Since Devuan-Ascii is a fork of Debian 9, it is assumed that the owncloud-client_2.4.3 client amd64 downloaded from the Owncloud clients webpage for DEBIAN 9 would properly install on a Devuan-Ascii amd64 install.
Client does NOT install on Devuan-Ascii and emits the following errors:
Unpacking owncloud-client:amd64 (2.4.3+oc-10035) …
dpkg: dependency problems prevent configuration of owncloud-client:amd64:
owncloud-client:amd64 depends on libowncloudsync0 (= 2.4.3+oc-10035); however:
Package libowncloudsync0 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5concurrent5; however:
Package ocqt562+240-libqt5concurrent5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5core5a; however:
Package ocqt562+240-libqt5core5a is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5dbus5; however:
Package ocqt562+240-libqt5dbus5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5gui5; however:
Package ocqt562+240-libqt5gui5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5keychain1; however:
Package ocqt562+240-libqt5keychain1 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5network5; however:
Package ocqt562+240-libqt5network5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5sql5; however:
Package ocqt562+240-libqt5sql5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5webkit5; however:
Package ocqt562+240-libqt5webkit5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5widgets5; however:
Package ocqt562+240-libqt5widgets5 is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5xml5; however:
Package ocqt562+240-libqt5xml5 is not installed.
owncloud-client:amd64 depends on owncloud-client-l10n; however:
Package owncloud-client-l10n is not installed.
owncloud-client:amd64 depends on ocqt562+240-libqt5sql5-sqlite; however:
Package ocqt562+240-libqt5sql5-sqlite is not installed.
dpkg: error processing package owncloud-client:amd64 (–install):
Please advise
