ownCloud 8.2.2.2 webfront blank after enabling Calendar
Calendar app should be enabled and usable.
Blank screen is shown in FireFox. HTTP 500 error is shown in Internet Explorer.
Ubuntu
Apache2
MySQL (I think)
8.2.2.2
7
Don’t remember
With CLI I get: PHP Fatal error: Class ‘OC_Search’ not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39
As I recall only native ones from oc install.
no
no
no
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
Output omitted:
[Mon Jan 22 06:25:08.259154 2018] [ssl:warn] [pid 1190] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Mon Jan 22 06:25:08.259194 2018] [ssl:warn] [pid 1190] AH01909: RSA certificate configured for 192.168.0.248:443 does NOT include an ID which matches the server name
[Mon Jan 22 06:25:08.274076 2018] [mpm_prefork:notice] [pid 1190] AH00163: Apache/2.4.7 (Ubuntu) PHP/5.5.9-1ubuntu4.9 OpenSSL/1.0.1f configured -- resuming normal operations
[Mon Jan 22 06:25:08.274106 2018] [core:notice] [pid 1190] AH00094: Command line: '/usr/sbin/apache2'
[Tue Jan 23 23:07:17.523222 2018] [:error] [pid 10431] [client 192.168.0.1:3049] PHP Fatal error:  Class 'OC_Search' not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39
[Tue Jan 23 23:07:42.889532 2018] [:error] [pid 9194] [client 192.168.0.1:3053] PHP Fatal error:  Class 'OC_Search' not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39
[Tue Jan 23 23:31:32.308904 2018] [mpm_prefork:notice] [pid 1190] AH00169: caught SIGTERM, shutting down
[Tue Jan 23 23:31:59.381859 2018] [ssl:warn] [pid 1152] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Jan 23 23:31:59.410690 2018] [ssl:warn] [pid 1152] AH01909: RSA certificate configured for 192.168.0.248:443 does NOT include an ID which matches the server name
[Tue Jan 23 23:32:05.621893 2018] [ssl:warn] [pid 1153] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Tue Jan 23 23:32:05.621922 2018] [ssl:warn] [pid 1153] AH01909: RSA certificate configured for 192.168.0.248:443 does NOT include an ID which matches the server name
[Tue Jan 23 23:32:05.623346 2018] [mpm_prefork:notice] [pid 1153] AH00163: Apache/2.4.7 (Ubuntu) PHP/5.5.9-1ubuntu4.9 OpenSSL/1.0.1f configured -- resuming normal operations
[Tue Jan 23 23:32:05.623362 2018] [core:notice] [pid 1153] AH00094: Command line: '/usr/sbin/apache2'
[Tue Jan 23 23:32:40.931665 2018] [:error] [pid 1290] [client 192.168.0.1:3360] PHP Fatal error:  Class 'OC_Search' not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39
[Tue Jan 23 23:32:46.764032 2018] [:error] [pid 1289] [client 192.168.0.1:3361] PHP Fatal error:  Class 'OC_Search' not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39
[Wed Jan 24 08:14:22.274153 2018] [:error] [pid 1288] [client 93.167.1.185:60267] PHP Fatal error:  Class 'OC_Search' not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39
Output omitted:
{"reqId":"NrhPjbJlvoZL4b3ytHzh","remoteAddr":"212.237.130.200","app":"PHP","message":"Cannot modify header information - headers already sent by (output started at \/var\/www\/html\/owncloud\/3rdparty\/sabre\/http\/lib\/Sapi.php:70) at \/var\/www\/html\/owncloud\/3rdparty\/sabre\/http\/lib\/Sapi.php#58","level":3,"time":"2017-08-22T17:17:03+00:00"}
{"reqId":"hHSlbwLIxiqql4A7iCzy","remoteAddr":"192.168.0.1","app":"core","message":"Could not get categories, content was no valid XML","level":3,"time":"2018-01-23T22:06:32+00:00"}
{"reqId":"Xw3tJbvudSR6a19DaCCd","remoteAddr":"192.168.0.1","app":"core","message":"Could not get application, content was no valid XML","level":3,"time":"2018-01-23T22:06:32+00:00"}
{"reqId":"MW4Q4XJYYmr3FNQXufBF","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:07:17+00:00"}
{"reqId":"i0bRNu3Yjz9vUET9DRtR","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:07:42+00:00"}
{"reqId":"VlfFkr\/fJ6ZpXAXpXGRS","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:07:42+00:00"}
{"reqId":"ENFfDokZNADHVYk6omk4","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:07:59+00:00"}
{"reqId":"SXlHA0xUHG7ay9pzTYdA","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:07:59+00:00"}
{"reqId":"O\/ZV2kwDbG1wDqXzWX\/0","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:32:40+00:00"}
{"reqId":"0JWDq+tTqs+wnGXP8o8X","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-23T22:32:46+00:00"}
{"reqId":"VIAvL4CF4DI3fyTCDSi9","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:14:22+00:00"}
{"reqId":"zuZ8qWkBLs7xhTzWuLN9","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:14:22+00:00"}
{"reqId":"8MN8LIRftlzCN7ZcL7AM","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:14:22+00:00"}
{"reqId":"KmRxdclM9b4msCbSVJdk","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:19:22+00:00"}
{"reqId":"M6LTJ8r9yvjMKcidu5Lo","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:24:22+00:00"}
{"reqId":"763BvLX+ItV7tFFIkvqD","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:29:22+00:00"}
{"reqId":"1AnE\/GkCoT\/fL7LfzCoG","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:34:22+00:00"}
{"reqId":"kk0JaiWLxKvLDnUueVqr","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:39:22+00:00"}
{"reqId":"I4byi+Hz3g9v8YeojOEr","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:44:22+00:00"}
{"reqId":"\/HL\/uoitqWhzjZPj5WRR","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:49:22+00:00"}
{"reqId":"uTCHw2nRWW6cbpZBSL6V","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T07:54:22+00:00"}
{"reqId":"DaPRrUK3u6Wi8kDrmgjp","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:30:53+00:00"}
{"reqId":"pzotSBPI7Yz\/WhPAfU9C","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:30:53+00:00"}
{"reqId":"l7w+g5kv1wWp1z4rnBeO","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:30:53+00:00"}
{"reqId":"TF7QsViHazU2rJUxiict","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:30:53+00:00"}
{"reqId":"0GCqN5FuE2ql6oVGimms","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:30:53+00:00"}
{"reqId":"hLqmFUkK5ATXz4\/Fzcpf","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:35:53+00:00"}
{"reqId":"zxR2mNRWN93nOFhmmOuX","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:40:53+00:00"}
{"reqId":"65wK4u1kIFpRPDGekvgv","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:45:53+00:00"}
{"reqId":"+oM9QTcCa3c6KfoyEbih","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:50:53+00:00"}
{"reqId":"X1B8q+BCfaWlLx0lu\/q7","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T09:55:53+00:00"}
{"reqId":"WATvxvSkXpSDXDKijD\/H","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:00:53+00:00"}
{"reqId":"+6upDu9ityY7tUz9XMeL","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:05:53+00:00"}
{"reqId":"9MAwKOz8CJlZ\/YSOKh4P","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:10:53+00:00"}
{"reqId":"tBj3lG7en7diwizQbg7K","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:15:53+00:00"}
{"reqId":"wGhNn04juGF36J5+kk0c","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:20:53+00:00"}
{"reqId":"HfekbQL27wV\/u0V6VBSh","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:25:53+00:00"}
{"reqId":"JSI5TlKTbhTY306e83qg","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:30:53+00:00"}
{"reqId":"BB\/+NsQaSvwdZX1T+30F","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:35:53+00:00"}
{"reqId":"+mISXqmB9\/GVzq9W8Ar3","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:40:53+00:00"}
{"reqId":"q4YzotPjb8xTgFHD6Zrt","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:45:53+00:00"}
{"reqId":"S4KbYVUgFj0kmyjv9ok5","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:50:53+00:00"}
{"reqId":"I4TbPZhyDv+DzvLceMoc","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T10:55:53+00:00"}
{"reqId":"d7s3AhkgBn5+i9lmZBlp","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:00:53+00:00"}
{"reqId":"BfP9AhhD3n28kGoqSQcG","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:05:53+00:00"}
{"reqId":"+a7ds9RQj0ZxsnRgNw4o","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:10:53+00:00"}
{"reqId":"nGabFFUFbs3HEfVE3Mdb","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:15:53+00:00"}
{"reqId":"PJm6RIfOjuoNwhaMVLAV","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:20:53+00:00"}
{"reqId":"lAGWi0idQ6DMQwxWml+6","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:25:53+00:00"}
{"reqId":"+SRcTalcsV2idH9W\/hqD","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:30:53+00:00"}
{"reqId":"t7\/+vy7DhUKq7Nggn9re","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:35:53+00:00"}
{"reqId":"d9YsjXXaltsV1qMzJjjj","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:40:53+00:00"}
{"reqId":"IedWyuGEsv2LQrvquv1m","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:45:53+00:00"}
{"reqId":"yI0uLucWjlRwUpBTVM\/+","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:50:53+00:00"}
{"reqId":"lT3lOxVoAoPoETmnuHwm","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T11:55:53+00:00"}
{"reqId":"sApZ\/mwzkWHKxAGI9cwO","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:00:53+00:00"}
{"reqId":"9aMEyiiewyuN\/wRezAXj","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:05:53+00:00"}
{"reqId":"PMp4OJcFqUGnDSHcNjG6","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:10:53+00:00"}
{"reqId":"GDjYNkKQ732AjAdMvR0x","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:15:53+00:00"}
{"reqId":"O5PgI1ZIdZHvX4E27RiX","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:20:53+00:00"}
{"reqId":"c8CBzrwloBd7BrQf8lVK","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:25:53+00:00"}
{"reqId":"tIHzwEzgVywH9SKVjomp","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:30:53+00:00"}
{"reqId":"Q+MzGjuVmhO5pelWjxXJ","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:35:53+00:00"}
{"reqId":"wSMV35+mmYB65AdIJRmg","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:40:53+00:00"}
{"reqId":"Qgmbvw\/qIGP+\/qOoqXBA","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:45:53+00:00"}
{"reqId":"DfAHwcbWNwf\/2DqA2x2\/","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:50:53+00:00"}
{"reqId":"DfzxS1qgQ1ptM9cVmZHl","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T12:55:53+00:00"}
{"reqId":"1XhOgymdZeES2p\/Kv4g+","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:00:53+00:00"}
{"reqId":"XLgZbwlF3Cy8JUDBVNyG","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:05:53+00:00"}
{"reqId":"nd55nZ\/F0jM92eEnFE8R","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:10:53+00:00"}
{"reqId":"8lHw55tuynbb1MxRURh4","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:15:53+00:00"}
{"reqId":"M71bU8vOCgiwUV2VtX+F","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:20:53+00:00"}
{"reqId":"TzYDxe1MJDi6OG\/L+JGn","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:25:53+00:00"}
{"reqId":"NTBaU6MPiJKLUqC1kHtz","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:30:53+00:00"}
{"reqId":"F49cJQYYtiNr7UbqrVFM","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:35:53+00:00"}
{"reqId":"dE+bp7hyTgvOMVzZb5Qt","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:40:53+00:00"}
{"reqId":"ImWaleOrI0W6iTsxWsCw","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:45:53+00:00"}
{"reqId":"lu\/R6TbXHRpPvED7qeMO","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:50:53+00:00"}
{"reqId":"9HofjmSRvwBMnSkbB8zw","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T13:55:53+00:00"}
{"reqId":"CfKtPzsHTEhtCmMrIFC5","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:00:53+00:00"}
{"reqId":"Ydk7L1DoR0zitovMZANC","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:05:53+00:00"}
{"reqId":"BeRCwgpu7LJ1ggG0nAhh","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:10:53+00:00"}
{"reqId":"bSLW300PFLSQn4B\/lrTO","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:15:53+00:00"}
{"reqId":"73vaiTjypuqIVwL1E7Ru","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:20:53+00:00"}
{"reqId":"Dsm+QWi0qx3VM3aby5vZ","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:25:53+00:00"}
{"reqId":"K\/zJr+KJCHsL0GhqL1Zl","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:30:53+00:00"}
{"reqId":"culTVtNN\/EQbUVpzsDa6","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:35:53+00:00"}
{"reqId":"HaqtctUCFIOOqQ2FFUl8","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:40:53+00:00"}
{"reqId":"KafYjfwbL6xgOwth9RmA","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:45:53+00:00"}
{"reqId":"tQS8hFVnu1mwDMHidws5","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:50:53+00:00"}
{"reqId":"ADfgq\/GMxf36dju2RRMy","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T14:55:53+00:00"}
{"reqId":"sd8pDipl8YO0EyKJTcUE","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T15:00:53+00:00"}
{"reqId":"VN69+Wo1ObpJqVj2JyUG","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T15:05:53+00:00"}
{"reqId":"bYSH2jvjarAF59o8zcTO","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T15:55:54+00:00"}
{"reqId":"Sd\/\/JapP7Nyvz7KxOT9w","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T16:00:54+00:00"}
{"reqId":"stOs6ptCbsrPrWFv8cNk","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T16:05:54+00:00"}
{"reqId":"6XrXu2EsIEFlkdPyB44l","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T16:10:54+00:00"}
{"reqId":"5siuGcG28blkBihRJNlR","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T16:15:54+00:00"}
{"reqId":"gZN2r0GI3JCrEVIA0oHw","remoteAddr":"93.167.1.185","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T16:20:54+00:00"}
{"reqId":"sVmgfM62z97RNGwzQg9\/","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:21:53+00:00"}
{"reqId":"Nyrx2QpWjMy+b5eXkbb\/","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:21:53+00:00"}
{"reqId":"oTmxjrxvZg8M4EHX0twg","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:21:53+00:00"}
{"reqId":"jVM73x22N5BNuVi1Ciwq","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:21:53+00:00"}
{"reqId":"8uHwxz7aFRqD5dQgxXWC","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:21:53+00:00"}
{"reqId":"tjeDWIiIA6Ub\/Vvi0dmo","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:26:53+00:00"}
{"reqId":"ZgypYPoSYm5VWpo9yjkR","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:31:53+00:00"}
{"reqId":"qUoa37WDA+guCql3W2O4","remoteAddr":"","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:32:25+00:00"}
{"reqId":"Dl7yYvTgYOLWZQ39Y1Ua","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:36:53+00:00"}
{"reqId":"sQQO1xxRuPVJkCw0EOFP","remoteAddr":"192.168.0.63","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:38:34+00:00"}
{"reqId":"b9ndmLuqB3YUTeZu\/mOR","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:41:53+00:00"}
{"reqId":"0te\/EXmx85lhhQWOmH9W","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:46:53+00:00"}
{"reqId":"P5OpyfbIYteDtur7sXfi","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:51:53+00:00"}
{"reqId":"tPhn8z7t6R3CpVFH5Z9Q","remoteAddr":"192.168.0.63","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:54:22+00:00"}
{"reqId":"6FElbTleW\/UHLBkps8da","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T20:56:53+00:00"}
{"reqId":"4dKIU81fd5XLfgYB\/pMI","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T21:01:53+00:00"}
{"reqId":"i8AzP+NYrodDZtjshUJw","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T21:06:53+00:00"}
{"reqId":"6lbY5LHJkU4P70pA2\/mz","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T21:11:53+00:00"}
{"reqId":"a1utpAyvgL0ZzYC9vOIB","remoteAddr":"192.168.0.1","app":"PHP","message":"Class 'OC_Search' not found at \/var\/www\/html\/owncloud\/apps\/calendar\/appinfo\/app.php#39","level":3,"time":"2018-01-24T21:16:53+00:00"}
#### Browser log
c) …
Looks like the calendar app does not properly work together with your server installation.
Please upgrade our server to ownCloud 10 and get a properly working calendar app from the marketplace.
ownCloud 8.2 is end of live and no longer supported
Would it be possible for now to just get the webfront working again? Or do you think that upgrading will restore webfront funtionality?
Br
Frank
By the way, I’ve tried disabling calendar app from CLI with no luck. I get err “PHP Fatal error: Class ‘OC_Search’ not found in /var/www/html/owncloud/apps/calendar/appinfo/app.php on line 39”.
Br
Frank
Try to remove /var/www/html/owncloud/apps/calendar completely - well actually move might be better just in case we need to restore it …
Thank you so much. That did the trick. I can now focus on upgrading OC.
Br
Frank
