ownCloud 9.0.3 will not refresh Dropbox files - Please help
I have ownCloud 9.0.3 installed.
I’m using External Storage 0.5.2 to send files from Dropbox to various FTP accounts.
When I add files on Dropbox using the Dropbox admin they do not appearin ownCloud. OwnCloud is not refreshing the Dropbox file list.
I see this has been a bug for some time. Is there a fix? If so, please explain it in ‘idiot terms’ :slight_smile:
Thanks!
Please update to the latest version first:
If the problems still exists, check your logfiles.
Exactly. This is also shown in the issue template you have missed to fill out:
Before posting please also snip make sure that you’re running the latest available version for your oC release: Changelog - ownCloud
oC 9.0.3 is far from being the latest available version of your oC release.
