- Add CardDav account in Mac OS X Contact Application.
- First contacts sync is partly successful - not all contact are synchronisieren.
- All new create Contacts within the Mac OSX contact application are not synchronised back to the owncloud.
iOS address book app working well - all changed/new contacts are synched to the owncloud and are see via Webbrowser and on other iOS devices.
See above
See above
Mac OS X 10.13.6 (High Sierra)
nginx/1.11.2
MariaDB mysql Ver 15.1 Distrib 10.1.14-MariaDB, for FreeBSD10.1 (amd64) using readline 5.2
PHP 7.0.8 (cli)
10.0.9
Updated from 10.0.8
Official tar.
`No errors have been found.``
Safari
See above
{"reqId":"GpjToAhiSlNurqZDqkT2","level":4,"time":"2018-09-16T10:07:50+00:00","remoteAddr":"192.168.2.72","user":"Familie","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Familie\/Kontakte\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"cahTTlPAuIdXupTONsDz","level":4,"time":"2018-09-16T10:07:50+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"ji9QLyWeh5GTabCSEmVX","level":2,"time":"2018-09-16T10:08:03+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"dav","method":"DELETE","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/369e8566-57ff-496f-88e9-d41fd2dcdae2.vcf","message":"Could not get node for path: \"addressbooks\/users\/Denis\/Denis privat\/369e8566-57ff-496f-88e9-d41fd2dcdae2.vcf\" : Card not found"}
{"reqId":"oPFaFm56l1vqzhxfHqdL","level":4,"time":"2018-09-16T10:08:03+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"aOA1J54CWDvUEhRG6BRb","level":4,"time":"2018-09-16T10:09:34+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"gmxFFYYnPHotUDlxrRow","level":4,"time":"2018-09-16T10:09:44+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"BaFKZbIyTLrOpNvmaQd1","level":4,"time":"2018-09-16T10:10:03+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"ydTUpjk38cSd2xHxZTbL","level":4,"time":"2018-09-16T10:10:13+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"webdav","method":"REPORT","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/","message":"Exception: HTTP\/1.1 403 Invalid or unknown sync token: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\InvalidSyncToken\",\"Message\":\"Invalid or unknown sync token\",\"Code\":0,\"Trace\":\"#0 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php(65): Sabre\\\\DAV\\\\Sync\\\\Plugin->syncCollection('addressbooks\\\/us...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport))\\n#1 [internal function]: Sabre\\\\DAV\\\\Sync\\\\Plugin->Sabre\\\\DAV\\\\Sync\\\\{closure}('{DAV:}sync-coll...', Object(Sabre\\\\DAV\\\\Xml\\\\Request\\\\SyncCollectionReport), 'addressbooks\\\/us...')\\n#2 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Object(Closure), Array)\\n#3 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(718): Sabre\\\\Event\\\\EventEmitter->emit('report', Array)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpReport(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:REPORT', Array)\\n#7 \\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(282): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/usr\\\/local\\\/www\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#10 \\\/usr\\\/local\\\/www\\\/owncloud\\\/remote.php(165): require_once('\\\/usr\\\/local\\\/www\\\/...')\\n#11 {main}\",\"File\":\"\\\/usr\\\/local\\\/www\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Sync\\\/Plugin.php\",\"Line\":123}"}
{"reqId":"eEJZhxJMJbhzsfaP6T2C","level":2,"time":"2018-09-16T10:15:49+00:00","remoteAddr":"192.168.2.72","user":"Denis","app":"dav","method":"DELETE","url":"\/remote.php\/dav\/addressbooks\/users\/Denis\/Denis%20privat\/18cf0a74-7a55-410f-810f-673f41183d74.vcf","message":"Could not get node for path: \"addressbooks\/users\/Denis\/Denis privat\/18cf0a74-7a55-410f-810f-673f41183d74.vcf\" : Card not found"}`
#### Browser log
c) …
