Owncloud 8.2.7 to 9.1
I have done yesterday by misstake the package upgrade via linux package repository from 8.2.7.1 to 9.1.4, but it was not working.
I decided today do the manual upgrade from 8.2.7.1 to 9.0.8, everything is working, but on pkg info i see still the 9.1.4 version, so I decided to continue to version 9.1.4 manually, but then I get the
The process control (PCNTL) extensions are required in case you want to interrupt long running commands - see PHP: PCNTL - Manual
Set log level to debug
> Exception: Updates between multiple major versions and downgrades are unsupported.
Update failed
Maintenance mode is kept active
Reset log level
also the occ status i get is that the version 9.1.4 is already installed, but in the webpage I see version 9.0.8
  • installed: true
  • version: 9.1.4.2
  • versionstring: 9.1.4
  • edition:
Any suggestion what to do next ?
Or where can be the problem?
Thanks.
I have fixed that issue, there was the problem with the latest tar file downloaded and also manual procedure was not correctly done.
Now everything is working.
in such cases putting the “Updates between multiple major versions and downgrades are unsupported.” message into the search box of the forums might help as well to get to the needed info. There is also a FAQ about this available here at [1].
[1]
