I’m using owncloud 10.1.1.1 server, and accessing my excel files (csv, xlsx) using webdav in windows 10.
But the excel app cannot display anything (blanks).
- install owncloud in debian stretch in odroid c2
- define local storage which connect to external hard drive
- map drive to the storage using windows 10 laptop
- open the folder in windows explorer
- double click the excel file to view the content using microsoft excel
- microsoft excel app open but did not show anything
File content shown in microsoft excel
File content not show in microsoft excel (blanks)
Operating system: Debian 9.12
Web server: Apache
Database: MariaDB 10.1.44
PHP version: 7.0.33-0+deb9u7
ownCloud version: 10.1.1.1
https://github.com/alexissinglaire/odroidc2owncloud/blob/master/config.json
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
**List of activated apps:**
**Are you using encryption:** no
**Are you using an external user-backend, if yes which one:** no
SELECT * FROM oc_appconfig
WHERE appid
= ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:** Windows 10
### Logs
#### Web server error log
[04/Apr/2020:08:48:29 +0000] “GET /owncloud/remote.php/webdav/nasstorage1/dummy_data1.xlsx HTTP/1.1” 200 14464 “-” “Microsoft-WebDAV-MiniRedir/10.0.18363”
[04/Apr/2020:08:48:29 +0000] “GET /owncloud/ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1” 200 1114 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.149 Safari/537.36”
[04/Apr/2020:08:48:41 +0000] “PROPFIND /owncloud HTTP/1.1” 301 586 “-” “Microsoft-WebDAV-MiniRedir/10.0.18363”
[04/Apr/2020:08:48:41 +0000] “PROPFIND /owncloud/ HTTP/1.1” 405 743 “-” “Microsoft-WebDAV-MiniRedir/10.0.18363”
[04/Apr/2020:08:48:41 +0000] “PROPFIND /owncloud/remote.php/webdav/nasstorage1 HTTP/1.1” 207 1173 “-” “Microsoft-WebDAV-MiniRedir/10.0.18363”
[04/Apr/2020:08:48:41 +0000] “OPTIONS /owncloud/remote.php/webdav/nasstorage1/ HTTP/1.1” 401 1313 “-” “Microsoft Office Excel 2014”
[04/Apr/2020:08:48:41 +0000] “OPTIONS /owncloud/remote.php/webdav/nasstorage1/ HTTP/1.1” 401 1307 “-” “Microsoft Office Excel”
[04/Apr/2020:08:48:41 +0000] “OPTIONS /owncloud/remote.php/webdav/nasstorage1/ HTTP/1.1” 401 1307 “-” “Microsoft Office Excel 2014”
[04/Apr/2020:08:48:41 +0000] “OPTIONS /owncloud/remote.php/webdav/nasstorage1/ HTTP/1.1” 401 1031 “-” “Microsoft Office Excel”
[04/Apr/2020:08:48:42 +0000] “HEAD /owncloud/remote.php/webdav/nasstorage1/dummy_data1.xlsx HTTP/1.1” 401 598 “-” “Microsoft Office Excel 2014”
