I upgraded from OC 10.0.7 to OC 10.0.8. Since then, basic authentication seems not to be working as expected any more - nor does the app password function, when OAuth2 is not supported by the client application.
Up to 10.0.7, the mobile application successfully exchanged data with OC, sending the basic auth info with every request.
OC 10.0.7 would respond with the content as requested PLUS an oc_sessionPassphrase.
Since 10.0.8, this oc_sessionPassphrase seems to be required for any content-call.
As an alternative, I set up an App password and used it together with my username. But I still cannot get Owncloud to respond with the data (I checked the basic auth header, it really contained the app password).
Any ideas on that? Is there a way to reestablish the basic auth behavior OC used to have?
Thanks a lot in advance.
Stefan
- log on to the OC GUI using the username
- create an app password
- provide that app password in combination with the username used
- try to receive the notes
Owncloud should return the notes, since the app password should be enough
Owncloud responds with the oc_passphrase but does not return the content requested
Ubuntu 16.04 / Raspberry Jessie
Apache2
MySQL
Ubuntu: PHP 7.0.30-0ubuntu0.16.04.1 (cli) ( NTS )
Raspberry: PHP 5.6.36-0+deb8u1 (cli) (built: Jun 26 2018 22:52:39)
ownCloud 10.0.8 (stable)
updated from 10.0.7 (stable)
Owncloud’s Ubuntu Repos
dont know
see https://gist.github.com/stefan-schilling/0902dd1507641850454f3b8730e78071
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.4
- notes: 2.0.2
- notifications: 0.3.3
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- theme-example
- user_external
no
no
no
nextcloud-notes/0.16.1 (Android)
Android 7
nothing relevant here: HTTP Status code 200 is returned
nothing reported
Wireshark log (1st call using Postman, requesting oc_passphrase)
GET /owncloud/index.php/apps/notes/api/v0.2/notes HTTP/1.1
Host: 192.168.178.30
Connection: keep-alive
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.99 Safari/537.36
Cache-Control: no-cache
Authorization: Basic c3RlZmFuOkZPVVFXLVFDU0FVLVdPWkpLLU9URUxY
Postman-Token: 5b1baeff-b2c7-2c6d-5996-8bff0e615f68
Accept: */*
Accept-Encoding: gzip, deflate
Accept-Language: de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
HTTP/1.1 200 OK
Date: Tue, 03 Jul 2018 16:02:17 GMT
Server: Apache/2.4.18 (Ubuntu)
Set-Cookie: octta7j2xedi=7koualce3qu7t0783src2ntb85; path=/owncloud; HttpOnly
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-cache, must-revalidate
Pragma: no-cache
Set-Cookie: oc_sessionPassphrase=ib7g76I67gCd2qd%2BcW616H%2BFFqS1uLFZUjPN6li0ylquK9XzNqlyp40atKAPZGCGelps2LXvC3SCUOEy97T2JRceqqctD1N6VJQeICyyA32oU2SEF02DOBKZC3E2Qmuk; path=/owncloud; HttpOnly
Content-Security-Policy: default-src 'none';manifest-src 'self';script-src 'self' 'unsafe-eval';style-src 'self' 'unsafe-inline';img-src 'self' data: blob:;font-src 'self';connect-src 'self';media-src 'self'
Set-Cookie: octta7j2xedi=bklalbi2kpat9s7senlf186583; path=/owncloud; HttpOnly
Content-Length: 2
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
X-Robots-Tag: none
X-Frame-Options: SAMEORIGIN
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Content-Type: application/json; charset=utf-8
Wireshark log (2nd call using Postman, content being returned)
GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1
Accept: */*
requesttoken: MxwLEGZCEwtBbgECAlNELxUQfiJxDBI+ISEXODI5SyE=:IZlzIuTb68kcP+wEgJIh44+jwn8AXZreLRu2gV6smoo=
DNT: 1
X-Requested-With: XMLHttpRequest
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/67.0.3396.87 Safari/537.36 OPR/54.0.2952.41
OCS-APIREQUEST: true
Cookie: oc_sessionPassphrase=RKCX796HGL%2B7Vlb6vugdc9xvuKYNHReg3pivBH%2Bixw7o1V3p0%2FbFI%2Bhoa83PnA4hEQ4Ca51iZUV%2FY4EGLqPomWSnU%2BA3EMYU3vCyAGjfXEDLITL80jZMq6J7Gb%2FEAWte; ocygaynly7kz=4mqj0b34fopg988iv5ufd969i7; octta7j2xedi=kidjhnq79bmk85uffvct2dqp94
If-None-Match: d751713988987e9331980363e24189ce
HTTP/1.1 200 OK
Pragma: no-cache
ETag: d751713988987e9331980363e24189ce
Content-Length: 108
X-Robots-Tag: none
{"ocs":{"meta":{"status":"ok","statuscode":200,"message":null,"totalitems":"","itemsperpage":""},"data":[]}}
Wireshark log (call using Notes app with the app password, no subsequent call expected / done)
Connection: Close
User-Agent: nextcloud-notes/0.16.1 (Android)
HTTP/1.1 200 OK
Date: Tue, 03 Jul 2018 15:28:26 GMT
Set-Cookie: octta7j2xedi=liro6097oh7m73rfbp270pfef6; path=/owncloud; HttpOnly
Pragma: no-cache
Set-Cookie: oc_sessionPassphrase=mTxRhQGrsiTO0CSsjvAqodoiZ5AVFdWwjLgiu9GNtWi7uUwN13O5es%2BaAMOcI48hi83g5ZIuWqCZ4L%2FtCtZl3zUGSRSzDEHDsF%2FWYiPjw%2FEOubYH7oQnHKhoYBFw00qU; path=/owncloud; HttpOnly
Set-Cookie: octta7j2xedi=ub07anli5r9q8p4s54d8ioo4v4; path=/owncloud; HttpOnly
Content-Length: 2
X-Robots-Tag: none
Connection: close
