:
  - encryption
  - external
  - theme-example
  - user_external
Are you using external storage, if yes which one: NO
Are you using encryption: NO
Are you using an external user-backend, if yes which one: NO
Browser: Davfs2
xxx.xxx.xxx:443 192.168.0.184 - - [07/Dec/2017:18:17:36 +0100] "OPTIONS /remote.php/webdav/ HTTP/1.1" 200 4378 "-" "davfs2/1.5.2 neon/0.30.1"
Nothing is logged
I did a few tests and could detect some strange things.
I test to mount davfs from demo.ownloud.org and it works. But demo uses version 10.0.3.3 (a version on wich it was working for me before the upgrade).
Cadaver is working on my 10.0.4.4 owncloud but not davfs.
I did some tests using curl and can see that a simple curl to remote/webdav without autentication retunr a code 200 instead of a code 401
curl -D - -X OPTIONS https:/xxx.xxx.xxx/remote.php/webdav/
HTTP/1.1 200 OK
Date: Thu, 07 Dec 2017 17:20:53 GMT
Server: Apache/2.4.18 (Ubuntu)
Set-Cookie: 513e28974df26=v4lef9aamd3vq82vnmseoeogr7; path=/; HttpOnly
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
Set-Cookie: oc_sessionPassphrase=CNa9pkjoDLG4qfFuJKbAfqkw4u0cmDxHn48h8mynSofwD6KzHtpy%2FN3OvEoWPq8oAnPcipfIbRuxtEWO4m475nJgYW9RfdDTkbOxSasE5sjsFLqWdI7rRn%2B2uWwY%2BKAy; path=/; secure; httponly
Content-Security-Policy: default-src 'none';
Access-Control-Allow-Headers: authorization,OCS-APIREQUEST,Origin,X-Requested-With,Content-Type,Access-Control-Allow-Origin,X-OC-Mtime,OC-Checksum,OC-Total-Length,Depth,Destination,Overwrite
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET,OPTIONS,POST,PUT,DELETE,MKCOL,PROPFIND,PATCH,PROPPATCH,REPORT,MOVE,COPY
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
X-Robots-Tag: none
X-Frame-Options: SAMEORIGIN
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
Content-Length: 0
Content-Type: text/html; charset=UTF-8
On demo
curl -D - -X OPTIONS https://demo.owncloud.org/remote.php/webdav/
HTTP/1.1 401 Unauthorized
Content-Length: 412
Content-Type: application/xml; charset=utf-8
Date: Thu, 07 Dec 2017 17:22:02 GMT
Pragma: no-cache
Server: Apache
Set-Cookie: ocgj9l8b2hha=ncb9c78r10dng4mhuvsu4nbmj2; path=/; HttpOnly
Set-Cookie: oc_sessionPassphrase=VMe9TPNuHvzwpPdl8qTbsBHNcn2Xw0xAh9ZjQpAXDBU8917cvBLt2geLGuV%2B%2BmEdenAilycACi8%2B1fWBBMzr3MIpV62ygpVpV5uorCy7qhEMwwPjcNpZxIODZGQvmZg3; path=/; secure; HttpOnly
Strict-Transport-Security: max-age=15768000; preload
Www-Authenticate: Basic realm="ownCloud"
X-Robots-Tag: none
X-Xss-Protection: 1; mode=block
<?xml version="1.0" encoding="utf-8"?>
<d:error xmlns:d="DAV:" xmlns:s="http://sabredav.org/ns">
  <s:exception>Sabre\DAV\Exception\NotAuthenticated</s:exception>
  <s:message>No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured, No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured</s:message>
</d:error>`
It appears that davfs make a first OPTIONS call without authentication, waits for a 401 and then proceed to authentication.
Here are my davfs logs:
When connecting to my owncloud
Dec  7 18:23:51 dreis-desktop mount.davfs: davfs2 1.5.2
Dec  7 18:23:56 dreis-desktop mount.davfs: Initializing webdav
Dec  7 18:23:56 dreis-desktop mount.davfs: HTTP session to https://xxx.xxx.xxx:443 begins.
Dec  7 18:23:56 dreis-desktop mount.davfs: ah_create, for WWW-Authenticate
Dec  7 18:23:56 dreis-desktop mount.davfs: Running pre_send hooks
Dec  7 18:23:56 dreis-desktop mount.davfs: Sending request headers:#012OPTIONS /remote.php/webdav/ HTTP/1.1#015#012User-Agent: davfs2/1.5.2 neon/0.30.1#015#012Keep-Alive: #015#012Connection: TE, Keep-Alive#015#012TE: trailers#015#012Host: xxx.xxx.xxx
Dec  7 18:23:56 dreis-desktop mount.davfs: Sending request-line and headers:
Dec  7 18:23:56 dreis-desktop mount.davfs: Doing DNS lookup on xxx.xxx.xxx..
Dec  7 18:23:56 dreis-desktop mount.davfs: req: Connecting to 192.168.0.1:443
Dec  7 18:23:56 dreis-desktop mount.davfs: Request sent; retry is 0.
Dec  7 18:23:56 dreis-desktop mount.davfs: [status-line] < HTTP/1.1 200 OK
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Date: Thu, 07 Dec 2017 17:23:56 GMT
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [date], Value: [Thu, 07 Dec 2017 17:23:56 GMT]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Server: Apache/2.4.18 (Ubuntu)
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [server], Value: [Apache/2.4.18 (Ubuntu)]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Set-Cookie: 513e28974df26=n3okeska5ece9ho3fnqrmf8o83; path=/; HttpOnly
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [513e28974df26=n3okeska5ece9ho3fnqrmf8o83; path=/; HttpOnly]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Expires: Thu, 19 Nov 1981 08:52:00 GMT
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [expires], Value: [Thu, 19 Nov 1981 08:52:00 GMT]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [cache-control], Value: [no-store, no-cache, must-revalidate, post-check=0, pre-check=0]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Pragma: no-cache
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [pragma], Value: [no-cache]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Set-Cookie: oc_sessionPassphrase=FBhgCuRqIYjJ8B144mqsZapghFNcFokFFcOOKTNTPz5TDoQX5rW0%%2BonY3rkig4st6clqpHSpH3T%%2BYAXZEz8npZk46dqOp0e%%2BV2S4%%2F6Fcpi96KqWGsLCaHs83C6ACnpMY; path=/; secure; httponly
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [oc_sessionPassphrase=FBhgCuRqIYjJ8B144mqsZapghFNcFokFFcOOKTNTPz5TDoQX5rW0%%2BonY3rkig4st6clqpHSpH3T%%2BYAXZEz8npZk46dqOp0e%%2BV2S4%%2F6Fcpi96KqWGsLCaHs83C6ACnpMY; path=/; secure; httponly]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Content-Security-Policy: default-src 'none';
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [content-security-policy], Value: [default-src 'none';]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Access-Control-Allow-Headers: authorization,OCS-APIREQUEST,Origin,X-Requested-With,Content-Type,Access-Control-Allow-Origin,X-OC-Mtime,OC-Checksum,OC-Total-Length,Depth,Destination,Overwrite
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [access-control-allow-headers], Value: [authorization,OCS-APIREQUEST,Origin,X-Requested-With,Content-Type,Access-Control-Allow-Origin,X-OC-Mtime,OC-Checksum,OC-Total-Length,Depth,Destination,Overwrite]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Access-Control-Allow-Origin: *
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [access-control-allow-origin], Value: [*]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Access-Control-Allow-Methods: GET,OPTIONS,POST,PUT,DELETE,MKCOL,PROPFIND,PATCH,PROPPATCH,REPORT,MOVE,COPY
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [access-control-allow-methods], Value: [GET,OPTIONS,POST,PUT,DELETE,MKCOL,PROPFIND,PATCH,PROPPATCH,REPORT,MOVE,COPY]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] X-Content-Type-Options: nosniff
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [x-content-type-options], Value: [nosniff]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] X-XSS-Protection: 1; mode=block
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [x-xss-protection], Value: [1; mode=block]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] X-Robots-Tag: none
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [x-robots-tag], Value: [none]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] X-Frame-Options: SAMEORIGIN
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [x-frame-options], Value: [SAMEORIGIN]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] X-Download-Options: noopen
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [x-download-options], Value: [noopen]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] X-Permitted-Cross-Domain-Policies: none
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [x-permitted-cross-domain-policies], Value: [none]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Content-Length: 0
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [content-length], Value: [0]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Keep-Alive: timeout=5, max=100
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [keep-alive], Value: [timeout=5, max=100]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Connection: Keep-Alive
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [connection], Value: [Keep-Alive]
Dec  7 18:23:56 dreis-desktop mount.davfs: [hdr] Content-Type: text/html; charset=UTF-8
Dec  7 18:23:56 dreis-desktop mount.davfs: Header Name: [content-type], Value: [text/html; charset=UTF-8]
Dec  7 18:23:56 dreis-desktop mount.davfs: End of headers.
Dec  7 18:23:56 dreis-desktop mount.davfs: Running post_headers hooks
Dec  7 18:23:56 dreis-desktop mount.davfs: Running post_send hooks
Dec  7 18:23:56 dreis-desktop mount.davfs: ah_post_send (#0), code is 200 (want 401), WWW-Authenticate is (none)
Dec  7 18:23:56 dreis-desktop mount.davfs: Request ends, status 200 class 2xx, error line:#012200 OK
Dec  7 18:23:56 dreis-desktop mount.davfs: Running destroy hooks.
Dec  7 18:23:56 dreis-desktop mount.davfs: Request ends.
On demo.owncloud.org:
Dec  7 18:25:38 dreis-desktop mount.davfs: davfs2 1.5.2
Dec  7 18:25:41 dreis-desktop mount.davfs: Initializing webdav
Dec  7 18:25:41 dreis-desktop mount.davfs: HTTP session to https://demo.owncloud.org:443 begins.
Dec  7 18:25:41 dreis-desktop mount.davfs: ah_create, for WWW-Authenticate
Dec  7 18:25:41 dreis-desktop mount.davfs: Running pre_send hooks
Dec  7 18:25:41 dreis-desktop mount.davfs: Sending request headers:#012OPTIONS /remote.php/webdav/ HTTP/1.1#015#012User-Agent: davfs2/1.5.2 neon/0.30.1#015#012Keep-Alive: #015#012Connection: TE, Keep-Alive#015#012TE: trailers#015#012Host: demo.owncloud.org
Dec  7 18:25:41 dreis-desktop mount.davfs: Sending request-line and headers:
Dec  7 18:25:41 dreis-desktop mount.davfs: Doing DNS lookup on demo.owncloud.org...
Dec  7 18:25:41 dreis-desktop mount.davfs: req: Connecting to 136.243.60.151:443
Dec  7 18:25:41 dreis-desktop mount.davfs: Request sent; retry is 0.
Dec  7 18:25:41 dreis-desktop mount.davfs: [status-line] < HTTP/1.1 401 Unauthorized
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Cache-Control: no-store, no-cache, must-revalidate
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [cache-control], Value: [no-store, no-cache, must-revalidate]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Content-Length: 412
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [content-length], Value: [412]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Content-Security-Policy: default-src 'none';
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [content-security-policy], Value: [default-src 'none';]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Content-Type: application/xml; charset=utf-8
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [content-type], Value: [application/xml; charset=utf-8]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Date: Thu, 07 Dec 2017 17:25:41 GMT
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [date], Value: [Thu, 07 Dec 2017 17:25:41 GMT]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Expires: Thu, 19 Nov 1981 08:52:00 GMT
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [expires], Value: [Thu, 19 Nov 1981 08:52:00 GMT]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Pragma: no-cache
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [pragma], Value: [no-cache]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Server: Apache
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [server], Value: [Apache]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Set-Cookie: ocgj9l8b2hha=kegme5fuimqfo9bbkqb5inp4t6; path=/; HttpOnly
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [ocgj9l8b2hha=kegme5fuimqfo9bbkqb5inp4t6; path=/; HttpOnly]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Set-Cookie: oc_sessionPassphrase=Xt80uNgZY6lCUHaRxLQ6%%2FlMN%%2B3gC8bDeH4yCjUvGS%%2F41LZeFomiu6bpAUMBcbSKAXDhBdadddF%%2B%%2F4isQ3LtBK2du16XPsGqPa1EtVo67zmHuASHxhKgx%%2BfBQ2EXCCBBw; path=/; secure; HttpOnly
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [oc_sessionPassphrase=Xt80uNgZY6lCUHaRxLQ6%%2FlMN%%2B3gC8bDeH4yCjUvGS%%2F41LZeFomiu6bpAUMBcbSKAXDhBdadddF%%2B%%2F4isQ3LtBK2du16XPsGqPa1EtVo67zmHuASHxhKgx%%2BfBQ2EXCCBBw; path=/; secure; HttpOnly]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Strict-Transport-Security: max-age=15768000; preload
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [strict-transport-security], Value: [max-age=15768000; preload]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] Www-Authenticate: Basic realm="ownCloud"
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [www-authenticate], Value: [Basic realm="ownCloud"]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] X-Content-Type-Options: nosniff
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [x-content-type-options], Value: [nosniff]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] X-Download-Options: noopen
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [x-download-options], Value: [noopen]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] X-Frame-Options: SAMEORIGIN
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [x-frame-options], Value: [SAMEORIGIN]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] X-Permitted-Cross-Domain-Policies: none
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [x-permitted-cross-domain-policies], Value: [none]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] X-Robots-Tag: none
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [x-robots-tag], Value: [none]
Dec  7 18:25:41 dreis-desktop mount.davfs: [hdr] X-Xss-Protection: 1; mode=block
Dec  7 18:25:41 dreis-desktop mount.davfs: Header Name: [x-xss-protection], Value: [1; mode=block]
Dec  7 18:25:41 dreis-desktop mount.davfs: End of headers.
Dec  7 18:25:41 dreis-desktop mount.davfs: Running post_headers hooks
Dec  7 18:25:41 dreis-desktop mount.davfs: Reading 412 bytes of response body.
Dec  7 18:25:41 dreis-desktop mount.davfs: Got 322 bytes.
Dec  7 18:25:41 dreis-desktop mount.davfs: Reading 90 bytes of response body.
Dec  7 18:25:41 dreis-desktop mount.davfs: Got 90 bytes.
Dec  7 18:25:41 dreis-desktop mount.davfs: Running post_send hooks
Dec  7 18:25:41 dreis-desktop mount.davfs: ah_post_send (#0), code is 401 (want 401), WWW-Authenticate is Basic realm="ownCloud"
Dec  7 18:25:41 dreis-desktop mount.davfs: auth: Got challenge (code 401).
Dec  7 18:25:41 dreis-desktop mount.davfs: auth: Got 'Basic' challenge.
Dec  7 18:25:41 dreis-desktop mount.davfs: auth: Trying Basic challenge...
Dec  7 18:25:41 dreis-desktop mount.davfs: auth: Accepted Basic challenge.
Dec  7 18:25:41 dreis-desktop mount.davfs: auth: Sending 'Basic' response.
Dec  7 18:25:41 dreis-desktop mount.davfs: Sending request headers:#012OPTIONS /remote.php/webdav/ HTTP/1.1#015#012User-Agent: davfs2/1.5.2 neon/0.30.1#015#012Keep-Alive: #015#012Connection: TE, Keep-Alive#015#012TE: trailers#015#012Host: demo.owncloud.org#015#012Authorization: xxxxxxxxxxxxxxxxxx
Dec  7 18:25:41 dreis-desktop mount.davfs: Request sent; retry is 1.
Dec  7 18:25:50 dreis-desktop mount.davfs: [status-line] < HTTP/1.1 200 OK
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Accept-Ranges: bytes
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [accept-ranges], Value: [bytes]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Allow: OPTIONS, GET, HEAD, DELETE, PROPFIND, PUT, PROPPATCH, COPY, MOVE, REPORT
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [allow], Value: [OPTIONS, GET, HEAD, DELETE, PROPFIND, PUT, PROPPATCH, COPY, MOVE, REPORT]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Cache-Control: no-store, no-cache, must-revalidate
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [cache-control], Value: [no-store, no-cache, must-revalidate]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Content-Length: 0
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [content-length], Value: [0]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Content-Security-Policy: default-src 'none';
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [content-security-policy], Value: [default-src 'none';]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Content-Type: text/html; charset=UTF-8
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [content-type], Value: [text/html; charset=UTF-8]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Date: Thu, 07 Dec 2017 17:25:41 GMT
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [date], Value: [Thu, 07 Dec 2017 17:25:41 GMT]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Dav: 1, 3, extended-mkcol
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [dav], Value: [1, 3, extended-mkcol]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Expires: Thu, 19 Nov 1981 08:52:00 GMT
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [expires], Value: [Thu, 19 Nov 1981 08:52:00 GMT]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Ms-Author-Via: DAV
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [ms-author-via], Value: [DAV]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Pragma: no-cache
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [pragma], Value: [no-cache]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Server: Apache
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [server], Value: [Apache]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Set-Cookie: ocgj9l8b2hha=orp8cdblk3kcvu14808qi936t4; path=/; HttpOnly
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [ocgj9l8b2hha=orp8cdblk3kcvu14808qi936t4; path=/; HttpOnly]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Set-Cookie: oc_sessionPassphrase=1c65yXjYeMHw8GMzizlc9%%2F4x2uIsUA2f5zJxEn%%2BQJduLkMRu%%2FE4HtFkrccB9YoeQlsKIlovhdsRcgKSHCurIjsyWKqzjq3NgRGJVHpg9%%2ByuUs%%2Bya9zY1uOuY5HtmlUCa; path=/; secure; HttpOnly
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [oc_sessionPassphrase=1c65yXjYeMHw8GMzizlc9%%2F4x2uIsUA2f5zJxEn%%2BQJduLkMRu%%2FE4HtFkrccB9YoeQlsKIlovhdsRcgKSHCurIjsyWKqzjq3NgRGJVHpg9%%2ByuUs%%2Bya9zY1uOuY5HtmlUCa; path=/; secure; HttpOnly]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Set-Cookie: ocgj9l8b2hha=s2vlugbs714b4ajrcjjnlpv0k4; path=/; secure; HttpOnly
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [ocgj9l8b2hha=s2vlugbs714b4ajrcjjnlpv0k4; path=/; secure; HttpOnly]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Set-Cookie: cookie_test=test; expires=Thu, 07-Dec-2017 18:25:50 GMT; Max-Age=3600
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [cookie_test=test; expires=Thu, 07-Dec-2017 18:25:50 GMT; Max-Age=3600]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] Strict-Transport-Security: max-age=15768000; preload
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [strict-transport-security], Value: [max-age=15768000; preload]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] X-Content-Type-Options: nosniff
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [x-content-type-options], Value: [nosniff]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] X-Download-Options: noopen
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [x-download-options], Value: [noopen]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] X-Frame-Options: SAMEORIGIN
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [x-frame-options], Value: [SAMEORIGIN]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] X-Permitted-Cross-Domain-Policies: none
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [x-permitted-cross-domain-policies], Value: [none]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] X-Robots-Tag: none
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [x-robots-tag], Value: [none]
Dec  7 18:25:50 dreis-desktop mount.davfs: [hdr] X-Xss-Protection: 1; mode=block
Dec  7 18:25:50 dreis-desktop mount.davfs: Header Name: [x-xss-protection], Value: [1; mode=block]
Dec  7 18:25:50 dreis-desktop mount.davfs: End of headers.
Dec  7 18:25:50 dreis-desktop mount.davfs: Running post_headers hooks
Dec  7 18:25:50 dreis-desktop mount.davfs: Running post_send hooks
Dec  7 18:25:50 dreis-desktop mount.davfs: ah_post_send (#1), code is 200 (want 401), WWW-Authenticate is (none)
Dec  7 18:25:50 dreis-desktop mount.davfs: Request ends, status 200 class 2xx, error line:#012200 OK
Dec  7 18:25:50 dreis-desktop mount.davfs: Running destroy hooks.
Dec  7 18:25:50 dreis-desktop mount.davfs: Request ends.
Dec  7 18:25:50 dreis-desktop mount.davfs: ah_create, for WWW-Authenticate
Dec  7 18:25:50 dreis-desktop mount.davfs: Running pre_send hooks
Dec  7 18:25:50 dreis-desktop mount.davfs: auth: Sending 'Basic' response.
Dec  7 18:25:50 dreis-desktop mount.davfs: Sending request headers:#012PROPFIND /remote.php/webdav/ HTTP/1.1#015#012User-Agent: davfs2/1.5.2 neon/0.30.1#015#012Connection: TE#015#012TE: trailers#015#012Host: demo.owncloud.org#015#012Depth: 1#015#012Content-Length: 257#015#012Content-Type: application/xml#015#012Authorization: xxxxxxxxxxxxxxxxxx
Dec  7 18:25:50 dreis-desktop mount.davfs: Sending request-line and headers:
Dec  7 18:25:50 dreis-desktop mount.davfs: Sending request body:
Dec  7 18:25:50 dreis-desktop mount.davfs: Request sent; retry is 1.
Dec  7 18:25:51 dreis-desktop mount.davfs: [status-line] < HTTP/1.1 207 Multi-Status
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Cache-Control: no-store, no-cache, must-revalidate
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [cache-control], Value: [no-store, no-cache, must-revalidate]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Content-Length: 2048
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [content-length], Value: [2048]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Content-Security-Policy: default-src 'none';
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [content-security-policy], Value: [default-src 'none';]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Content-Type: application/xml; charset=utf-8
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [content-type], Value: [application/xml; charset=utf-8]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Date: Thu, 07 Dec 2017 17:25:50 GMT
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [date], Value: [Thu, 07 Dec 2017 17:25:50 GMT]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Dav: 1, 3, extended-mkcol
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [dav], Value: [1, 3, extended-mkcol]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Expires: Thu, 19 Nov 1981 08:52:00 GMT
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [expires], Value: [Thu, 19 Nov 1981 08:52:00 GMT]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Pragma: no-cache
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [pragma], Value: [no-cache]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Server: Apache
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [server], Value: [Apache]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Set-Cookie: ocgj9l8b2hha=jkh4koh95cjq4v1t6imofl8a83; path=/; HttpOnly
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [ocgj9l8b2hha=jkh4koh95cjq4v1t6imofl8a83; path=/; HttpOnly]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Set-Cookie: oc_sessionPassphrase=tUNkQFz9aCqHYIeJsEADndojKnPScXhHpnK9ygtKNRyuHhOUIG3ldTKo2tFnLFSuVuYyTk6yWAFDWMoYoej74tlGJddsUs%%2F07opRY2jgxR91%%2F1Gmh%%2FfdfT0i2nHZ%%2BO2j; path=/; secure; HttpOnly
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [oc_sessionPassphrase=tUNkQFz9aCqHYIeJsEADndojKnPScXhHpnK9ygtKNRyuHhOUIG3ldTKo2tFnLFSuVuYyTk6yWAFDWMoYoej74tlGJddsUs%%2F07opRY2jgxR91%%2F1Gmh%%2FfdfT0i2nHZ%%2BO2j; path=/; secure; HttpOnly]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Set-Cookie: ocgj9l8b2hha=i76d3gg45m8gvd6grsr2kf9ku7; path=/; secure; HttpOnly
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [ocgj9l8b2hha=i76d3gg45m8gvd6grsr2kf9ku7; path=/; secure; HttpOnly]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Set-Cookie: cookie_test=test; expires=Thu, 07-Dec-2017 18:25:51 GMT; Max-Age=3600
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [set-cookie], Value: [cookie_test=test; expires=Thu, 07-Dec-2017 18:25:51 GMT; Max-Age=3600]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Strict-Transport-Security: max-age=15768000; preload
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [strict-transport-security], Value: [max-age=15768000; preload]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] Vary: Brief,Prefer
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [vary], Value: [Brief,Prefer]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] X-Content-Type-Options: nosniff
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [x-content-type-options], Value: [nosniff]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] X-Download-Options: noopen
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [x-download-options], Value: [noopen]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] X-Frame-Options: SAMEORIGIN
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [x-frame-options], Value: [SAMEORIGIN]
Dec  7 18:25:51 dreis-desktop mount.davfs: [hdr] X-Permitted-Cross-Domain-Policies: none
Dec  7 18:25:51 dreis-desktop mount.davfs: Header Name: [x-permitted-cross-domain-policies], Value: [none]
Any help would be great.
Regards,
David
Shouldn’t something which worked before and stopped to work after an update be reported to a bugtracker rather then user forums?
Same issue with my docker setup. I’ve upgraded to 10.0.4 from 10.0.3 and now WebDav isn’t working. Has this issue been reported on github yet?
Workaround does already exist and works. Patch is worked on and will then be in 10.0.5.
does someone know if this severe issue was fixed in 10.0.5? I can not find it in the changelog.
FYI, if you don’t want to do a WebDAV mount, you can also use the ownCloud desktop client’s VFS mode which downloads files on double click (other files are just “placeholders”).
