Owncloud 504 timeout when accessing through domain
  1. fresh install of owncloud docker compose stack
  2. existing install of nginx proxy manager
  3. existing domain via dynDNS script on cloudflare
  4. ???
Owncloud should be accessible via domain, localhost and internal network IP
Owncloud is accessible via localhost/internal network IP but not via domain.
Via Domain Owncloud infinitely loads until nginx raises a 504 timeout.
Ubuntu 22.04.4 LTS hosting docker Ubuntu 22.04.6
unknown
mariadb:10.11
unknown
redis version:
redis:6
ownCloud 10.15.0 (stable)
fresh install via docker compose
https://doc.owncloud.com/server/10.15/admin_manual/installation/docker/
https://gist.github.com/JustLokust/4eadd17d0b4a5ae594b550544d9cfbde
do not know how to check in docker container
Are you using external storage, if yes which one: local /mnt/hdd..
Are you using encryption: no?
Are you using an external user-backend, if yes which one: no?
Google Chrome 127.0.6533.120 (64-Bit)
Windows 11
do not know how to collect in docker
https://gist.github.com/JustLokust/b34472bd700188e3356c77c74d5f2ac9
note that I have manually restarted the server causing the apache restart message
Network tab just shows a 504 Gateway Time-out after 90s of no answer.
Additional Information
Docker Port Forwarding
Since Port 8080 is already being used on the system I rerouted the Port to 444:8080 via docker.
Nginx Reverse Proxy
The Docker containers are running on a machine that is also hosting a wide variety of different services. Therefore a Nginx Reverse Proxy is running and distributing the traffic.
Following Setup has been done for owncloud:
Cloudflare DynDNS
Since where I come from my Internetprice would more than double just for a simple static IP Adress I am stuck with using DynDNS.
I solved this via using the Cloudflare API (where I also host my domain) to update my current IP-adress via script. This is done using a docker container with the oznu/cloudflare-ddns image.
The Script updates an A Entry for my domain.
All other subdomains are CNAME Entries including the owncloud subdomain.
from what i know ownCloud is only a web application and written in PHP. From what i know ownCloud is not responsible for such responses like “504 timeout” or similar which i think is originating from the used web server.
I think it could be possible that the ownCloud community can’t help with such web server topics (i think this can be seen due to the lack of responses from the community here) and i think that it could be possible that support channel for networking / web server or docker specific topics needs to be contacted.
