yesterday I updated to from Owncloud 10.4. to Owncloud 10.6. to use the Owncloud Web App.
Now the Mozilla Thunderbird Calendar doesn’t connect to my calendar anymore. I can’t “activate” it.
Over my android phone the connection still works. So I am a little lost.
Haven’t changed anything on Thunderbird.
Anyone with the same problem and maybe a solution?
- Install Mozilla Thunderbird 78.6.1
- Install Owncloud 10.6.0 (stable)
- Install App oauth2
- Install Owncloud Web
- Create a calendar in Thunderbird and try to connect
The calendar should fetch the data from owncloud
The calendar can’t connect to owncloud
Operating system: Linux a2e3d 4.9.0-12-amd64 #1 SMP Debian 4.9.210-1+deb9u1 (2020-06-07) x86_64
Web server: Apache
Database: 5.7.32 - MySQL Community Server (GPL)
PHP version: 7.2.34
ownCloud version: 10.6.0 (stable)
Updated from an older ownCloud or fresh install: updated from 10.4.0.4 to 10.4.1.3 to 10.5.0.10 to 10.6.0
Where did you install ownCloud from: Webinstaller
https://gist.github.com/tinogithub/ca6b2dd25db33817bad4f853054e128f
"system": {
"instanceid": "oc4c2c9vksza",
"trusted_domains": [
"cloud.XXXXXX.de"
"datadirectory": "\/httpdocs\/owncloud\/cloud_data",
"overwrite.cli.url": "https:\/\/cloud.XXXXXX.de",
"dbtype": "mysql",
"version": "10.6.0.5",
"dbname": "kXXXXX_owncloud",
"dbhost": "10.35.46.62:3306",
"dbtableprefix": "oc_",
"logtimezone": "UTC",
"installed": true,
"maintenance": false,
"theme": "",
"loglevel": 2,
"mail_smtpmode": "php",
"trashbin_retention_obligation": "auto, 7",
"trashbin_purge_limit": 15,
"updater.secret": "***REMOVED SENSITIVE VALUE***",
"web.baseUrl": "https:\/\/cloud.XXXXXX.de\/index.php\/apps\/web"
Enabled:
- activity: 2.6.0
- calendar: 1.6.4
- comments: 0.3.0
- configreport: 0.2.0
- contacts: 1.5.5
- dav: 0.6.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.4
- files_pdfviewer: 0.11.2
- files_sharing: 0.14.0
- files_texteditor: 2.3.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.9
- firstrunwizard: 1.2.0
- gallery: 16.1.1
- market: 0.6.0
- notifications: 0.5.2
- oauth2: 0.4.4
- onlyoffice: 6.2.1
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- templateeditor: 0.4.0
- twofactor_totp: 0.7.1
- updatenotification: 0.2.1
- web: 1.0.2
Disabled:
- encryption
- external
- user_external
Are you using encryption: no
Mail-Client: Thunderbird 78.6.1
Operating system: Windows 10
no log during that time
Access SSL log
89.12.185.155 - - [20/Jan/2021:14:59:15 +0100] "PROPFIND /remote.php/dav/calendars/XXXXXXX/owncloud_kalender/ HTTP/1.0" 401 1636 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:78.0) Gecko/20100101 Thunderbird/78.6.1"
Mail-Client Log
401 Unauthorized (HTTP/2)
