- Download Zimbra Drive apps on OwnCloud marketplace.
- mv the folder to /var/www/owncloud/apps.
- Go to disabled apps to install Zimbra Drive apps.
Apps installed.
This app cannot be installed because the following dependencies are not fulfilled:
- ownCloud 10.0 or lower is required.
Ubuntu 16.04 LTS
Apache2
SQLite
{“installed”:true,“maintenance”:false,“needsDbUpgrade”:false,“version”:“10.1.0.4”,“versionstring”:“10.1.0”,“edition”:“Community”,“productname”:“ownCloud”}
fresh install
wget -qO- https://download.owncloud.org/download/repositories/stable/Ubuntu_16.04/Release.key | sudo apt-key add -
root@x:/home/x# cat /var/www/owncloud/config/config.php
