ownCloud 9.1.0 : How to enable HSTS?
Hi , I have installed ownCloud on my Raspberry pi B+ (OS : Raspbian 8 (jessie) ) and after successful installation , i went to admin option - there shows this warning message :
The “Strict-Transport-Security” HTTP header is not configured to at least “15552000” seconds. For enhanced security we recommend enabling HSTS as described in our security tips.
My Question is: How can I enable HSTS and configure HTTP header to at least 15552000 seconds? I have searched many forums but now I am confused.
Please help me with detailed procedure.
Thanks in advance. Happy ownClouding! :stuck_out_tongue:
Operating system: Raspbian 8 Jessie
Web server: nginx
PHP version: 5
ownCloud version : 9.1.0
Updated from an older ownCloud or fresh install: Fresh Install
it worth to have a look at the nginx config provided in the official documentation which includes a HSTS part you can enable:
Hi @RealRancor,
Thanks for reply. The link you gave me is already visited. I am no expert in this - I just want to know in which file i need to add this code?
<VirtualHost *:443>
  ServerName cloud.owncloud.com
    <IfModule mod_headers.c>
      Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains; preload"
    </IfModule>
 </VirtualHost>
can you give me detail procedure or guidance?
Thanks in advance.
Best regards-
Nazmul
Sorry, have posted the wrong link. The correct link would be:
as you’re on nginx.
Dear @RealRancor,
Thanks for your awesome response. I just saw the codes and just one question - should i just put this code-
    </IfModule>
after the line below? (i mean line below server name)-
server {
    listen 443 ssl;
    server_name cloud.example.com;
Thanks again.
Best regards-
Nazmul
You don’t want to (and can’t) use apache stuff in nginx. Please read my second post and forget the first post with the link.
Dear @RealRancor,
Many many thanks for your info. I got confused. That’s why I was making same mistakes. I will use codes you suggested and let you know if it works.
Thanks again.
Best regards-
Nazmul
Yeah, that was my fault to post a wrong link. :slight_frown:
Dear @RealRancor,
You are awesome. your code works. Many many thanks. :smiley:
Best regards-
Nazmul
2 posts were split to a new topic: Set HSTS header on apache fails
