I tried to setup ownCloud 10.0.4 and 10.0.5 on a Rasbian 9 Stretch now three times. I followed this Tutorial, however I also checked the ownCloud documentation about the installation process in verfied it for correctness. Unfortunately, the final setup process using the web installer fails without any message. It just keep saying “Finishing setup…” (well the text on the button, for me it is in german). I assume all database entries are written and also the config.php is written. However, there is one line missing:
‘installed’ => true,
Here the config how it is written:
><?php
$CONFIG = array (
‘updatechecker’ => false,
‘instanceid’ => ‘oci9gu827tnv’,
‘passwordsalt’ => ‘OkKejz8UzJViAB1wZdmMrqciHvdru8’,
‘secret’ => ‘tB1amGKv75Sh042h7Z41YKLJmJen37AwCog4RaCYYbFmDrBd’,
‘trusted_domains’ =>
array (
0 => ‘XXX’,
‘datadirectory’ => ‘/media/usb-hdd/owncloud/data’,
‘overwrite.cli.url’ => ‘XXX’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘10.0.5.4’,
‘dbname’ => ‘owncloud’,
‘dbhost’ => ‘localhost’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘owncloud’,
‘dbpassword’ => ‘XXX’,
Changing the installed value to true allows me to use ownCloud but I can’t verify if it is installed correctly, can I? For instance is the sync using the Windows App super slow (I actually think is is only the upload). But this could be another issue. It is not related to network and hardware support of the Raspberry Pi, also already did some Benchmarking.
Also tried to run ownCloud 7 using Rasbian Jessy - it was working.
Are this known issues?
