Pages load within 1-2 secs
pages load within 20-30 (or more) seconds
Operating system: ubuntu 12.04
ownCloud version: 9.1.6
originally from image, upgraded today to 9.1.6
Owncloud premade image
result: No errors have been found.
<?php $CONFIG = array ( 'updatechecker' => false, 'instanceid' => 'oc6p7d7e0t1e', 'trusted_domains' => array ( 0 => 'localhost', 1 => 'vvv.co.uk', ), 'passwordsalt' => 'vvv', 'secret' => 'vvv', 'datadirectory' => '/var/www/owncloud/data', 'overwrite.cli.url' => 'http://localhost/owncloud', 'dbtype' => 'mysql', 'version' => '9.1.6.2', 'dbname' => 'oc', 'dbhost' => '127.0.0.1', 'dbtableprefix' => 'oc_', 'dbuser' => 'oc_admin', 'dbpassword' => 'vvv', 'logtimezone' => 'UTC', 'installed' => true, 'memcache.local' => '\\OC\\Memcache\\APCu', 'mail_smtpmode' => 'smtp', 'mail_smtpauthtype' => 'LOGIN', 'mail_from_address' => 'email', 'mail_domain' => 'vvv.co.uk', 'mail_smtphost' => 'smtp.office365.com', 'mail_smtpport' => '587', 'ldapIgnoreNamingRules' => false, 'loglevel' => 2, 'enable_certificate_management' => true, 'maintenance' => false, 'mail_smtpsecure' => 'tls', 'mail_smtpauth' => 1, 'mail_smtpname' => 'vvv@email.co.uk', 'mail_smtppassword' => 'vvv', 'logfile' => 'owncloud.log', **List of activated apps:** ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** local/smb/sftp/... no **Are you using encryption:** no **Are you using an external user-backend, if yes which one:** LDAP Things I tried to fix it: We had a power cut, the server is a VM, it went into a saved state, as all others did, upon restore of power, the server is now slow. Other windows VMs are fine in speed. Rebooted server upgraded to latest available owncloud version (9.1.5 -> 9.1.6) increased processor and RAM Server still slow Thanks, Tim
