rasco
March 16, 2017, 5:44pm
1
contacts_old: An exception occurred while executing ‘CREATE TABLE oc_contacts_addressbooks (id INT UNSIGNED AUTO_INCREMENT NOT NULL, userid VARCHAR(255) DEFAULT ‘’ NOT NULL, displayname VARCHAR(255) DEFAULT NULL, uri VARCHAR(200) DEFAULT NULL, description VARCHAR(255) DEFAULT NULL, ctag INT UNSIGNED DEFAULT 1 NOT NULL, active INT DEFAULT 1 NOT NULL, INDEX c_addressbook_userid_index (userid), PRIMARY KEY(id)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB’: SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘oc_contacts_addressbooks’ already exists
You have already reported that to the bugtracker at [1] (which is btw. a duplicate of [2]) so please keep this issue at one place.
[1]
opened 05:29PM - 16 Mar 17 UTC
closed 12:19PM - 19 Mar 17 UTC
status/STALE
### Steps to reproduce
1.
2.
3.
### Expected behaviour
Tell us what shoul… d happen
I run the new update
### Actual behaviour
Updating ownCloud to version 9.0.8, this may take a while.
Preparing update
Set log level to debug
Turned on maintenance mode
Checking whether the database schema can be updated (this can take a long time depending on the database size)
Checked database schema update
Checking updates of apps
Checked database schema update for apps
Updating database schema
Updated database
contacts_old: An exception occurred while executing 'CREATE TABLE `oc_contacts_addressbooks` (`id` INT UNSIGNED AUTO_INCREMENT NOT NULL, `userid` VARCHAR(255) DEFAULT '' NOT NULL, `displayname` VARCHAR(255) DEFAULT NULL, `uri` VARCHAR(200) DEFAULT NULL, `description` VARCHAR(255) DEFAULT NULL, `ctag` INT UNSIGNED DEFAULT 1 NOT NULL, `active` INT DEFAULT 1 NOT NULL, INDEX c_addressbook_userid_index (`userid`), PRIMARY KEY(`id`)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB': SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'oc_contacts_addressbooks' already exists
### Server configuration
**Operating system**:
Debian 7.6
**Web server:**
Apache2
**Database:**
php myadmin
**PHP version:**
php 5.5.27
ownCloud 8.2.9
web /settings/admin#updater
paste the results here.
ownCloud will be updated to version 9.0.8
Please make sure that the database, the config folder and the data folder have been backed up before proceeding.
**List of activated apps:**
Insert your config.php content here
(Without the database password, passwordsalt and secret)
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
[2]
opened 03:09PM - 08 Apr 16 UTC
closed 02:03PM - 13 Dec 17 UTC
needs info
feature:update
1. Install owncloud on centos 7.2 and mariodb on another … server, php 5.5.34 and ldap
2. Try to upgrade from 8.2.3 to 9.0.1
3.
Upgrade should works (at least the installer should detect that the tables already exist and update them instead of trying to create them)
Upgrade fail because of some mysql error messages
**Operating system**: Centos 7.2
**Web server:**
Apache
**Database:**
mariadb 10.10.22
**PHP version:**
5.5.34
8.2.3
yes
**Browser:**
### Logs
Here are the logs from the upgrade:
bash-4.2$ ./occ upgrade
Checking whether the database schema for <activity> can be updated (this can take a long time depending on the database size)
Checking whether the database schema for <files_sharing> can be updated (this can take a long time depending on the database size)
Checking whether the database schema for <user_ldap> can be updated (this can take a long time depending on the database size)
Updated database
Updating <files_pdfviewer> ...
Updated <files_pdfviewer> to 0.8
Updating <files_texteditor> ...
Updated <files_texteditor> to 2.1
Updating <gallery> ...
Updated <gallery> to 14.5.0
Updating <user_ldap> ...
Updated <user_ldap> to 0.8.0
Updating <files> ...
Updated <files> to 1.4.4
Updating <activity> ...
Updated <activity> to 2.2.1
Updating <files_sharing> ...
Updated <files_sharing> to 0.9.1
Updating <files_versions> ...
Updated <files_versions> to 1.2.0
notifications: An exception occurred while executing 'CREATE TABLE `oc_notifications` (`notification_id` INT AUTO_INCREMENT NOT NULL, `app` VARCHAR(32) NOT NULL, `user` VARCHAR(64) NOT NULL, `timestamp` INT DEFAULT 0 NOT NULL, `object_type` VARCHAR(64) NOT NULL, `object_id` VARCHAR(64) NOT NULL, `subject` VARCHAR(64) NOT NULL, `subject_parameters` LONGTEXT DEFAULT NULL, `message` VARCHAR(64) DEFAULT NULL, `message_parameters` LONGTEXT DEFAULT NULL, `link` VARCHAR(4000) DEFAULT NULL, `actions` LONGTEXT DEFAULT NULL, INDEX oc_notifications_app (`app`), INDEX oc_notifications_user (`user`), INDEX oc_notifications_timestamp (`timestamp`), INDEX oc_notifications_object (`object_type`, `object_id`), PRIMARY KEY(`notification_id`)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB':
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'oc_notifications' already exists
federation: An exception occurred while executing 'CREATE TABLE `oc_trusted_servers` (`id` INT AUTO_INCREMENT NOT NULL, `url` VARCHAR(512) NOT NULL COMMENT 'Url of trusted server', `url_hash` VARCHAR(255) DEFAULT '' NOT NULL COMMENT 'sha1 hash of the url without the protocol', `token` VARCHAR(128) DEFAULT NULL COMMENT 'token used to exchange the shared secret', `shared_secret` VARCHAR(256) DEFAULT NULL COMMENT 'shared secret used to authenticate', `status` INT DEFAULT 2 NOT NULL COMMENT 'current status of the connection', `sync_token` VARCHAR(512) DEFAULT NULL COMMENT 'cardDav sync token', UNIQUE INDEX url_hash (`url_hash`), PRIMARY KEY(`id`)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB':
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'oc_trusted_servers' already exists
files_trashbin: An exception occurred while executing 'CREATE TABLE `oc_files_trash` (`auto_id` INT AUTO_INCREMENT NOT NULL, `id` VARCHAR(250) DEFAULT '' NOT NULL, `user` VARCHAR(64) DEFAULT '' NOT NULL, `timestamp` VARCHAR(12) DEFAULT '' NOT NULL, `location` VARCHAR(512) DEFAULT '' NOT NULL, `type` VARCHAR(4) DEFAULT NULL, `mime` VARCHAR(255) DEFAULT NULL, INDEX id_index (`id`), INDEX timestamp_index (`timestamp`), INDEX user_index (`user`), PRIMARY KEY(`auto_id`)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB':
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'oc_files_trash' already exists
dav: An exception occurred while executing 'CREATE TABLE `oc_addressbooks` (`id` BIGINT UNSIGNED AUTO_INCREMENT NOT NULL, `principaluri` VARCHAR(255) DEFAULT NULL, `displayname` VARCHAR(255) DEFAULT NULL, `uri` VARCHAR(255) DEFAULT NULL, `description` VARCHAR(255) DEFAULT NULL, `synctoken` INT UNSIGNED DEFAULT 1 NOT NULL, UNIQUE INDEX addressbook_index (`principaluri`, `uri`), PRIMARY KEY(`id`)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB':
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'oc_addressbooks' already exists
Starting code integrity check...
Finished code integrity check
Update successful
Turned off maintenance mode
Reset log level
bash-4.2$
rasco
March 16, 2017, 10:18pm
3
Update:
I run the following command from command
sudo -u www-data ./occ upgrade
Updated database
calendar_old: An exception occurred while executing ‘CREATE TABLE oc_clndr_objects (id INT UNSIGNED AUTO_INCREMENT NOT NULL, calendarid INT UNSIGNED DEFAULT 0 NOT NULL, objecttype VARCHAR(40) DEFAULT ‘’ NOT NULL, startdate DATETIME DEFAULT ‘1970-01-01 00:00:00’, enddate DATETIME DEFAULT ‘1970-01-01 00:00:00’, repeating INT DEFAULT 0, summary VARCHAR(255) DEFAULT NULL, calendardata LONGTEXT DEFAULT NULL, uri VARCHAR(255) DEFAULT NULL, lastmodified INT DEFAULT 0, PRIMARY KEY(id)) DEFAULT CHARACTER SET utf8 COLLATE utf8_bin ENGINE = InnoDB’:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table ‘oc_clndr_objects’ already exists
Starting code integrity check…
Update successful
Reset log level
My owncloud came back … but this time i have another error.
"there were problems with the code integrity check , more information
Results
core
EXTRA_FILE
owncloud-8.1.1.tar.bz2
indie.json
stats/hourly_usage_201703.png
stats/ctry_usage_201609.png
stats/usage_201509.html
stats/usage_201507.html
stats/hourly_usage_201606.png
stats/daily_usage_201610.png
stats/webalizer.current
stats/hourly_usage_201701.png
stats/ctry_usage_201612.png
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[owncloud-8.1.1.tar.bz2] => Array
[expected] =>
[current] => 7d975e3352529a50c362b31445f36cc75ad7999618011320518b04e3a3853fcefac39dd53a6c9880bf6e073c46f06203d12f1ca9c0cb4c816fa784c11620c0a7
[indie.json] => Array
[expected] =>
[current] => 09c52e4fec07e803f9cbd5526da5b378f98a70fb6a28bd7c6a6b1a654afae6e06a98756aca485da1be2f2adada58b6c52258ddb621386385e7926b54989d1799
The one thing i did is i got the backup before doing the upgrade and replace does files.
is there a way to fix this.. i check the documentation but unable to fix.
rasco
March 17, 2017, 12:05am
4
Guys never mind this has being solved.
for some reason i copied does files by mistake i deleted them
and message when away now everything is good
SOLVED
Solution:
From command prompt
@rasco If this is solved for you please close your reported issue at github.
status/STALE
1.
2.
3.
Preparing update
Updated database
Debian 7.6
**Web server:**
Apache2
**Database:**
php myadmin
**PHP version:**
php 5.5.27
ownCloud 8.2.9
**Browser:**
### Logs
#### Browser log
