1.Install owncloud then upgrade to latest.
2.
3.
Should upgrade and not fail
I need help solving this issue. I am getting a integrity check fail missing files.
the missing files are
/updater/vender/autoload.php
/updater/vender/autoload_static.php
-/updater/vender/autoload_real.php
I tried to use winscp and a download of owncloud 10.4 to copy the files over but not sure where to copy the files to what directory since there is a ton of directory’s. In ownlcoud it a under /Var/www/owncloud/updates/vender/ but in the winscp program to transfer i see everything and not sure where UCS store them and what I need to do to fix this issue.
Thank you
Brock
Univention server
10.08
fresh install of 10.07
owncloud.org VM appliance
