- Install Owncloud container on Debian testing
- Configure it to use an external PostgreSQL database
- When everything is up, change the DNS name of the machine.
Login should be possible and the list of files should appear after login.
Login mask appears and after entering a correct username and password, the login mask reappears. The URL in the browser changes from https://www.theosys.at/owncloud/login
to https://www.theosys.at/owncloud/login?redirect_url=%252Fapps%252Ffiles%252F
I found some posts with similar errors, but no working solution. I tried almoust everything I could find, but nothing worked.
Hint: If I remove the options OWNCLOUD_OVERWRITE_WEBROOT=/owncloud
and OWNCLOUD_OVERWRITE_PROTOCOL=https
from the docker configuration, I can login by calling the docker instance on port 8080 direct. But then the ProxyPass of the WEB server doesn’t work any more.
Operating system: Linux Debian testing (12)
Web server: Apache 2.5.57 used as frontend.
Database: PostgreSQL 15
PHP version: 7.4 (build into container)
ownCloud version: 10.12.1.3
Where did you install ownCloud from: The official page
# docker-compose exec owncloud occ config:list
"system": {
"apps_paths": [
"url": "\/apps",
"writable": false
"path": "\/var\/www\/owncloud\/custom",
"url": "\/custom",
"writable": true
"trusted_domains": [
"localhost",
"127.0.0.1",
"www.theosys.at",
"10.x.x.x",
"theosys.theosys.at",
"10.x.x.x"
"datadirectory": "\/mnt\/data\/files",
"dbtype": "pgsql",
"dbhost": "10.x.x.x:5432",
"dbname": "owncloud",
"dbtableprefix": "oc_",
"log_type": "owncloud",
"supportedDatabases": [
"sqlite",
"mysql",
"pgsql"
"upgrade.disable-web": true,
"default_language": "de",
"logfile": "\/mnt\/data\/files\/owncloud.log",
"filelocking.enabled": true,
"memcache.distributed": "\\OC\\Memcache\\Redis",
"redis": {
"host": "redis",
"port": "6379"
"version": "10.12.1.3",
"logtimezone": "Europe\/Vienna",
"installed": true,
"instanceid": "oc3jdpobfihe",
"mail_smtpmode": "smtp",
"mail_smtpport": 25,
"mail_smtpauthtype": "PLAIN",
"maintenance": false,
"htaccess.RewriteBase": "\/",
"trusted_proxies": [
"localhost",
"127.0.0.1",
"www.theosys.at",
"10.x.x.x",
"10.x.x.x"
"overwrite.cli.url": "http:\/\/localhost:8080\/",
"loglevel": 0,
"overwritewebroot": "\/owncloud",
"overwriteprotocol": "https"
"apps": {
"activity": {
"types": "filesystem",
"enabled": "yes",
"installed_version": "2.7.1"
"backgroundjob": {
"lastjob": "17"
"calendar": {
"signed": "true",
"installed_version": "2.0.0",
"types": "",
"enabled": "yes"
"comments": {
"installed_version": "0.3.0",
"types": "logging,dav",
"enabled": "yes"
"configreport": {
"installed_version": "0.2.1",
"enabled": "yes"
"core": {
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"public_files": "files_sharing\/public.php",
"first_install_version": "10.12.1.3",
"backgroundjobs_mode": "cron",
"lastupdateResult": "[]",
"shareapi_allow_public_notification": "yes",
"vendor": "owncloud",
"installedat": "1684847977.1677",
"default_encryption_module": "OC_DEFAULT_MODULE",
"lastupdatedat": "1685954649",
"allow_user_mount_sharing": "no",
"oc.integritycheck.checker": "[]",
"enable_external_storage": "yes",
"shareapi_allow_social_share": "yes",
"lastcron": "1685966281"
"dav": {
"installed_version": "0.7.0",
"enabled": "yes"
"encryption": {
"userSpecificKey": "1",
"recoveryKeyId": "recoveryKey_07c7cbeb",
"publicShareKeyId": "pubShare_07c7cbeb",
"masterKeyId": "master_07c7cbeb",
"installed_version": "1.5.3",
"enabled": "yes",
"encryptHomeStorage": "0"
"federatedfilesharing": {
"installed_version": "0.5.0",
"enabled": "yes"
"federation": {
"installed_version": "0.1.0",
"types": "authentication",
"enabled": "yes"
"files": {
"installed_version": "1.5.2",
"enabled": "yes",
"cronjob_scan_files": "500"
"files_external": {
"installed_version": "0.9.0",
"enabled": "yes",
"allow_user_mounting": "yes",
"user_mounting_backends": "owncloud,sftp,smb,dav,\\OC\\Files\\Storage\\SFTP_Key,\\OC\\Files\\Storage\\SMB_OC"
"files_mediaviewer": {
"installed_version": "1.0.5",
"types": "",
"enabled": "yes"
"files_pdfviewer": {
"installed_version": "1.0.1",
"types": "",
"enabled": "yes"
"files_sharing": {
"installed_version": "0.14.0",
"enabled": "yes"
"files_texteditor": {
"types": "",
"enabled": "yes",
"installed_version": "2.5.1"
"files_trashbin": {
"installed_version": "0.9.1",
"enabled": "yes"
"files_versions": {
"installed_version": "1.3.0",
"enabled": "yes"
"firstrunwizard": {
"installed_version": "1.2.0",
"types": "",
"enabled": "yes"
"gallery": {
"signed": "true",
"installed_version": "16.1.2",
"enabled": "yes",
"types": ""
"market": {
"types": "",
"enabled": "yes"
"music": {
"signed": "true",
"installed_version": "1.8.3",
"enabled": "yes"
"notifications": {
"installed_version": "0.5.4",
"types": "logging",
"enabled": "yes"
"provisioning_api": {
"types": "prevent_group_restriction",
"enabled": "yes"
"richdocuments": {
"enabled": "no",
"wopi_url": "https:\/\/collabora.theosys.at",
"signed": "true",
"installed_version": "3.0.0",
"systemtags": {
"types": "logging",
"enabled": "yes"
"templateeditor": {
"installed_version": "0.4.0",
"types": "",
"enabled": "yes"
"updatenotification": {
"types": "",
"enabled": "yes"
# docker-compose exec owncloud occ app:list
Enabled:
- activity:
- Version: 2.7.1
- calendar:
- Version: 2.0.0
- Path: /var/www/owncloud/custom/calendar
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.1
- dav:
- Version: 0.7.0
- encryption:
- Version: 1.5.3
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.5.2
- files_external:
- Version: 0.9.0
- files_mediaviewer:
- Version: 1.0.5
- files_pdfviewer:
- Version: 1.0.1
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.5.1
- Path: /var/www/owncloud/apps/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.2.0
- gallery:
- Version: 16.1.2
- Path: /var/www/owncloud/custom/gallery
- market:
- Version: 0.7.0
- music:
- Version: 1.8.3
- Path: /var/www/owncloud/custom/music
- notifications:
- Version: 0.5.4
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- templateeditor:
- Version: 0.4.0
- Path: /var/www/owncloud/apps/templateeditor
- updatenotification:
- Version: 0.2.1
Disabled:
- admin_audit:
- Path: /var/www/owncloud/apps/admin_audit
- announcementcenter:
- Path: /var/www/owncloud/apps/announcementcenter
- customgroups:
- Path: /var/www/owncloud/apps/customgroups
- enterprise_key:
- Path: /var/www/owncloud/apps/enterprise_key
- external:
- files_antivirus:
- Path: /var/www/owncloud/apps/files_antivirus
- files_classifier:
- Path: /var/www/owncloud/apps/files_classifier
- files_external_dropbox:
- Path: /var/www/owncloud/apps/files_external_dropbox
- files_external_ftp:
- Path: /var/www/owncloud/apps/files_external_ftp
- files_ldap_home:
- Path: /var/www/owncloud/apps/files_ldap_home
- files_lifecycle:
- Path: /var/www/owncloud/apps/files_lifecycle
- firewall:
- Path: /var/www/owncloud/apps/firewall
- graphapi:
- Path: /var/www/owncloud/apps/graphapi
- guests:
- Path: /var/www/owncloud/apps/guests
- metrics:
- Path: /var/www/owncloud/apps/metrics
- oauth2:
- Path: /var/www/owncloud/apps/oauth2
- openidconnect:
- Path: /var/www/owncloud/apps/openidconnect
- password_policy:
- Path: /var/www/owncloud/apps/password_policy
- ransomware_protection:
- Path: /var/www/owncloud/apps/ransomware_protection
- richdocuments:
- Path: /var/www/owncloud/custom/richdocuments
- sharepoint:
- Path: /var/www/owncloud/apps/sharepoint
- systemtags_management:
- Path: /var/www/owncloud/apps/systemtags_management
- theme-enterprise:
- Path: /var/www/owncloud/apps/theme-enterprise
- user_external:
- user_ldap:
- Path: /var/www/owncloud/apps/user_ldap
- user_shibboleth:
- Path: /var/www/owncloud/apps/user_shibboleth
- web:
- Path: /var/www/owncloud/apps/web
- windows_network_drive:
- Path: /var/www/owncloud/apps/windows_network_drive
- wopi:
- Path: /var/www/owncloud/apps/wopi
- workflow:
- Path: /var/www/owncloud/apps/workflow
Proxy configuration of apache
ProxyPreserveHost On
ProxyRequests on
ProxyPass "/owncloud" "http://10.x.x.x:8080"
ProxyPassReverse "/owncloud" "http://10.x.x.x:8080"
Docker compose configuration
version: '3'
volumes:
files:
driver: local
redis:
driver: local
services:
owncloud:
restart: always
image: owncloud/server:${OWNCLOUD_VERSION}
container_name: owncloud_server
ports:
- ${HTTP_PORT}:8080
depends_on:
- redis
environment:
- OWNCLOUD_DOMAIN=${OWNCLOUD_DOMAIN}
- OWNCLOUD_TRUSTED_DOMAINS=${OWNCLOUD_TRUSTED_DOMAINS}
- OWNCLOUD_TRUSTED_PROXIES=${OWNCLOUD_TRUSTED_PROXIES}
- OWNCLOUD_DB_TYPE=pgsql
- OWNCLOUD_DB_NAME=owncloud
- OWNCLOUD_DB_USERNAME=**********
- OWNCLOUD_DB_PASSWORD=**********
- OWNCLOUD_DB_HOST=10.x.x.x:5432
- OWNCLOUD_DB_PREFIX=oc_
- OWNCLOUD_ADMIN_USERNAME=${ADMIN_USERNAME}
- OWNCLOUD_ADMIN_PASSWORD=${ADMIN_PASSWORD}
- OWNCLOUD_DEFAULT_LANGUAGE=de
- OWNCLOUD_REDIS_ENABLED=true
- OWNCLOUD_REDIS_HOST=redis
- OWNCLOUD_HTACCESS_REWRITE_BASE=/
- OWNCLOUD_LOG_TIMEZONE=Europe/Vienna
- OWNCLOUD_MAIL_DOMAIN=theosys.at
- OWNCLOUD_MAIL_FROM_ADDRESS=office
- OWNCLOUD_MAIL_SMTP_AUTH_TYPE=PLAIN
- OWNCLOUD_MAIL_SMTP_HOST=10.x.x.x
- OWNCLOUD_MAIL_SMTP_MODE=smtp
- OWNCLOUD_MAIL_SMTP_PORT=25
- OWNCLOUD_OVERWRITE_WEBROOT=/owncloud
- OWNCLOUD_OVERWRITE_PROTOCOL=https
healthcheck:
test: ["CMD", "/usr/bin/healthcheck"]
interval: 30s
timeout: 10s
retries: 5
volumes:
- /opt/owncloud:/mnt/data
redis:
image: redis:6
container_name: owncloud_redis
restart: always
command: ["--databases", "1"]
healthcheck:
test: ["CMD", "redis-cli", "ping"]
interval: 10s
timeout: 5s
retries: 5
volumes:
- redis:/data
Are you using external storage, if yes which one: Link to other owncloud instance
Are you using encryption: yes
Browser: Firefox
Web server error log (from frontend)
10.x.x.149 - - [05/Jun/2023:14:02:10 +0200] "PROPFIND /owncloud/remote.php/dav/files/andreas/ HTTP/1.1" 207 1446 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:02:10 +0200] "GET /owncloud/ocs/v1.php/cloud/capabilities?format=json HTTP/1.1" 200 3340 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:02:11 +0200] "GET /owncloud/ocs/v1.php/cloud/user?format=json HTTP/1.1" 200 1390 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:02:11 +0200] "GET /owncloud/remote.php/dav/avatars/andreas/128.png HTTP/1.1" 404 1221 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:02:18 +0200] "PROPFIND /owncloud/remote.php/dav/files/andreas/ HTTP/1.1" 207 6204 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:02:58 +0200] "PROPFIND /owncloud/remote.php/dav/files/andreas/ HTTP/1.1" 207 6202 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:03:38 +0200] "PROPFIND /owncloud/remote.php/dav/files/andreas/ HTTP/1.1" 207 6204 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:14 +0200] "GET /owncloud/status.php HTTP/1.1" 200 6030 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:14 +0200] "PROPFIND /owncloud/remote.php/dav/files/andreas/ HTTP/1.1" 207 1444 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:14 +0200] "GET /owncloud/ocs/v1.php/cloud/capabilities?format=json HTTP/1.1" 200 3346 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:14 +0200] "GET /owncloud/ocs/v1.php/cloud/user?format=json HTTP/1.1" 200 1390 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:15 +0200] "GET /owncloud/remote.php/dav/avatars/andreas/128.png HTTP/1.1" 404 1211 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:18 +0200] "PROPFIND /owncloud/remote.php/dav/files/andreas/ HTTP/1.1" 207 1445 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
10.x.x.149 - - [05/Jun/2023:14:04:21 +0200] "GET /owncloud/ HTTP/1.1" 302 1444 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:21 +0200] "GET /owncloud/login HTTP/1.1" 200 3296 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:22 +0200] "GET /owncloud/core/js/oc.js?v=9ad02c7e6d383515e305e2adab9a4725 HTTP/1.1" 200 2419 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:23 +0200] "GET /owncloud/core/vendor/browser-update/browser-update.js?_=1685966662868 HTTP/1.1" 200 11431 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:33 +0200] "POST /owncloud/login HTTP/1.1" 303 1574 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:33 +0200] "GET /owncloud/apps/files/ HTTP/1.1" 303 1212 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:33 +0200] "GET /owncloud/login?redirect_url=%252Fapps%252Ffiles%252F HTTP/1.1" 200 3334 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:34 +0200] "GET /owncloud/core/js/oc.js?v=9ad02c7e6d383515e305e2adab9a4725 HTTP/1.1" 200 2415 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
10.x.x.149 - - [05/Jun/2023:14:04:35 +0200] "GET /owncloud/core/vendor/browser-update/browser-update.js?_=1685966674842 HTTP/1.1" 200 11431 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
Web server error log (from docker)
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:14 +0000] "GET /status.php HTTP/1.1" 200 1254 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:04:14 +0000] "PROPFIND /remote.php/dav/files/andreas/ HTTP/1.1" 207 1422 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:04:14 +0000] "GET /ocs/v1.php/cloud/capabilities?format=json HTTP/1.1" 200 3324 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:04:14 +0000] "GET /ocs/v1.php/cloud/user?format=json HTTP/1.1" 200 1368 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:04:15 +0000] "GET /remote.php/dav/avatars/andreas/128.png HTTP/1.1" 404 1189 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:04:18 +0000] "PROPFIND /remote.php/dav/files/andreas/ HTTP/1.1" 207 1423 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 127.0.0.1 - - [05/Jun/2023:12:04:21 +0000] "GET /status.php HTTP/1.1" 200 1190 "-" "curl/7.68.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:21 +0000] "GET / HTTP/1.1" 302 1099 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:21 +0000] "GET /login HTTP/1.1" 200 3274 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:22 +0000] "GET /core/js/oc.js?v=9ad02c7e6d383515e305e2adab9a4725 HTTP/1.1" 200 4813 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:23 +0000] "GET /core/vendor/browser-update/browser-update.js?_=1685966662868 HTTP/1.1" 200 11387 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:33 +0000] "POST /login HTTP/1.1" 303 1229 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:33 +0000] "GET /apps/files/ HTTP/1.1" 303 1190 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:33 +0000] "GET /login?redirect_url=%252Fapps%252Ffiles%252F HTTP/1.1" 200 3312 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:34 +0000] "GET /core/js/oc.js?v=9ad02c7e6d383515e305e2adab9a4725 HTTP/1.1" 200 4809 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 10.x.x.x - - [05/Jun/2023:12:04:35 +0000] "GET /core/vendor/browser-update/browser-update.js?_=1685966674842 HTTP/1.1" 200 11387 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"
owncloud_server | 127.0.0.1 - - [05/Jun/2023:12:04:51 +0000] "GET /status.php HTTP/1.1" 200 1198 "-" "curl/7.68.0"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:04:58 +0000] "PROPFIND /remote.php/dav/files/andreas/ HTTP/1.1" 207 1424 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 127.0.0.1 - - [05/Jun/2023:12:05:21 +0000] "GET /status.php HTTP/1.1" 200 1188 "-" "curl/7.68.0"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:05:38 +0000] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 1314 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:05:38 +0000] "PROPFIND /remote.php/dav/files/andreas/ HTTP/1.1" 207 1426 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 10.x.x.x - andreas [05/Jun/2023:12:05:38 +0000] "PROPFIND /remote.php/dav/files/andreas/ HTTP/1.1" 207 5101 "-" "Mozilla/5.0 (Linux) mirall/2.11.0 (ownCloud, debian-6.1.0-9-amd64 ClientArchitecture: x86_64 OsArchitecture: x86_64)"
owncloud_server | 127.0.0.1 - - [05/Jun/2023:12:05:51 +0000] "GET /status.php HTTP/1.1" 200 1194 "-" "curl/7.68.0"
{"reqId":"414a9426-699e-4ec8-b31e-6966f4742ac0","level":0,"time":"2023-06-05T14:05:38+02:00","remoteAddr":"10.x.x.149","user":"--","app":"OC\\Authentication\\Token\\Defau
ltTokenProvider::invalidateToken","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/andreas\/","message":"invalidating token a485e67e0e8fba34aa7cd9c971b77361
d375685c075c45326b090b7e591a18c5fe742d08bbfdb4670d7959d2122374745e54cb9714ed40606646880149780ff2"}
{"reqId":"b685558f-cb9a-4d70-874b-a732a2622f44","level":0,"time":"2023-06-05T14:05:38+02:00","remoteAddr":"10.x.x.149","user":"--","app":"core","method":"GET","url":"\/ow
ncloud\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","message":"OC\\Authentication\\LoginPolicies\\GroupLoginPolicy policy registered"}
{"reqId":"b685558f-cb9a-4d70-874b-a732a2622f44","level":1,"time":"2023-06-05T14:05:38+02:00","remoteAddr":"10.x.x.149","user":"--","app":"OC\\User\\Session::loginInOwnClo
ud","method":"GET","url":"\/owncloud\/ocs\/v2.php\/apps\/notifications\/api\/v1\/notifications?format=json","message":"login andreas using \"password\" login type"}
ltTokenProvider::getToken","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/andreas\/","message":"token 8ceb49d6421c9cd47d99ac7f54b28e38eb98b02e7ae46bd90ddd
2b6e9adf5386dacd1de9a236e79d341c41d01eb4683b33af87020413d48837c9a1f04223d50d does not exist"}
{"reqId":"414a9426-699e-4ec8-b31e-6966f4742ac0","level":0,"time":"2023-06-05T14:05:38+02:00","remoteAddr":"10.x.x.149","user":"--","app":"OC\\User\\Session::login","metho
d":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/andreas\/","message":"regenerating session id for uid andreas, password set"}
{"reqId":"414a9426-699e-4ec8-b31e-6966f4742ac0","level":0,"time":"2023-06-05T14:05:38+02:00","remoteAddr":"10.x.x.149","user":"--","app":"OC\\User\\Session::validateToken
","method":"PROPFIND","url":"\/owncloud\/remote.php\/dav\/files\/andreas\/","message":"token 8ceb49d6421c9cd47d99ac7f54b28e38eb98b02e7ae46bd90ddd2b6e9adf5386dacd1de9a236e
79d341c41d01eb4683b33af87020413d48837c9a1f04223d50d, not found"}
