Hello, I have installed owncloud in a DMZ on a host with disabled ipv6 and the marketplace doesnt work ( see error below ). Also i get similar erros in data/owncoud.log. Is there fix to use ipv4 instead of ipv6? Or is there something different that I’m missing?
Thank you in advance for any help
- Install owncloud 10
- disable ipv6
- try to use market
- look in data/owncloud.log
I expect marketplace to work and owncloud.log without errors
No marketplace connection: cURL error 7: Failed to connect to 2a01:4f8:161:73ec::2: Network is unreachable.
also another error in data/owncloud.log: cURL error 7: Failed to connect to 2a01:4f8:130:806f::5: Network is unreachable
Operating system: Centos 7
Web server: nginx 1.12.2
Database: MariaDB 10.1
PHP version: 7.1
ownCloud version: 10.0.3
Where did you install ownCloud from: official site ( source code )
Signing status (ownCloud 9.0 and above): No errors have been found.
The content of config/config.php: config_report_20171127.txt (66.2 KB)
Are you using encryption: no
