ownCloud 8.2.x (known issues, faq and upgrade problems)
Blogpost about upgrading: https://owncloud.org/blog/upgrading-to-owncloud-server-8-2/
General changes in this release: ownCloud Documentation Overview
Another blogpost how to do a correct upgrade: all mine!: How to Upgrade ownCloud: Don't Skip Releases!
Please read those links carefully!!!
Common issues
On every major upgrade it is recommended to do a full upgrade by deleting all files and folders within your installation directory except /data/ and /config/ and then extract the new code into this installation directory. How to do a full upgrade can be found at the documentation:
Updates between multiple major versions and downgrades are unsupported.
Please see: ownCloud Central
Known Bugs
A list of bugs to fix or features to include for 8.2.6 is available here: Issues · owncloud/core · GitHub
Massive increase in MySQL-load: Massive increase in MySQL load after upg from 8.2.3 to 8.2.5 · Issue #24651 · owncloud/core · GitHub
fix will be included in 8.2.6: [8.2] cache isLocal for shared storage by icewind1991 · Pull Request #24841 · owncloud/core · GitHub
Files locked: “server replied: Locked” or “Exception: is locked”
→ Was fixed with 8.2.2
→ If this still happens with existing files a manual cleanup of the locking table is needed
→ See File that were locked cannot still be synced with 8.2.2 · Issue #21360 · owncloud/core · GitHub for more details
Known Issues with PHP 7
You need at least oC 8.2.3 for full PHP 7 compatibility. With PHP 7.0.6 there is small issue that will be fixed in OC 8.2.4:
until this new release, you can apply this patch manually: [Stable 8.2] Make ownCloud work again in php 7.0.6 by rullzer · Pull Request #24344 · owncloud/core · GitHub
When running Apache and PHP there is currently also an issue within the .htaccess shipped by oC. Make sure that you replace:
with
in your .htaccess. Ref: Mod_php7.c reference missing in .htaccess · Issue #21146 · owncloud/core · GitHub
Fixed Bugs
Shared folder (by link) doesn’t display all files
→ Was partly fixed in 8.2.1 but happens again for two reasons:
→ PDF Viewer App might cause this
—> Report: Shared folders don't show all files in a directory when pdfviewer 0.7 is active · Issue #21373 · owncloud/core · GitHub
→ Internet Explorer (IE) still doesn’t show all files
—>Report: Shared folder doesn't display all files · Issue #21203 · owncloud/core · GitHub
→ Fix for both issues is included in 8.2.3: Backport of #91 - Fix regression introduced by 72069f4 by Henni · Pull Request #92 · owncloud/files_pdfviewer · GitHub
Fixes pagination in IE by MorrisJobke · Pull Request #22548 · owncloud/core · GitHub
E-Mail notifications not sent out
→ Might be caused by a deleted background job.
→ A possible workaround was posted here: No email notification · Issue #20962 · owncloud/core · GitHub
→ The issue is also fixed with oC 8.2.3 and the update should re-add the background job automatically.
Updater is failing with "Unable to move /var/www/owncloud/_oc-upgrade/8.2.1.4/core/resources to /var/www/owncloud/resources
Workaround: [Stable8.2] Use 8.2 by VicDeo · Pull Request #192 · owncloud/updater · GitHub
→ Was fixed with oC 8.2.2. If you have a oC version prior to 8.2.2 you need to manually apply the fix of the workaround above.
Unable to generate a URL for the named route “xyz” as such route does not exist.
Report: Upgrade to 8.1.3 fails with URL route error · Issue #19145 · owncloud/core · GitHub
Workaround: Dont die when we're missing a route by icewind1991 · Pull Request #20788 · owncloud/core · GitHub
→ Was fixed with oC 8.2.2 / 8.1.5
Cannot share at all when share with link is disabled globally
Report: Cannot share at all when share with link is disabled globally · Issue #20642 · owncloud/core · GitHub
Workaround: Enable “Share by link” or apply [stable8.2] Fix duplicate bogus share field when link sharing is not allowed by PVince81 · Pull Request #21012 · owncloud/core · GitHub manually
overwritewebroot config setting is broken which is needed for SSL-Proxies
→ Was fixed with oC 8.2.1
Base table or view not found: 1146 Table ‘owncloud.file_locks’ doesn’t exist’
Workaround: Upgrade 8.1->8.2 fails with: Table 'owncloud.oc_file_locks' doesn't exist · Issue #20111 · owncloud/core · GitHub
Public / anonymous uploads via shared link stopped to work
Workaround: fix pagination on public file list · owncloud/core@480a005 · GitHub
Performance issues since 8.2.0
→ Was fixed with 8.2.1
→ Current Workaround: Use redis for transactional file locking (See documentation)
Google drive mounted folder expires after some days
There are various incompatibilities with PHP7 known. Especially the shipped SabreDAV library 2.x in oC 8.2 is not compatible with PHP7. More resources:
[php7] Sabre\DAV\Exception\NotAuthenticated: HTTP/1.1 401 No basic authentication headers were found · Issue #21461 · owncloud/core · GitHub → WebDAV issue
Caldav is not compatible with PHP7 · Issue #21309 · owncloud/core · GitHub → Calendar/Contacts issue
APCu 5.1.2 & PHP7: \OC\Memcache\APCu not usable · Issue #21095 · owncloud/core · GitHub → APCu issue (stripped page)
Weird: ownCloud 8.2.2 with PHP 7.0.1 unstable / unusable - read on · Issue #21352 · owncloud/core · GitHub
Accessing CardDAV causes segmentation fault with PHP 7 · Issue #21476 · owncloud/core · GitHub
Until oC 9.0.0 or 8.2.3 is released which ships PHP7 compatible versions of SabreDAV it is recommended to stay at PHP 5.x.
